Question about Acer Aspire™ T180 PC Desktop
Coding and synopsis for computerised telephone directory in java.
I want to know the whole things required for making a project on computerised telephone directory.
  • 1 more comment
  • Anonymous Mar 29, 2009
    coding in java for telephone directory
  • Tony May 11, 2010
    Good luck, Nokia have been trying to solve problems with their PC Suite in regard to the contact list/phone book.
  • Prosun Pal
    Prosun Pal May 11, 2010
    What do you mean by "computerised telephone directory"?
    Novelist:
  • 148 Answers
knowing any application programming language will be enough
like
C/C++/VB/Java
for pragramming a computerised telephone directory on pc ie, offline
but if you want to do it on the web you need to know web scripting languages like
php/perl/python and some database to store the values like mysql
Further Queries are welcome
If you think my solution was helpfull please do rate me
Posted on Feb 23, 2009
How to pprogram a java language
download java compiler from http://www.oracle.com/technetwork/java/javase/downloads/index.html
Go where you install your java, default Path is "C:\Program Files\Java"
in Java Folder open folder jdk then open bin copy its directory located at the address bar then
Right Click My Comuter > left click Properties > Advance > Environment Variables > on System Variables find Path then click it then click Edit
insert a semicolon " ; " on the end of the textbox (if already have don't add semicolon) then paste the directory you copy...
you can now create your Java Code....
to Compile and Run it...
open command promt ( to open click start > run > type cmd )
go to directory where you save your java code..
(ex. if your Directory is "D:\Java Folder" then type "cd.." press Enter repeat "cd.." until "C:\>" is remaining then type "D:" press enter then type "cd Java Folder" then press Enter type "javac (name of your javacode).java " Press Enter (if there is an error correct your java code) if no type "java (name of your javacode)" there you can run your Java Code
Aug 04, 2011 | Microsoft Windows XP Professional for PC
Plz suggest me topic for minor project in core java ,i am in 5th sem B.E
You can go for core java projects as well JSP Projects. As you are in 5th semester of BE mini project in Java will suit your requirements.
Check some projects here If it can help you out.
http://projectsgeek.com/java-mini-projects-with-source-code
Aug 10, 2010 | Microsoft Windows XP Professional
Want a good project topic in advanced java
You can build a good project like which takes all input required to generate a K-Map and then shows graphically the map.
Jan 25, 2010 | Microsoft Windows XP Professional
Hi tryed to download javameantime, error code 25099 connot unzipp core files, how do i corect the problem,
WORKAROUND
Step 1 : Completely delete content of the following directory: C:\Program Files\Java\jre6\ (or alternate directory if you chose a non-default install location)
Step 2 : If Step 1 has permission issues due to files being locked or in use, restart your system
Step 3 : Now, completely delete content of the following directory: C:\Program Files\Java\jre6\
Step 4 : Download and install Java.
  1. Go to Java.com
  2. Click on the Free Java Download button, and start the installation process.
Sep 17, 2009 | Microsoft Windows XP Professional With...
Rename a folder in c drive using java code
import java.io.*;
public class RenameFileOrDir{
public static void main(String[] args) throws IOException{
BufferedReader in = new BufferedReader(new InputStreamReader(System.in));
System.out.print("Please enter the file or directory
name which has to be Renamed : ");
String old_name = in.readLine();
File oldfile = new File(old_name);
if(!oldfile.exists())
System.out.println("File or directory does not exist.");
System.exit(0);
System.out.print("please enter the new file or directory name : ");
String new_name = in.readLine();
File newfile = new File(new_name);
System.out.println("Old File or directory name : "+ oldfile);
System.out.println("New File or directory name : "+ newfile);
boolean Rename = oldfile.renameTo(newfile);
if(!Rename)
System.out.println("File or directory does not rename successfully.");
System.exit(0);
else {
System.out.println("File or directory rename is successfully.");
Mar 30, 2009 | Sun Java Programming Language (cdj-275)
Java source code for detecting phone call
hello Asda
First things first:
1) Check the online manual for JAVA aplication, it tell all those codes you need.
Carl
http://java.sun.com/docs/books/tutorial/
Feb 09, 2008 | Audio Players & Recorders
Acer Aspire™ T180 PC Desktop Logo
1,225 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
