Question about Mitsubishi WS-55511 55" Rear Projection Television
PIP WILL NOT GO AWAY
I CAN RUN THROUGH ALL OF THE PIP INPUTS AND CHANGE THE CHANNELS IN PIP, BUT I CAN NOT GET THE PIP TO GO AWAY VIA THE REMOTE.
If you are using a cable box remote and the actual tv remote it is possible that both remotes have this option. check both remotes....
Posted on Feb 11, 2009
Remote will not change channels
If you are using the original remote, it has failed.
Sep 26, 2017 | Pioneer PDP-5080HD 50 in. Plasma HDTV
I am not sure how to use the PIP feature? I have read it has something to do with the HDMI?
You have to have two inputs going at once (a dvd and a cable box or something) in order to see two pictures. If you want two different cable channels on PIP you usually have to do that on the cable box remote
Mar 01, 2011 | Televison & Video
Digitor 4321 TV - can't change inputs or channels without remote
I purchased a new original remote from **** smiths, Fremantle on 6 july 2010. $15.00 part numberG4321 0F 0004
Jul 13, 2009 | Televison & Video
Vizio remote
The remotes for the TV and Direct TV box are universal remotes that can operate very basic functions for whatever else they are programmed to control. If you can program the TVs remote to operate the Direct TV box it will basically only control power and channel. Maybe something else, but not much. The same goes for the Direct TV remote. It will control basic functions on the TV; power, channel & volume. Best bet would be to purchase a universal remote that can learn functions from the original or just keep both remotes available by the TV.
PIP (Picture In Picture) - Your television should have the capability because it has two built in tuners. It can show two channels at the same time or show one channel and one video source (whatever is connected to the audio/video inputs). However, because you are using DTV (Direct TV) you are very limited because you are not using the built in tuners on your television. You should be able to see one picture from the DTV channel and one from lets say your DVD player. If your DTV box has two tuners built in then you should have the PIP capabilities from your DTV and not your television. I'm guessing your DTV is a single tuner (one satellite cable to your box). If you want to watch two different channels you'll need to either upgrade your box or attach another box to your television.
Option: you could also connect an antenna to your television this way you can use the PIP function. Obviously you'll only be able to view whatever local stations you can get with the antenna. Depending on where you live you might or might not have a lot of channels to choose from.
Apr 19, 2009 | Vizio L32 32 in. LCD HDTV
Zenith 27" HDTV second antenna input not accessible on TV/remote
Hi and welcome to FixYa,
Pls verify if your particular model/versions has a PIP feature. To my understanding, the 2nd Antenna/Cable IN goes to a 2nd tuner that is primarily used for the PIP (picture in picture) mode. This mode would allow you to watch simultaneously 2 different TV channels.
Pls post back. Good luck and thank you for using FixYa.
Feb 10, 2009 | Zenith C27V36 27" TV
How do you get to diffrent tv station to show at the same time (pip)
If your TV has built-in Duel Tuner then you can see 2nd picture in pip. In remote you have channel up-down button for main picture and another set of channel up-down for pip function to change channels in pip.
Sep 28, 2008 | Televison & Video
Pip pictture doesn t turn off
I had the same problem many times, and I don't have the original remote. Go into your menu options and select Auto-Program. It will run through all your channels, but when it is done, PIP will be off !! I have PIP!
Jun 28, 2008 | Televison & Video
Picture in picture
i am not familiar with this model, but on most sets you will have a button on the remote to activate pip, when active you should be able to adjust channels on the small display with the remote and cycle through inputs. depending on the tv you will either have 2 inputs for your cable/sat/tv feed, or will have 1 with a dual tuner.
check the connections in the back for a second cable input, or hook up a dvd/vcr/game console/etc to test the pip.
start dvd or tape playing, press pip button to display the mini-screen, then use the tv/vcr or input button to cycle through the modes and see if one pops up. most tvs that have pip will also have a swap button on the remote, it may be labeled with text, or it may just look like one screen overlaying another, press that one to swap between displays.
hope this helps,
trin
Nov 16, 2007 | Samsung PCJ522R 52" Rear Projection...
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Mitsubishi WS-55511 55" Rear Projection Television Logo
141 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
