Question about ASUS P5P800-VM Motherboard
My netbook shut down without warning
My netbook shut down quickly without warning after i turn it on (it lasts between 30 seconds and 2 minute, randomly). It happens even when I get into bios setting. transfer files, turned off wireless connection...
Before this problem happened, I download Windows live Messenger, I clicked windows live family safety, and it led to installation which I wasn't intended to. after installed live family safety, I was so annoyed by the pop up warnings every 10 seconds at down right corner of my screen, since it gave no choice to stop it and you can remove it, I thought it was a virus. so I searched google and found a software to remove it, this software seemed did not solved problem, so I uninstalled it and restarted my net book. then the problem happened.
my Acer aspire one netbook using window xp, and it had no problem since I brought it 5 months ago. I tried both AC power and battery power, the problem still occurs.
Is there anyway to fix this problem?
  • 1 more comment
  • lmvcnn Feb 11, 2009
    Hi ashish13 and rtrahan, thank you both for your reply and help.
     After a good sleep with the problem carried in my mind. I recalled that I did drop a bit water into keyboard yesterday. so I set my Acer netbook under a househood heater fan, facing the keyboard to the fan, in less than five minutes, the problem disappeared.
  • ashish13
    ashish13 May 11, 2010
    it aint cuz of any softwares cuz then system would work in Bios without any hitches... seems there is some hardware incompatibilities happenin... try restoring all bios features to default... will have to do so quickly before the restart though.....
  • Randall  Trahan
    Randall Trahan May 11, 2010
    Well its not on long enough to overheat so it can't be a hardware..just for giggles can you load that software back, the one you uninstalled and see if the Acer does not shut down..we'll start there...
  • 741 Answers
Could you rate this also with 3 stars as we never really got to the problem and the other expert got 3 stars..thanks
Posted on Feb 11, 2009
  • 1,602 Answers
GO INTO THE THE PROGRAM AND DELETE ALL PROGRAM THAT ARE BOUNDLED IN THE PACKAGE AND REMOVE THEM UNTIL YOU RESOLVE THE ISSUES. IT MAY BE TAKING MORE POWER OR JUICE TO RUN THE ONE PROGRAM FOR YOUR CPU TO HANDLE ALL THE WORK
DID YOU NOTICE A DROP IN THE SYSTEMS PERFORMANCE AFTER INSTALLING THIS PROGRAM.
ROD
Nuvico nvjv 4000 beeps and shuts off
sometimes these will go into an automatic sleep mode and will restart once you power it down and restart..
Jan 19, 2014 | Nuvico NVJV-4000N Video Recorder
Shuts down immediatley after booting up
I can assume from your description and this "click" sound that you are facing an HDD problem. I would suggest downloading Hiren's BootCD from this link. Burn the content on a disk and boot up from it. Then start some of the HDD tests like HDD Regenerator and examine the results.I hope this helps!
Nov 20, 2011 | Acer Aspire One Netbook
When i turn on my laptop,the fan just run for a while then stop and my laptop become blank like force shut down
Power drain would be a better solution in this case.first shut down the comp.unplug the charger. remove the batteryand after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer
Oct 23, 2011 | Lenovo IdeaPad S10-2 Netbook
My 1989 f350 duelly starts in am and dies quickly bought coil and ecm cap rotor and backfires and shakes and dies any ideas.i was thinking distributor or fuel pump please help
If you spray starting fluid in the air intake, does it stay running? I would go to harber freight and get a cheap fuel pressure tester and hook it into the fuel line. It hsould be about 40 psi, and hold for about 30 minutes after shut down without bleeding down too much, like 5 psi.
Try this too. Turn key to ON, wait 5 seconds for the pump to shut off. Then turn key off and listen for the realy to "Cclick" under the dash (about 10 seconds). Repeat this. Then start engine. This primes the lines & injectors if you are getting bleed down due to a bad check valve in the fuel pump.
report resuts. pleasre rate assistance.
Aug 12, 2011 | 1989 Ford F 350
Netbook gets stuck "cycling" between shutdown and restart
go to the powermanagement in the control panel. In it check the settings to turn off system when i press, or shutdown the pc after 30 min change it to never, and turn harddisk off to never. and remove the system from hibernation
Apr 19, 2010 | ASUS Eee PC 1000HE Netbook
Trying to reset ps 2 to factory
Hello :
1: Remove the battery from the left side of the PSP while it is still onThe unit will power down instantly. Wait ten seconds and then replace the battery.
2: Press both clear shoulder buttons at the top of the PSP and keep them held while the PSP reboots. A "Recovery" mode will be initiated.
3: Press down on the control pad to locate a "recovery" folder. This will contain all of your PSP content, including games, music, videos and podcasts that are saved on the device. Highlight this folder and press the "X" button to begin reinstalling your content.
Warnings :
If you would like to reset your PSP while it is working normally, you can do so by going to the Settings menu and selecting "System Reset." This will get rid of all your content and restore the PSP to factory settings (and subsequently remove all of your content.)
Or try this for hard resetting :
1: Locate your Power button on your PSP. Push the power button up for 10 seconds.
2: The PSP will and should shut off. Leave the PSP off for 30 seconds.
3: Turn your PSP back on by flicking the power button up very quickly. If it doesn't turn on, try pushing the power button forward very quickly again. (sometimes you have to do it 2-3 times)
4: Your PSP should be working now. If not, then you may have a firmware problem.
Warning:
Do not have your PSP plugged into a power supply.
If your PSP doesn't turn off after 10 seconds (of power button being help up) then remove your battery and wait 30 seconds, and then replace
good luck .
please don't forget to rate !
Apr 05, 2010 | Sony PlayStation Portable (PSP) Console
Dell Vostro 200 shuts down with little warning, maybe 30 seconds warning, then just restarts, has been happening about every 24 hours or so for the last week, but today is happening every 20 minutes The...
What kind of warning do you get? i would update the BIOS from dell.com. also, get rid of Vista and get Windows 7. apart from that this could also be a motherboard issue.
Apr 01, 2010 | Dell Vostro 1500 Notebook
LEXUS LS 2004 Maint Reqd (Master warning light) how I can switch off after change the oil engine?
You can disconnect your battery for 15 minutes or pull the fuse for an ECM or PCM fuse, but the best way is to visit any local repair shop. Most shops will have a universal Check Engine Light Code Reader that can quickly and safely reset check engine light trouble codes. It should take about 30 seconds.
Ask your local service center if they could reset the check engine light with a Check Engine Light Code Reader.
Dec 14, 2009 | 2004 Lexus LS 430
How do i access the processor fan for hp pavilion dv5000 because it gets extremely hot in the top right corner, then shuts down. and the fan only runs for like 2 minutes every 30 minutes
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
AND
With the ear bud clean the vents of the fan and check whether it is happening again. And if it is happening again do the bios update of the computer from the hp.com website and check.
Oct 28, 2009 | HP Computers & Internet
Sudden Shutdown
Hi, I am Sanja and will try to help you.
Try to remove battery from your motherboard, and power cable from computer case. Leave it for about minute, and then return battery, power cable and try to turn on the PC.
You should have no trouble in identifying battery, it is pretty much standard, if you have more questions please do post them
Regards, Sanja.
Sep 15, 2008 | ASUS P5P800-VM Motherboard
ASUS P5P800-VM Motherboard Logo
1,790 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
