I have an Eiki EIP 2600 and it says computer not reg.
I think it's hooked up properly but when i put input on computer and expect the computer screen to project I simply see a black screen and in the top corner it says "compuer not reg"
loosen all the screws from the bottom ( one is in the middle) and two at the back ( edge)
press the grill on exhaust fans side near the heat warning mark.Lift carefully the rear and turn towards the lens side, BUT BE CAREFULL that some points of the upper cover will not scrape of some smd parts from the mainboard !!
this model has a firmware issue, an update is necessary to get the lamp timer reset option. This is a expert job, you need the right image file and DLP composer software V4.2 Lite.
inside there is a thermal fuse, that might be activated, because the cooling of the lamp did not happen after the power surge.
You need to remove the upper cabinet to reach, but do this very carefully !!
Hello, I couldn't find any remotes available for this projector.
Try contacting Eiki directly with the form on the page below
Click here:http://www.eiki.com/ContactForm.aspx
Try cleaning the IR port on the projector (and the remote itself). These can get enough of a dust layer build up that they can't "see" the infrared signal being sent.
