Question about Konica Minolta bizhub 350 All-In-One Laser Printer
Printer saying 'out of memory'
Im trying to print but keeps coming up saying 'out of memory' how do i fix this? thanks
  • 167 Answers
If it is giving this message at your computer then it is not the KM.
If it is giving this message at the KM panel AFTER it has left your computer then the KM needs a HArd drive added.
Try sending fewer pages, if it is a PDF then try reducing the file size.
Is the "spool" option on at the Computer?
Posted on Feb 17, 2009
How to fix CM2320 MFP PAPER JAM
if you don't find nothing inside printer and you are SURE there is no paper inside machine try to clean or replace pickup roller, if you wanna be sure about that try to print from Try1, if it work the problem is in try 2
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
Im trying to print important documents, when i print its says error printing, yet i was able to print the test page and align my carterigdes , what is going on?, thank you my kind sir
un install and re innstall the disk with the app, and drivers for your operating system. test page just comes from the printer, it's not seeing the document
Sep 01, 2011 | HP PhotoSmart C4480 All-in-One Printer ...
Our printer keeps saying printhead and wont print ofcourse. so ive changed the printhead with a new one and it printed just fine for a day til they turned it off and returned the next day to find the same...
im not familiar with that model but ill say the platen roller is probably fine in your case. im going to ask is this a direct thermal or thermal transfer printer?? transfer means uses a ribbon?? if not its possible your thermal paper isnt any good?? it does have a shelf life and gets to the point where print might be there but quite faded if the paper is old. one more question...does this printhead have an ohms value on its label?? if it does and so will the new one and that value might need to be set in the printer itself. like i say im not that familiar with your model im used to large industrial tabletops and print engines on applicators
Aug 01, 2017 | Zebra 105Se Thermal Printer
Printer will not print. keeps saying
first you pl. check the dimm/sdram module is seated properly in its place otherwise insert new one
Feb 05, 2010 | HP LaserJet P3005n Printer
Im trying to delete a pending which will not go
You can use the following command to stop spooler at DOS prompt.
net stop spooler
When the spoller stops, you can open the printer dialog and try to delete it. When it gets deleted, go to DOS and type:
net start spooler
Hopefully, this will solve your problem
Nov 21, 2009 | Office Equipment & Supplies
Im having same problem when trying to print. its
it may be a driver problem try to update your computer or reinstall vista again
May 14, 2009 | OKI C5100n Laser Printer
Printer Spooler service!
1) Click the Star>Run, type in "Services.msc" in the Run dialog box.
2) A services window popup, find the service name "Print Spooler", double it and change the Service Status to "Start".
Now u can use your printer now.
YBC (/\)
Aug 04, 2008 | HP LaserJet 1018 Printer
My lexmark x2480 won't print since i installed new cartridge
try to reinstall programme for it or check the cable between com and printer.
May 26, 2008 | Lexmark All-in-One Printer, Scanner &...
Msg:supply rec paper
Ya, I had that same problem too; I was printing something that was over printing margins, and then i had the message "supply rec. paper......" on the lcd screen. I ended up fixing the problem by clearing/canceling all the documents i was printing on my computer, and clearing/canceling all the documents saved inside the MEMORY OF THE PRINTER (note the green light with the "memory, in use" which means it's probably still trying to print the document that's too big, so it wont print anything else). (<--- not sure if that was your problem, but it was mine)
Anyways, to clear the memory inside the printer, i pressed the "status monitor" button located to the left of the "B&W start" button, and then i scrolled over to "print status, select job to cancel" and canceled all jobs, and then once i canceled all jobs, the alarm disappeared, and it was fixed XD
Feb 13, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Konica Minolta bizhub 350 All-In-One Laser Printer Logo
232 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
