Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Reset parental lock for panasonic pt-53wx53
I have forgotten the parental lock code for my tv and the manual states that I will need to have it serviced profesionally to reset it. Can you help?
You can try this it worked for my pt53wx52f... On front of TV if there are a set of buttons with your channel and volume look for the Action Button. Press and hold the Action button and while holding the action button press the power button. Hold these two buttons for 5 seconds and the TV will go into a self check. Turn the TV off then wait 10 seconds and turn it back on, The parental lock settings should be set to OFF
Posted on Nov 21, 2011
    Scholar:
  • 150 Answers
Hi, try this it works' on most pan. tv`s, ON REMOTE push the power button for at least 7 seconds, video-tek
Posted on Feb 11, 2009
Pt-53wx53 Panasonic Projection TV Turns off
OK< likely one of the new chips are bad or when soldered in you shorted pins at that time----3 blinks is short protection and you are going to find ONE of the light blue 2.2 ohm resistors is open (usually discolored in middle).
Having changed hundreds of chips in this model once in a while you get a new one that is bad---replace both again.
How did you get at them----remove the board or pull the light box?
Oct 26, 2012 | Panasonic PT-53WX53 53" Rear Projection...
Looking for the steps to connect panasonic tv
if PT-53wx53 just Google the model number with manual after it and you will find an owners manual for free---save to your computer and read it--if questions let me know.
Mar 11, 2012 | Panasonic PT-53WX53 53" Rear Projection...
How do I reset or get rid of the parental control lock. I just got the TV as a gift but they didn't unlock it.
Go to Panasonic website, or Google model #; you can get the manual, will answer all the questions.
Nov 05, 2010 | Panasonic PT-47WX49 47" Rear Projection...
I need to reset lamp on PT-52LCX16 Panasonic rear projection tv how do I do that
MODEL INDICATED DOES NOT USE A "LAMP", IT IS A CRT (picture tube---has red, green and blue picture tubes).
Verify model number is or is not correct.
What is problem with this set?
SD TECH
Aug 16, 2010 | Panasonic PT-53WX53 53" Rear Projection...
How do I remove the top part of a PT-53WX53 panasonic rear projection tv. I can get the back off but not the top part off. My Mini-van isn't big enough, so i need to split it into two parts to transport...
Hello Griff,<br />Did you ever get a copy of the Service Manual from Lonemountain? If you did, would you send it to: vipnite at yahoo dot com<br />.I would greatly appreciate your help. I hope you were able to take care of your problem. Was yours a convergence problem as well?<br />Kind Regards,<br />Ricky<br /> <!-- from fixya rte -->
Nov 11, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53wx53 rear projection tv does not turn on, blinking
Thats the error code for the convergence. You can get the PT53WX53 Convergence repair kit at the following link. www.tvrepairworld.com
the kit contains the parts and CD with instructions
Aug 14, 2009 | Panasonic PT-53TW53 53" Rear Projection...
How do you reset forgotten parental control password?
for the phillips and magnavox tv sets the code is 0711, then open the menu setting restet the code to something easy to remember , or what i would do is completly disable the child lock by going to that option in parental settings.try it hope it works!
Apr 14, 2008 | Philips Magnavox 27MS343S 27" TV
PT-53wx53 replacement bulb
Your model doesnt have a bulb. The PT 53WX53 is a progressive scan CRT projection TV. You have 3 CRT Tubes, Red, Green And Blue. Hope this helps. If you need more info let me know.
Jan 30, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
You can try these codes 2211 or 3308 if they do not work you will need to reset the unit. You will need to unplug it for 45 minutes that will reset the TV to factory settings. Then the pass codes I provided should work.
Oct 23, 2006 | Daewoo DTQ-13P2FC 13" TV
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
244 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
