Question about Philips Televison & Video
Wrap around/folding picture
I have a Magnavox 25tsc6 0101 and the picture is ''folded'' on the top and bottom making it hard to watch. Is there anything I can check or repair to fix this at a reasonable cost?
  • ponyracer Feb 11, 2009
    Thanks for your reply! where can I download a wiring diagram for the pc board to aid in locating this?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem indicates a problem in the vertical section. The folding normally is caused by a faulty boost capacitor. Faulty capacitors are easily identified by bulging top (normally flat), blistered/split casing, brownish paper within the immediate surrounding, rubber bottom partially out and/or powdery residue on one of the pins. This is relatively an easy/quick repair and would normally be inexpensive. There are however instances where the vertical IC is at fault or some other minor components. What would be more challenging would be identifying which to replace and/or getting access to the solder points.
Good luck and thank you for using FixYa.
Posted on Feb 11, 2009
  • Louie  Role
    Louie Role Feb 11, 2009
    For the service manual/schematic, pls try here.
Toshiba 36 CRT tv has a Bottom left corner picture problem. Looks like its folded or pulling away from left corner!?....
Vertical scan output section circuit fault. Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences of the author of that site.
Aug 19, 2016 | Toshiba Televison & Video
Picture has hourglass look and has split screen picture hourglass comes and goes but split screen is continual
If hour glass on conventional set it is either pincussion circuit or power supply---by split screen if you mean folded over top to bottom in the middle that is in the same areas.
Apr 06, 2012 | ESA EF427E TV
A black line (about 2 inches wide) appears at the top of the screen with this amount of the picture looking like it is folded down translucently over the remaining picture. What's up?
Hello
Your TV has vertical fold problem. Just check all the electrolytic capacitors. On checking, most of them may look good. But on circuit, when energised, will show problems. So it is best to replace all of them once and check. Please check the electrolytic capacitor connected to the vertical power supply [usually comes from the secondary supply section of the Line Output Transformer], first, and replce it. It may be a 1500Mfd or 2200mfd. Check it first by replacing a new one. In most foldover cases, this service will solve the problem. gopakumarg43@ymail.com
Oct 18, 2010 | Philips Televison & Video
I HAVE A JVC AV27D302: THE PICTURE IS FOLDED OVER
For how many years this TV with you? Most tv now a days after few years of using vertical IC solder started to dry(dry solder) you can try to re-solder or you may check also two capacitors (100uF/35V) for most JVC model has this symptom with this parts changes its electrical characteristics. If still problem persist replace vertical IC. Hope his helps, Good Luck
Feb 14, 2010 | JVC AV27F476 27" TV
Black bar top 1" screen
Dry capacitors on the vertical output
Feb 17, 2009 | JVC AV-27D302 27" TV
Magnovox TV
I've taken the TV to a Magnavox repair shop.
Apr 29, 2008 | Televison & Video
Phillips 27" flat tube tv
go to menu. u have a horazontel problem
Feb 07, 2008 | RCA 13R400TD 13" TV
27MT5005D vertical foldover
You have bad capacitor(s) in the vertical circuit.
Dec 06, 2007 | Televison & Video
Televison & Video Logo
57 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
