Question about Sony PlayStation Portable (PSP) Console
IP address i just got a wireless router and am tring to get online. it get to network connection- looking for IP address. it sets for a min. and says the attempt has timed out. so what is my IP address. so i can put it in manuly
  • Anonymous Feb 12, 2009
    goodle.com
  • 261 Answers
You get your ip-address by using this http://www.ip-details.com/internet-speed-test/ .
Posted on Sep 11, 2009
    Problem Solver:
  • 12 Answers
You can enter it manually but i wouldnt recomened it because it wouldnt solve your problem. This problem can be solved by entering the wep key for your router. A wep Key is like a password most routers have set as default so people in your neighborhood dont have access to your computer's personal files. Read the manual and find the Ip address section. Each router comes with a installation CD installs a utility program on your computer. You can find the ip address by going on your computer then clicking START-> RUN-> type cmd.exe in the box->in the black box type "ipconfig" without the quotation marks. and it will give you your ip address.
Posted on Feb 13, 2009
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
How can I change my routers IP address?
You can assign Different Ip-address manually,Or use the Proxy to change the ip-address,by hiding the Original Ip-address or contact the ISP get the Dynamic Ip-address and Change the Ip-address,You can check the Ip-address at here
Jan 23, 2011 | D-Link AirPlus DI-524 Wireless Router
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
I have a linksys router and my IP address is 192.168.1.1 how can I locate my passowrd/WEP?
The Linksys configuration URL is http://192.168.1.1 and if you cannot Login or remember the password then you can reset the router back to the factory defaults by -
Power up the Linksys and pressing and holding the pinhole reset button at the back of the Linksys for 30 secs. The router will restart.
Username Login = admin
Password = admin
You can now change the admin password and configure the wireless settings ie SSID, WPA or WPA2 encryption etc.
Don't forget to configure the wireless card in your computer with the router's wireless dettings so the computer can connect to the Linksys.
Apr 04, 2010 | Linksys Wireless-G Broadband Router
When trying to connect to my wireless modem it can't get an ip ad
Is it a modem or a router ?
If it is only modem then only 1 computer will go online at a time. If you have any other computer online already then the second computer will not go online and it will not get IP address.
If it is a combination of modem and router OR if it router then you can open the set up page of the device and find out the password.
For this you will need a computer connected to the device.
Check the IP address and open the set up.
Click Here for more info
Nov 30, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Aquiring network address
Hey there,
in connecting wirelessly to the router, we need to make sure the encryption on the router.
Access the router setup screen, check the IP address first of the computer.
Open IE type there 192.168.1.1 username is blank and password is admin.
once it is on the setup screen checked the wireless tab and look for wireless security, verify it and try to connect again.
in your wireless computer, right click wireless connection and go to view available wireless network, try to connect - input the network key if in case it is not asking you for it, click the changed the order of the preferred networks and then removed all the preferred networks there, then try to connect again and you will now be asked for a network try to connect and you should be connected then.
Jun 24, 2009 | Linksys WRT160N Wireless Router
Network connection
wel you can scan for your router the best way i think or you can test your connection by going to settings on psp go to bottom to then to network settings then infracture mode then click new connection scan if nothing shows up then this was pointless
Feb 11, 2009 | Sony PlayStation Portable (PSP) Console
Cant connect router & dsl modem, cant aquire ip address
Try typing another website on the address bar.
Try checking on your router advaced setting make sure that Mac filtering is off under network filter.
Make sure all other settting on the advaced setting are also in default setting.
Jan 06, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Router
Before you can get online through the router all you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its 192.168.1.1, you need to change it to 192.168.2.1. And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (192.168.2.1).
  2. Now you restart your computer to refresh the connection and that should get you online.
Just reply to my post to let me know if your done doing this. We will setup the wireless after we make sure that you can get online wired to the router.
May 13, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Limited or no connectivity
you need to get into the routers settings (192.168.1.1 in your web browser) and look for DHCP, and enable it so as to give your pc's there automatic ip addresses, also check in the general settings if it's a modem router that you have got a internet connection from your ISP and all the dns and ip addresses are showing. Go to the properties of each network card in network connections in your control panel and click on the TCP/IP line and click properties again and ensure obtain ip address automatically is selected and click ok. Restart all pc's if neccasary and refresh your web browser when trying to get online.
Sep 06, 2007 | 3Com OfficeConnect Router
Sony PlayStation Portable (PSP) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
