Question about Panasonic PT-53WX52 53" Rear Projection Television
My picture is grainy and colors are distorted.Do I need tube?
Is this common and is it correctable? TV works fine other than than this.
  • 1 more comment
  • tlehman Feb 11, 2009
    I have unplugged and restarted the TV several times and no difference. Picture is still grainy and reds and greens are out of sequence.
    Sound is fine.
  • tlehman Feb 12, 2009
    I have unplugged and restarted the TV and no difference in picture. Still gainy and green and reds are distorted. Any other suggestions?
    Do the convergence tubes need replacing periodically?
  • tlehman Feb 14, 2009
    Still having problems with my grainy picture and reds and green colors. Tried resetting and surge filter and still no luck.
  • Panasonic Master
  • 5,138 Answers
My Advice to you is to take this set to a TV Repair Shop and Let Them Quote a repair Cost to fix this problem Trust Me on this one I my self do not care to work on these Sets After Replacing convergence ICs To Enter Service Menu / For Realinement on convergence is not an easy job , But First Clean all 3 Tube lenses,and mirror Then adjust contast,and sharpnest and if you can solder resolder flyback transfomer and all of the convergence yoke Plugins on power board CK high voltage capacitor it is blue 2Kv feeds off the hori output Transistor.
Posted on Feb 14, 2009
  • 142 Answers
A grainy picture on an HDTV is caused by an anolog signal coming through a Digital converted tv, such as yur HDTV. You need an HD signal, or HD converter box. PERIOD. There is nothing wrong with your set. Contact your cable company and rent or buy a Digital/HD converter.
You did a great job explaining the problem (grainy or rice grain) is what we use in the cable field for this problem.
Please remember to rate this solution.
    President:
  • 2,559 Answers
It is a signal issue,Check the connections to and from the cable box,tv,and any other device that the signal goes through prior to entering the TV
Posted on Feb 12, 2009
    Sergeant:
  • 250 Answers
Reception problems, fix your antenna. if still has the same problems, try adjusting tuning. The problem could most likely be with the set's STK ICs. The soldering comes loose, sometimes actually coming loose INSIDE the IC, where it solders in there! Heat/cold over and over translates into expand/contract over and over.
Just resoldering the legs usually does the trick, but if you have continued to use your set while hurt, the ICs may eventually go out completely and need replacement. Resoldering them in before that time usually saves the ICs and never needs to be done again.
There will be either one or two of them, and they will be heavily heat sunk - as in mounted on a big heat sink, with vertical fins. That's all I can say without seeing the unit in front of me, open. They usually face towards the front, are in the middle of the middle board, and the name of the ICs is covered by a screw-on plate, which has to be removed for replacement.
Be generous with the heat sink compound when replacing the ICs, get the old stuff off the heat sink with a putty knife if it has dried out.
To check whether you need to replace the ICs or not, with the unit on if you tap on the heat sink with something long and not conductive, like a stick, and it affects your conv - be VERY careful, this has to be done while the unit is on - you can probably get by with just resoldering the legs. If not and it just won't converge, IC replacement will be necessary. I recommend replacing both if you replace one, because next week the other one may go out and you may have to get in and out of the unit all over again.
Best way is usually to remove the entire light box, tho sometimes it's best to remove just the board, other times you can prop the whole board up and do the resoldering on your back.
The name of the STK ICs is STK392-570. You can Go to a website "bluestar-online.com" and find them for sale.
Posted on Feb 11, 2009
  • 6,784 Answers
Hi there, this kind of build will have this problem due to the rear projection set up. sometimes the lamps and convergence board can get out of sink and cause blur and grainy picture. i would use the DVI or rgb/hd connections. this may fix the picture quality a bit. im sure the convergence board is going out at this time so, i suggest you to prepare for the replacement of this board. you can also improve the visual look by ordering a replacement screen from the manufacture. the screen is bombarded by hot rays during long term viewing that can produce a cloud on the back side of your projection screen.
  • 4,234 Answers
No reset will address this problem. If the distortion appears like a 3-D picture, the problem is in the convergence circuit. This could be as simple as poor solder connections or a defective IC. Can you solder? If so, you can fix this yourself. Be aware that there are potentially dangerous high voltages present even when the set is unplugged.
Update this if you wish to attempt the repair and I will provide additional details and instructions.
Thanks,
Dan
  • 10,594 Answers
TV has grainy picture on Cable / Antenna or AV input like DVD Player?
  • Panasonic Master
  • 19,396 Answers
Try first changing the vido cable, if the problem is not the cable ift may be a fault, in that case it may be expensive to fix.
  • Ginko
    Ginko Feb 12, 2009
    The tubes are CRTs, not convergence tubes. The convergence is regulated by convergence Ics, here is explained: Fixing Convergence problems in RPTV's
    However convergence fault does not cause graini picture, that is associated to bad signal, tuner board faults, digital control faults, light engine faults.
  • 679 Answers
Unplug the unit for 10 mins and restart.
hope this works
  • rockfixya
    rockfixya Feb 12, 2009
    OK... Try swaping the cable input wire, and also check color schime on TV might be you changed some of color settings.
    If all is done than there is a problem with Convergence IC, it needs repair.
    Thanks
    Master:
  • 848 Answers
Hard reset - Just unplug the power cord leave the unit disconnected for 30 minutes and plug the power chord to the unit and it resets the unit ......problem of color wheel
    Top Expert:
  • Panasonic Master
  • 77,169 Answers
Do u have a filtered surge protector to plug the TV into? if not get one, allot of times a Dirty AC signal can cause this, had this problem with my own TV.
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Cc color distortion bows at too and bottom
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 05, 2011 | Mitsubishi WS-55809 55" Rear Projection...
I have some distored blue color across the screen
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 15, 2010 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 43FDX15B distorted picture. The top of screen displays a half circle cirle and the image is distorted within the half circle. The same at the bottom of the screen. The middle of the screen is fine....
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Mar 11, 2010 | Hitachi 43FDX15B 43" Rear Projection...
KP-57HW40 rear projection TV colors out of alignment and warped
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 04, 2010 | Sony KP-57HW40 57" Rear Projection...
The picture projects the image with concave lines on the edges. I'll explain further: somehow the picture is distorted in a way that bends the four edges of the picture in a curved-concave manner so that...
*Screen Looks 3-D
*Colors wont align
Nov 26, 2009 | Mitsubishi VS-55705 55" Rear Projection...
Green screen and distorted picture sound is good but no picture
It must be connected with the color circuit of your tv, a board connected to back end of the tube. Could be dust, cob web or carbon deposit shorting a transistor. Popping noise if loud enough can be attributed to high voltage circuit fault and picture tube.
Have it service by a qualified person.
Apr 04, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Rolling and distorted picture
*Screen Looks 3-D
*Colors wont align
Dec 02, 2008 | Mitsubishi VS-60707 60" Rear Projection...
TV Color Distortion
Hello Sherry:
you will need to hav th unit repaired it ounds like there is a problem with your small signal board.
The Slash
Aug 17, 2008 | Sony FWD50PX2/S 50 in. Plasma Television
Green Shadow
The most common problem for this complaint is contaminated coolant for the picture tubes. If you look directly into the three picture tubes you will probably see a haze in the blue one. This is fairly common but requires a knowledgeable service man to take care of.
Dec 31, 2007 | Philips 50P8341 50" Rear Projection...
Panasonic PT-53WX52 53" Rear Projection Television Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
