Question about Frigidaire Affinity ATF7000ES Front Load Washer
Washer will drain but will not reach full spin in spin only mode
Checked drain pump checked out ok door latch seems ok what maybe the problem
  • 20 Answers
They dont spin full speed if they are overloaded, try it with less clothes.
Posted on Feb 13, 2009
Sounds crazy but try a running the load a few times with NO soap. These washers stop going to a high spin if they detect that too much soap is being used. Also if you go to the spin cycle, click cancel TWICE to where the lights are lit up again then hold down the START and the OPTIONS button at the same time for a few seconds the washer will go into DIAG mode once the lights are flashing back and forth turn the dial once and it will go through a SPIN only cycle and give you any errors that may not show up during normal operation.
Posted on May 05, 2009
Electrolux washing machine wont spin all the way
Not a solution, but I wonder if it thinks you've either selected no spin or it thinks the machine isn't drained and so won't spin or it thinks the load is unbalanced. You seem to have done everything logical so far.
Also look at all all connectors
Logic seems to dictate that if the motor/motor drive functionality and other diagnostics don't show any problems (although I must admit if it were possible I'd like to try another motor control board just to convince me it wasn't implicated) then it must be a logic/ sensor problem and maybe diagnostic mode doesn't check all sensors in the same way as would happen in normal use? Sorry I can't be of more help. (The motor brushes are probably ok but I'd check them anyway while you are in there) Do let us know if you find anything.
Apr 16, 2014 | Electrolux EIFLW55HIW Front Load Washer...
Tip
No spin - tip for all washers.
Hi.
If you have no spin there may be different reasons behind the problem. Before advancing to spin the timer board performs a test on drain part of the cycle, stops the drain and checks the door lock. Drain system, pressure switch and lid switch are all parts that if defective may cause no spin.
The first part to be tested is the drain system. This must be checked regardless of the fact that the pump is working. If there is blockage, residual water in the drain system or water flowing back from drain hose may cause the washer not detecting that drain is complete, and not advancing to spin.
Disconnect power and check the drain system, accessing drain filter and hose connected to the drain pump.
In most front loaders this is accessed removing the trim at the base of the front side of the appliance (under the door), and rotating the filter cap counterclockwise. The filter should be located behind the trim at the base of the washer.
Top loader usually offer access to pump either from back or from the bottom of the appliance. In some case (eg.Kenmore top load) you have to lean the machine forware to gain access to the bottom part of the unit, where the pump is located.
After opening the pump hose cover be prepared to collect a good amount of water. Keep a container at hand. Ensure that power is not connected before starting.
Also double check drain hose at the back of the appliance, and check that the elbow height is as prescribed in manual. Incorrect drain hose settings may result in syphoning, that means water is flowing back from drain hose into the washer tube. This may result in no spin.
After performing the check on the drain system test washer again. Sometimes removing eventual blockage in drain pump may fix this kind of problem.
If the pump is draining, but drain doesn't complete, and if there is no blockage in drain lines, a parts that may be causing the no-spin problem are pressure switch and door latch switch.
The door latch switch is checked by electronic control before advancing to spin. The door switch is tested running a cycle with the door switch contacts jumped. If the model has a lock motor more testing is needed. In that case the switch is tested ensuring that the lock motor impedance reads according to specifications and energizing the lock motor.
If the drain stops always at same point and cycle does not advance replace also the pressure switch. The pressure switch detects water level and determines when drain is over and when to advance to spin. This part is difficult to test in full, the part is not expensive and it is usually replaced without testing. Pressure switch is a common failure causing no spin. If drain is OK, then either pressure switch or lid switch/lock system is usually responsible.
If the above is OK , with top loaders you need to add to the list the problems related to motor and transmission. In front loaders, check problems related to motor and motor control unit. Such problems will be near to the end of the troubleshooting list. Check them before deciding to replace the electronic control.
