Question about Canon DC210 DVD Camcorder
I can not get my canon DC210 batteries to charge
I have a Canon DC210 and my batteries won't charge. i thought the old battery might have a charing problem but took it to a battery place and they charged it no worries and I came home and viewed what was on the camcord and could operate it until the battery went flat once again. So then I thiought that it was my charger and I bought a new charger for the unit but the charger won't charge either can i be doing something wrong or do you think their is something with the unit. i love my camcord and it is only just over a year old. What can i do?
I have a friend who brought me his camera that had exhibied the same problem for over a year. I took it apart and found that the cable going to the charger was a bit loose. Might not be for the faint of heart, but it does work now.
First you need to take the two dark grey panels that go around the outside of the camera. Next you will have access to the rounded cover that goes above the lens. Once that is off you will be able to remove the silver cover on the left side of the camera, underneath which there are a couple of ribbon cables that go from a board inside the camera to the battery terminals and the lcd screen. Just make sure the cable is pushed in good and reassemble. There are about 18 screws you have to remove that range from tiny to tinier to tiniest, so keep track of what you are doing and good luck!
Posted on Jul 13, 2009
    Scholar:
  • 170 Answers
Clean the contacts on the battery and the charger with a pencil eraser. Make sure you are inserting the batteries correctly, with the battery contacts touching the charger's contacts.
Posted on Feb 11, 2009
Battery wont charge
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 04, 2012 | Canon PowerShot SD1000 Digital Camera
Canon S8100 battery won't charge
well somethings wrong with your canon S8100 battery or you need a new charger, or battery
Apr 24, 2012 | Nikon S8100 Digital Camera
Batteries run out fast
If the recharageable battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% and graduallythe charge reduces until the battery won't charge up at all. OR The batteryshows a 100% charge but when the adapter is disconnected the battery drops offto zero capacity in a very short time. If the battery drops to an unacceptablecharge level then the battery needs to be replaced.
Mar 25, 2012 | Canon PowerShot A80 Digital Camera
Canon Elura 90 camcorder
If the battery do not have any current after removing it from the charger, you can use 6 volt adaptor bust the battery before charging
Nov 03, 2011 | Video Cameras
Battery not charing
Ifthe cell phone battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Jul 07, 2011 | AT&T Computers & Internet
Does it really need to be plugged into an outlet to turn on?
NO - the camera should have a battery life for at least 2-3hrs for video taking and playback.
It does need to be in it's base to recharge properly , maybe the battery is low and , but , once charged fully you should be able to turn on/off many times.
Try letting the batteries run down very low - and then leave them charging for 7-10 hours. -- Ray
Feb 19, 2011 | Canon DC210 DVD Camcorder
I HAVE TO CONTINUALLY BUY NEW BATTERYS BECAUSE THEY WIIL NOT CHARGE AFTER ONE OR TWO USES.
I now canon got an avertising about lithium ion
counterfeigth battery running at different place retailer you must buy original battery pack from canon
or its could be your charger pack
Feb 23, 2010 | Canon DC210 DVD Camcorder
Charging battery on a DC210
It blinks red when charging and it goes to steady red when its fully charged.
The best source is to look in the user manual:
http://gdlp01.c-wss.com/gds/0900000562/DC210NIM-EN.pdf
Its on pg. 20, step 5 on the right column.
Jun 17, 2008 | Canon DC210 DVD Camcorder
My Canon DC210 will not turn on. Ithought maybe the battery was dead, so I hooked the camera up to the charger. It's been charging for two days now. But whenever I try to turn it on the "DISC/CHG" light...
You may have a faulty charger or internal battery.
If your camera is still under warranty take it back to the shop where you bought it, explain what is happening, and ask for a refund or exchange.
Feb 29, 2008 | Canon DC210 DVD Camcorder
Canon dc210
It sounds like you may have a faulty battery or charger.
Take the extra battery and whatever you used to charge it (camcorder or battery charger) back to the shop where you bought it and get them to help you figure out what's wrong with their product. Your purchase is still under warranty and you deserve to have a product that works.
Dec 29, 2007 | Canon DC210 DVD Camcorder
Canon DC210 DVD Camcorder Logo
259 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
