Question about Sony PlayStation Portable (PSP) Console
Network connection I just got a wireless router and am tring to get on line with my psp. it get all the way to looking for my IP address. What is a IP address and how do find out mine. so i can put in manuly
    Problem Solver:
  • 13 Answers
Wel you can scan for your router the best way i think or you can test your connection by going to settings on psp go to bottom to then to network settings then infracture mode then click new connection scan if nothing shows up then this was pointless
Posted on Feb 13, 2009
How to connect my self and make my IP address ?
you can set your laptop up to detect ip address automatically in its network settings. if you had provided the operating system it would have helped to narrow down how to do this. If you had told us how you plan to connect to the router this also would have been helpful. Are you connecting via blue cat5 ethernet cable or via wireless. If it is wireless your laptop should detect the wireless network and you can ask it to connect to it. If the wireless link is encrypted you need to log into the router via ethernet cable and look for the securirty settings on the wireless and find out what the encryption code is. Usually the router will use what is called an internal IP address range. the subnet is usually class c being 255.255.255.0 and the ip address default gateway IP address is usually either 10.0.0.1 or 198.168.0.1 and this can be put into the browser to log into the router. When you set the laptop to automatically obtain the IP address the Wireless Router has a DHCP server that manages the leases of IP addresses to computers connected to it. However if you are connecting the Wireless Router into an existing network with another router you will need to set the IP address to the next IP address eg 10.0.0.1 on existing router make second router 10.0.0.2> if you have a DCHP server on the wireless turn it off if you have a DCHP server on the existing router otherwise you have confusion as to which DHCP server to listen too on your network.Make sure the DHCP router does not allocate at least the first 10 addresses eg 10.0.0.1 to 10.0.0.10 to allow for the routers and printers on your network that may need dedicated IP addresses (Static IP addresses)
Feb 07, 2015 | D-Link dlinkgo Wireless N 150 Router...
How come the http://192.168.123.254 address isnt working?
Find your computer's IP address : Windows 7, Vista, and XP, using the command prompt
  1. Click Start, and then select All Programs. Note: If this doesn't match what you see, refer to About navigation settings in Windows.
  2. Click Accessories, and then Command Prompt.
  3. At the command prompt, enter: ipconfig The IP address (or IPv4 address, if you are using Windows 7 or Vista) will be a series of numbers following the pattern xxx.xxx.xxx.xxx (i.e., 156.56.27.32).
Note: If you are using PPP with a modem at home, your IP address will change each time you log in.
Windows 7, without using the command prompt
  1. In the system tray, click the network connection icon and select Open Network and Sharing Center.
  2. To view the IP address of a wired connection, click Local Area Connection. To view the IP address of a wireless adapter, click Wireless Network Connection (Network Name).
  3. Click Details... . Your IP address will appear next to "IPv4 Address".
Windows Vista, without using the command prompt
  1. From the Start menu, right-click Network, and then select Properties. This opens the Network and Sharing Center.
  2. To view the IP address of a wired connection, click View Status to the right of Local Area Connection. To view the IP address of a wireless adapter, click View Status to the right of Wireless Network Connection.
  3. Click Details... . Look for the address next to "IPv4 IP Address".
Windows XP, without using the command prompt
  1. From the Start menu, right-click My Network Places, and then click Properties.
  2. To view the IP address of a wired connection, double-click Local Area Connection. To view the IP address of a wireless adapter, double-click Wireless Network Connection.
  3. Click the Support tab, and then click Details... . The window that appears will display the IP address.
Your IP address has to be in the 192.168.123.xxx range
The router must be configured to match your
Internet service. If you do not know your
Internet connection configuration, please
contact your Internet Service Provider (ISP).
By default, the router is pre-configured with
these settings:
• Automatically set IP addresses for
computers on your LAN (connected to the
router's ports 1-4). The router acts as a
server for dynamic host configuration
protocol (DHCP) and assigns IP addresses
in the range 192.168.123.100 through
192.168.123.199
• The default LAN IP address for the router is
192.168.123.254 with a subnet mask of
255.255.255.0
• The Internet service connected to the
router's WAN port uses a dynamic IP
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 26, 2010 | Asante FriendlyNET FR1104-G Wireless...