If all the other parts are OK, what remains is the electronic control module (CCU). The CCU is rarely causing no spin. A defective electronic control module usually results in an error message being prompted, or in the machine not working at all. The part is tested in full reading volts while the machine is operating. In some case it is possible to find a faulty CCU by visually inspecting the board or by testing the module at component level.
For safety reasons some of the operations proposed in the tip are suitable only for a trained technician. Always ensure that power is turned off while inspecting and maintaining the appliance.
Good luck
Ginko.
on Jan 12, 2011 | Washing Machines
Water keeps clicking of after 5 sec same with draining water and drum wont sprin
Hi Robert.
If the machine fills with water and cycle starts but it does not spin and drain, then possible problems are drain hose, drain filter, pressure switch and less frequently pump.
Always disconnect power cord or trip the circuit breaker before performing maintainance operations.
If you need to contact a qualified technician, call the phone number listed on the owners manual.
To find parts give me the model number or click on the link below, select distributor and enter your model number.
Parts and diagrams
Regards.
Ginko
Dec 04, 2011 | Washing Machines
Does not want to drain the water after washing circle
Hi.
Start checking the drain hose at the back, and the hose attached to the drain pump, located at the bottom of the appliance. After that access the control panel and clean the hose attached to the pressure switch. Also check the lid is closing well. Those are the only easy fixes.
The first parts to check are door latch and drain system.
The timer performs an additional check on the door latch before advancing to spin. The door switch it is tested by jumping its contacts, or by reading impedance to check if the switch is opening and closing the circuit (you will need a multimeter).
About the drain system,
if the machine does not drain, then the cycle will not advance to spin.
The electronic control checks the input from pressure switch (which detects water level) before advancing to spin part of the cycle. If there is a drain problem, then the machine will not spin.
The first step will be accessing the drain pump.
Kenmore top loaders' washer pump is accessed from the bottom side of the appliance.
Get ready to collect the water that will come from inside the tub.
Check also the drain hose at the back. Ensure that the height of the hose elbow is respecting the specifications indicated in manual. A wrongly placed hose will result in water going in the washer drain pump and tub, causing drain problems and no spin.
If lid switch and drain lines are OK, replace the pressure switch, which is difficult to test (it is tested reading impedance with tub full and empty. Before replacing the switch, you can try cleaning it and blowing into the switch pipe. Check also motor before replacing the switch. The switch is connected to a long rubber hose and it is located in the control panel.
Below an article about the no spin problem. If the problem is coming with no drain, check drain filter, drain hose at the back. If they are OK, the pressure switch may need to be replaced or the pump may be defective.
Here the general troubleshooting for no spin: If you have no spin there may be different reasons behind the problem.
Enter full model number here (the one written on tag) to get all parts and diagrams for your washer.
Regards.
Ginko.
Mar 19, 2011 | Speed Queen AWS75NW Top Load Washer
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
Won't drain or spin
take toe panel off. reach in to latch from inside theres a tab u pull and door opens
Feb 12, 2010 | Kenmore Elite 45986 Front Load Washer
Won't spin
I replaced the door switch/latch assembly. It works!
Sep 03, 2009 | Kenmore 43142 Front Load Washer
Washer not spinning
You're problem is probably the door latch assembly. This is a common problem on Frigidaire front load washers. You can find the part at your local appliance parts suppliers. If the door latch assembly is faulty, the washer will run through all of its normal cycles, but will not spin. Hope this fixes the problem for you.
Jan 01, 2009 | Frigidaire ATF6000ES Front Load Washer
Actually it's Frigidaire CRTR9300ASO Help Please
Your pump doesn't have a pulley. With the washer full of water if your put it on the spin cycle will it pump out water? If so pump is probably ok and the pressure switch thinks the washer is full of water and spends the whole spin cycle trying to pump water out. If not then your pump is plugged or bad and needs to be replaced.  If your dooe latch is bad your door lock light would not come on. So if it does come on in the spin cycle that part is probably fine.
Nov 07, 2006 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
255 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
