Question about Microsoft Windows Vista Ultimate Edition
My c.p.u have problem
While start the computer on boot willcome on that it have cpufanerror&on middle the system will restat again & again
    Scholar:
  • 116 Answers
Have you checked the CPU fan?
open the system, see if it is turning, make sure it is relatively clean, reseat the cable that goes from the fan to the motherboard.
If the fan runs fast and clean, but the error is still there, there may be an issue with the motherboard.
Sometimes it helps to unplug the power, hold the power button 15 seconds, release, plug back in. Otherwise, unplug the system, and remove the batery from the motherboard for a minute, you may have to reset some BIOS setting after this.
Hope one of these suggestions helps
Posted on Feb 11, 2009
Windows install service
I do not understand your problem ?
Try this.... Start your computer in Safe mode, and then register theMsiexec.exe file. To do this, follow these steps:
  1. Shut down your computer, and then restart your computer.
  2. Restart your computer and press the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, press the F8 key when you see the Boot menu.
  3. Use the ARROW keys to select Safe Mode, and then press ENTER.
  4. If the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  5. Log on to the computer.
  6. Click Start, click Run, type msiexec /regserver in the Open box, and then click OK.
Apr 27, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Dual Boot
You may have overwritten your boot.ini file.
  • Click Start, click Control Panel, and then double-click System.
  • On the Advanced tab, under Startup and Recovery, click Settings.
  • Under System startup, in the Default operating system list, click the operating system that you want to start when you turn on or restart your computer.
  • Select the Display list of operating systems for check box, and then type the number of seconds for which you want the list displayed before the default operating system starts automatically.
    To manually edit the boot options file, click Edit. Microsoft strongly recommends that you do not modify the boot options file (Boot.ini), because doing so may render your computer unusable.
If both OS's are the same, you should be able to copy and paste the line for XP and simply change the drive letter to the location of the second OS.
Jul 10, 2012 | Computers & Internet
My hp pavilion a820n computer will turn on but won't start up
As the computer is starting up keep hitting F8 until you come to the boot options screen. Once in the boot options select "Last Known Good Configuration" and see if it will start. If it still will not start then try and see if the computer will boot in safe mode (Do the F8 thing again until you reach the boot options screen again and click on "Safe Mode").
If it will not load into safe mode then you may need a Windows O/S Reinstall.
Jul 12, 2011 | HP Computers & Internet
My computer is very slow booting
Slow Booting is mainly due to startup items. I would recommend you to disable unnecessary startup items which will surely improves your computer booting speed.
You can do that by following below mentioned steps
Step1: Click on start and then click on Run.
Step 2: Type MS Config and hit ENTER.
Step 3: Click on Startup tab.
Step 4: Click on Disable all then click on apply and then Click on OK.
Step 5: Your system will be prompted for a reboot. Go ahead and restart it.
Step 6: As soon as the system is backup you would get syste configuration utility screen where in you should Check "Don't show this message again".
Step 7: You are all set. Try rebooting again and the booting speed will be lot better.
Note: If you want you keep one or two start up items enable which can be done manually. However disabling start up items will not hamper your system in any way its just that those will not load during boot up. It will still work with out any problem.
If the complete system in slow then disabling start up items does not solve the problem.
Good Luck
Nov 16, 2010 | Computers & Internet
I've never had a satisfactory response or solution. Once I was just left on the line. Why should I try this again?
Please restate your question, giving all the details:
* what happens
* what did you expect to happen
* what OS software (Windows XP/Vista/7)
* what hardware (HP, Dell)
* whether it just started to happen, or it always has malfunctioned
* what application software (Office 2003? Office 2010? WordPerfect? PhotoShop?) you are using.
Jun 10, 2010 | Computers & Internet
Regarding Direct Memory Access
Your disk is probably operating in slow PIO - you can reset it to DMA by reading this article
http://winhlp.com/node/10
Take the Quick solution
Nov 30, 2009 | Microsoft Windows XP Home Edition
Can't start automaticlly call for service
hi
please try to folow these steps .
try to boot the computer from cd.
you needto change the boot oder from hardisk to cd rom
once the computer start booting from cd then try to click on to the option that says repair the operating system .once the os gets repaired your system would run fine
if you once again face a same problem i would suggest to go to http://techbuddies.org and from their you can download the manual guide of OS repair .if you face a problem chat with techbuddies and they will help you on same
Jun 28, 2009 | Microsoft Windows Vista Ultimate Edition
ERROR LAODING OPERATING system
Please boot in safe mode and uninstall the driver.
To boot inn safe mode:
- Start your computer
- Press F8 ( Just before it start booting into windows)
- Select safe mode
Apr 19, 2009 | Microsoft Windows XP Professional
Windows Xp Problem
if yu have a copy of win xp cd. what u do is insert it in yr cd rom drive then make sure yr first boot device is cd rom. now restat yr computer to boot from cd rom just as if u want to reinstall a new xp os but this time yu will chose the option "repair" on the second blue screen that will come out.
try this and all deleted files will be replaced..
NB: before yu start this process make sure yu back up yr important files to a diff drive say d: or possibly external drives incase things go wrong.
thank u
May 30, 2008 | Microsoft Windows XP Professional
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