I have a hp pavilion dv7-2277cl laptop (64 bit) and a hp laserjet 2605dn. suddenly the communication between the two has gone missing. This is a wireless network and worked until last week. I have down...
The one that is missing in the network is the printer.So try to reconfigure the IP of the printer again using the wireless wizard in the printer manager. Or go to Using the HP Network Diagnostic Utility in Windows - HP Customer Care (United States - English)
Also ; Very seldom does the printer itself cause problems. To determine if you have printer trouble, do the following:
  • If you're using a wireless connection, see if the wireless indicator lamp is illuminated? Can you turn on the wireless radio from the control panel of the printer?
  • Print a Network Configuration page and a Wireless Network Test report from your printer's control panel, if available.
    • Does the Wireless Network Test report indicate trouble?
    • Does the report indicate that the printer is connected to your wireless router, and not to a neighbor's? The network name the printer is connected to will be shown on the both the Network Configuration page and Wireless Network Test report.
    • Compare the printer's IP address [X]
      IP address
      An IP address is a series of numbers by which computers, printers and other devices on a network are known. An IP address is usually issued by the local wireless router (network) from its DHCP service. A device is given an IP address that is similar to the wireless router's IP address. For example, if the wireless router's IP address is 192.168.1.1, a printer may be given an IP address of 192.168.1.5. to the gateway IP address [X]
      Gateway IP address
      This is the IP address of your wireless router. . They should have a similar format (for example, the gateway IP address might be 192.168.0.1 and the printer IP address 192.168.0.5). If the printer has an IP address similar to 169.254.XXX.XXX, it probably is not connected to your wireless network.
    • On some printers, the Network Configuration page will list all wireless networks detected in your area. Is your network listed among those found? Does it have good signal strength?
    • Are there several wireless networks on your same channel or using channels close to your channel? You should use a channel at least 5 channels away from the closest used channel. Consider changing your wireless router's channel to 1, 6 or 11.
  • Are there any error messages on the printer or unexpected blinking lights (consult your manual to determine what to expect)?
  • Reset your printer (usually by removing the power cord from the back of the printer, waiting 30 seconds and then reconnecting the cord. Consult your manual for specifics).
  • Restart your wireless router [X]
    Wireless router
    A wireless router is networking hardware that allows both wired and wireless devices to connect to a network. When connected to a wireless router, devices such as computers, printers, and other Wi-Fi enabled electronics can share one Internet connection AND connect to each other. Connections can be made to the wireless router through a wireless connection or a wired connection using an Ethernet cable. by unplugging the power cord, waiting 60 seconds, then reconnecting the cord to the wireless router.
Dec 16, 2010 | HP Color LaserJet 3500 Printer
How do you get internet on a PSP?
Hi ana01,
Connecting your PSP to the internet is just like connecting your computer to a router. First to consider is having an access point. So what is an access point? Access point is your router. If you wanted to get started going online using your PSP I suggest trying the following steps below:
1. Just turn on your PSP as well as your WLAN/wiresless.
2. Use the left and right directional button to find "Network Setting".
3. Now look for "Infrastracture Mode".
4. Please select "New Connection" and name it.
5. Go to "WLAN Settings" then select "Scan".
6. Your PSP will now detect your router.
7. Navigate to "WLAN security setting". Just leave the option "NONE", If you dont have an encryption in your Router set up.
8. But if have an encryption in your Router. Then put your WEP or WPA security key.
9. Go to "Address Settings". Select "Easy".
10. Navigate to "Setting List". Check if your setting is correct.
11. Go to the next page then save your setting by pressing x. Then press x again once you get a message that says "Save Completed. Test Connection".
12. Next message would say "connecting to access point." The next should say "obtaining IP address".
You already established a connection and you can now browse the net using your PSP.
Hope it helps.
Thank you for using FixYa.
Nov 15, 2010 | Sony PlayStation Portable (PSP) Slim...
My son is trying to connect his PSP game console and it's asking for the security code WEP.
