Question about Maytag MGR6772BDS Gemini Gas Kitchen Range
Gemini electric oven; glass top cracked
I have gemini electric; glasstop seriously cracked; can it be replaced? How much would it cost?
    President:
  • 1,314 Answers
Yes its not too difficult check your owners manuel as most ceramic cook tops are under extended warrenties from 5-10 years
Posted on Feb 11, 2009
After a power failure, the clock face went out and there is no power to the duel ovens on a Maytag gemini electric oven. All four burners on the glass flat top work though.
try turning power off at electrical main switchboard for a minute, then back on. reset clock and see how it goes.
otherwise > call the repair man.
Oct 20, 2013 | Maytag Gemini Electric Double Oven Range...
F1-1 reading on control board
F1:-1 may appear on your Gemini oven range for various reasons, but the meaning is always the same. The error means that the display relay control board thinks your temperature on your upper double oven range is running away and getting too hot. To fix the error F1-1, check the wire harness between your oven sensor and your control board to make sure the wires are secure and the connections are good. Pull the oven out and remove the back panel on the oven to check the wires connections. If the connections and wires check good, disconnect the wire connection to the oven sensor and check the resistance of the sensor. The resistance should be 1100 ohm at standard room temperature. If the sensor is not good you need to replace it, and if the sensor checks within range replace the display control board. Here is the part to order.
All parts come with a 365 day, any part, any reason return policy.
Feb 09, 2013 | Maytag MER6772 Gemini Electric Kitchen...
I have a maytag gemini double oven stove and I broke the glass cook top, can I order another glass top and replace it myself?
yes you can order it,it's around 200 dollars,and it's a little work to do this,when you call your parts store give them the full model number off of the machine,the part number i found is 5706X371-09 and it's around 200 dollars but 10 models came up and this seems to match all of them but you might have a different color so check when you buy it.
Apr 18, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Used self cleaning feature of my electric Maytag Gemini stove. Lower oven glass window in door basiciall cracked into thousnads of small pieces. What did I do wrong and how do I get the stove fixed?
You didn't necessarily do anything wrong. The glass may have been banged at some point and weakened it. The only thing you can do is call an appliance parts store with your model and serial numbers and get them to look up the price and availabilty of the lower oven, inner glass. If you can get the door off the range, and it should come off, it may be more reasonable for you to take the door into the shop where you ordered the glass and get them to put it in for you.
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Nov 03, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag gemini model MER6770AAB - F1-2 error
Check the sensor for correct ohm reading. If it is good, replace the control. It should read 1143 at 100 degrees
Sep 18, 2009 | Maytag MER6772 Gemini Electric Kitchen...
I broke the glasstop of my stove. Can I replace
http://www.partselect.com/Maytag-Stove-Parts.htm
just typ in your model number, and find the part you want on the diagram. you can purchase it through them, too.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Display Malfunction
Hello murfraven,
Welcome,
You said, you went to set the timer while baking a pizza and I got a "set or en" on the display of my Maytag Gemini Ceramic Top electric oven.
How old is the range?
And the model number?
Threat it like an error code.
This can reset the system.
Turn the breaker off to cut the power for 5 minutes.
Then restart the breaker and try the range.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
If this does not remedy the problem, then the switch itself is bad.
Let me know how it works out.
Huuum, Please remember to leave a rating
Oct 10, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MGR6772BDS Gemini Gas Kitchen Range Logo
297 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
