Question about Kenmore 75051 Wall/Window Air Conditioner
Air con not cooling
My Kenmore air con (bought in 2005) is no longer cooling efficiently.  Is there anything I can check before calling in the repair person?  Is it even worth calling for repairs?  I have a window unit in a high rise so I am unable to wash the coils or take it out.
  • 537 Answers
If you can vacuum out the filter or wash it out that might help.
Check this web site:
http://www.hometips.com/home_probsolver/hps06/02_ac_andheatpumps/hps_ac02.html
Posted on Feb 11, 2009
Our wall mounted air con is set at 16 degrees but it is not cooling the house at this temp. Could it be the thermostat
most wall mounted ac units are designed to only cool a room, not a house
close all the doors to the room along with all windows
generally a 3kw unit (32,000btu )will cool a room 12ft X 12 ft X 9 ft quickly but anything bigger, the time that is taken to bring the temp down gets longer and longer depending on the setting and 16 C is far too low
Dec 07, 2016 | Heating & Cooling
Air-con faulty
sounds like an electrical problem check all fuses and ac clutch relay
Jul 20, 2013 | 2005 Mercedes-Benz Sprinter 311CDI
My Audi 2005 Air con system will not blow cold air is this anything to do with the vent at the front of the vehicle that creates an airflow
Well, I don't know. I would have to see the car.
Generally, as long as air can flow thru the condenser and radiator, the ac system can produce cold air.
As for the interior, you normally pull in outside air and cool or heat it, but you can also recirculate inside air which would close off the outside fresh air intake for the cabin.
Jul 01, 2012 | 2005 Audi A4
The unit is only 4 months old. bought from lowes in warsaw in.they dont have a repair or cant replace it out of stock, contaced custermer services . she gave two fridgidair repaire places ,they dont...
Sears sells fridgidair parts. Go to sears .com under there appliance parts. You should Find the part you need. You might want to check to make sure the sensing bulb for the Thermostat is in front of the cooling coil just behind your air filter. If it not located properly It can't properly sense the air temp. And may not shut down .
Aug 28, 2011 | Frigidaire FRA256ST2 WallWindow Air...
My air-con is not as cold as before. I tried to lower the temperature, but when i try setting the temperature to 18 degrees, the remote just shows 18 degrees for like 5 seconds before going back to 31...
These is because you have not service your air-con for a long time. The cooling fins are clotted with dirt & dusts accumulated for a long period of time, and the water vapour caught between the cooling fins turn into ice when you set lower the temperture for the air-con. Moreover cool air from the blower/fan cannot pass thru', the cooling fins to regulate the cool air into your room.
You have to get the professionals to do a service on your air-con.
Hope it clarify your predicaments.
Jun 15, 2011 | Sanyo Heating & Cooling
I have an old Kelvinator air conditioning. Not sure what the model is since I have lost the manual, but from the remote control I can see some code looking like the model number: 6711A20012M. A few weeks...
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
Dec 25, 2010 | Heating & Cooling
I HAVE A AN ISSUE WITH PORTABLE AC IT DOESN'T BLOW COOL AIR
dear sir
please make sure first your air con,s compressor is working if it, working and it,s not getting cold then it can be low gas problem or if compressor is not working then please check the thermostat settings and make tempreture correct and setting on cool mode
then i hope if it,s only normal problem then your air con will work again .
after that if not get cold then contact to air con technician for repair it (it,s need to repair and only air con special maintenance person can do it)
thank you
hope answer the question
please vote!
Sep 24, 2010 | Amcor A12000E Nanomax Portable Air...
Air con fan works but no cool air the compressor doesn't appear to start
It may need regassing, air con runs out after a while as its 2005 it most likely needs to be regassed/refilled!
Jan 14, 2010 | 2005 Ford Futura
Air condition won't cool.fan blows warm air.
sounds like the air-con gas is low switch on air-con a nd check to see if the compressor clutch is pulling in if not reove h/p dust cap on the aircon pipe press schroder valve to see if gas escapes if not will need re-gassing even if you get gas out without a pressure gauge it is hard to tell if the right anount of gas is in the system.
Jul 12, 2009 | 2005 Lexus Ls 430
Kenmore 75051 Wall/Window Air Conditioner Logo
221 people viewed this question
Top Kenmore Heating & Cooling Experts
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
