Question about IBM ThinkPad T23 2647 Notebook
Ibm laptop t23
Unit turns on but fan is running and over the key board theres a lite on with a circle lit with a z in the center ? wat is that unit worked but took a slite band can u tell me wat 2 do?
  • Anonymous May 02, 2009
    Doesn't work sir .
  • Dan rogers
    Dan rogers May 11, 2010
    That is the sleep button. If you press the sleep button or the power button it sholud "wake up" your computer so you can use it
  • 131 Answers
Your laptop is in sleep mode. Hence the z. Push your power button for 5 seconds, and the unit should turn off, and be able to boot properly.
Posted on Feb 12, 2009
Forgot my password to power on my ibm t23 what can i do ?
If a BIOS or HD lock password you are out of luck.
BIOS password means replacement of the system board. HD password requires replacement of the HD and reinstallation of all software on new drive.
This is a security feature so no one can steal laptops and try to use or sell it.
Feb 16, 2010 | IBM ThinkPad T23 Notebook
How can i clean the keys of an ibm thinkpad T23
1. Purchase a can of compressed air (Walmart) 2. Hold laptop upside down. 3. Spray the compressed air at the keys starting at one end. 4. Keep moving the flow of air from one end of the keyboard to the other in sweeping motion. 5. This should clear out any trapped debris. 6. Repeat if necessary.
Nov 06, 2009 | IBM ThinkPad T23 2647 Notebook
Ibm thinkpad t23 shutting off after 10 minutes or so
Your CPU is overheating and the solution is a laptop cooling pad which will save you the cost of another motherboard.
Apr 13, 2009 | IBM ThinkPad T23 2647 Notebook
When computer is turned on screen stays black and fan races fast
If you put it in another T23, Windows will recognize the hardware change and ask you to re-activate Windows. Microsoft may or may not require you to pay for Windows again.
Mar 16, 2009 | IBM ThinkPad T23 Notebook
T23 IBM will not operate on battery power & won't charge battery.
The battery has likely been charged one too many times and will no longer hold a charge. Buy a new battery.
Mar 08, 2009 | IBM ThinkPad T23 2647 Notebook
My ibm thinkpad t23 needs a new cpu fan which i have but cant work out how to get at it
Go to this link: http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-4UYM3F. On that page is a PDF file which should cover your model. Look at the section called "Removing and replacing a FRU" (Field Replaceable Unit). Look at the one for fan assembly removal. It references other sections that are necessary to get the fan out. When done, just reverse the steps. If you're not comfortable working with small parts, have someone else do it. It's just like working on a desktop, only smaller, more delicate, and there's no consistency between manufacturers.
Jan 17, 2009 | IBM ThinkPad T23 2647 Notebook
Monitor is blank when we turn the computer on.
Maybe not. Find the FN key. It is usually BLUE in color
Then look on TOP row of Computer keyb (or all over) and find CRT/LCD.
Press the FN and that key and your screen should come back. You accidentally sw. it to CRT (outside, external monitor)
Jan 14, 2009 | IBM ThinkPad T23 2647 Notebook
T23 fan error
This is a commin IBM issue fans going Bad ... to try and free it if it's just dust you can actually blow into the vent with compressed air and free up the Fan ... The IBM T series all check fan before powering up.
The replacement is not too difficult to do.
The safest air is the can type to blow in there.
LB
Good Luck
Oct 29, 2008 | IBM ThinkPad T23 2647 Notebook
Fan turns on and off rapidly
The fan cycling problem on the T23 series usually indicates a loose solder or missing inductor which is usually on the underside beneath the PCMCIA slot. If you replaced the mobo yourself you may have flexed what is a weak solder joint loose - you will need to pull the board and resolder this or have someone else do this for you. You can sometimes get the laptop to start by flexing the assembled laptop gently around the PCMCIA slot and if so then that almost always means an inductor problem. You can find some photos by googling (images) "T23 mobo" or "T23 motherboard".
Feb 19, 2008 | IBM ThinkPad T23 2647 Notebook
IBM T23 OPERATORS MANUAL
use the following link to get adobe reader (free) to read the manuals
Click "Get Adobe Reader"
http://www.adobe.com
the following link will allow you to detemine your product number
http://www-307.ibm.com/pc/support/site.wss/MIGR-49QTT6.html#hp
That product number will allow you to access manuals and software with this link
http://www-307.ibm.com/pc/support/site.wss/homeLenovo.do?country=us
There are links in the center and in the bar on the left
Dec 24, 2007 | Lenovo ThinkPad T23 2647 Notebook
IBM ThinkPad T23 2647 Notebook Logo
183 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