This Utility program will help you locate few details of your network like,
1. SSID ( network name )
2. WEP/WPA Key ( Your network security key )
3. The PC/Laptop IP Address
4. Router IP address
5. Which all Devices are connected to your Router/Network Wireless
6. Which all Network are available nearby your place
7. Let you access the Router Configuration
Click here to Download the HP Network Diagnostic Utility
Download the file on Desktop and Run the program ( Ex. File name = HPNDU.EXE )
Follow the Instructions on the Screen and do accordingly.
Hope this is helpful.
* Rating and comments are welcome on this solution
Nov 11, 2010 | Belkin (F5D7231-4) Wireless Router
Aquiring network address
Hey there,
in connecting wirelessly to the router, we need to make sure the encryption on the router.
Access the router setup screen, check the IP address first of the computer.
Open IE type there 192.168.1.1 username is blank and password is admin.
once it is on the setup screen checked the wireless tab and look for wireless security, verify it and try to connect again.
in your wireless computer, right click wireless connection and go to view available wireless network, try to connect - input the network key if in case it is not asking you for it, click the changed the order of the preferred networks and then removed all the preferred networks there, then try to connect again and you will now be asked for a network try to connect and you should be connected then.
Jun 24, 2009 | Linksys WRT160N Wireless Router
I am trying to connectmy basement computer to my upstairs office
Your wireless router issues IP address to your computers.
Your wireless card on your downstairs computer needs to be configured to communicate with the router, ie WEP or WAP encryption - if your have enabled it, SSID etc.
To configure the TCP/IP settings on your downstairs computer -
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on Properties.
Then in "This connection uses the following items, scroll down to Internet Protocol (TCP/IP) and click on Properties. Under the General Tab make sure Obtain an IP address automatically and Obtain DNS server address automatically are selected. Click OK.
If you do not see TCP/IP in the Wireless Network Connection then click on the install button and then install the TCP/IP driver.
IF TCP/IP is OK then before you do the following, turn off or disconnect the power to your wireless router, wait for 1 minute before connecting the power again. Wait till the LED lights indicate that it is on line again and the wireless is on then :-
Click on Start - Control Panel - then Network Connections - then right click on your Wireless Network connection - click on View Available Wireless Networks
Do you see your wireless network (ie. your wireless router)?
If so click on your wireless router and then click Connect.
You can also click on Repair to try to reconnect to your wireless router.
Let me know if it works.
Mar 04, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Can only connect 1 computer to router
You might need to check if your laptop is able to get a valid IP address when connected wirelessly to the router. You can go to the Control Panel then click on network connections and look for wireless network connection. Right click the wireless network connection then click properties. Click the support tab and there you will see the IP address. You should not be getting 169.254.x.x. Where X represents numbers.
An IP address is very important. Make sure you're getting a correct IP address and it should be the IP address provided by your router. Without a valid IP address, you won't be able to get onlinwe. Your wireless connection can tell you that its connected eventhough its not getting a valid IP address.
Feb 07, 2009 | NetGear DG834 Router
Wireless Router
If you clicked repair connection at anytime, you need to reset the router, by way of a reset button on the rear or front, go to your wired network card properties in control panel>network connections, click TCP/IP line, click properties again and select obtain ip address automatically. At this point you can run the setup wizard again if you wish using the rj45 cable You should set up the router using an RJ45 lan cable which comes with the unit and get into the routers settings by typing it's ip address in your web browser 192.168.0.1. Check that DHCP is set at enabled to give your pc's an automatic ip address. Check that wireless is also enabled and save any changed settings. Go to the properties of your pc's wireless adapter in control panel network connections and on its TCP/IP line check that obtain ip address automatically is ticked. when you have set up your wireless connection and the router is set up correctly, disconnect the rj45 cable and if neccassary dissable the wired network card so as the router looks for your wireless adapter and gives it an ip address. When a connection is found by your wireless connection you need to go into the router again and set up your wireless security, using whatever method you choose eg WEP or WPA PSK. You need to select the numbers and letters mixture pass phrase that you use for encyption and use the same numbers in the wireless adapter when it asks for the passkey no., you should then be able to connect again securely.
Sep 10, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Sony PlayStation Portable (PSP) Console Logo
42 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
