Question about GE Dryers
My dryer will not power on.
It first started to buzz now nothing
  • 979 Answers
You may have either a burned off wire in the back or more than likely it is a bad themal overload switch. It is located under the top of the dryer at or near the drum. Bypass it and see if it runs then. If so, replace it about $20. I am assuming you have checked the breakers. Turn them off and then back on. Check the wiring from the receptacle to the plug to the back of the dryer. I believe however, it is in the thermal switch.
Posted on Feb 11, 2009
Need to know what the unit does, Buzz, nothing? Because if it buzzes it could be a clogged blower or bad motor, its important to know this information.
Please get back to me
Sep 08, 2011 | Maytag PYE2300AY Electric Dryer
When hitting start button, it sometimes buzzes, but fails to start. Can sometimes wait for a little while and try again, and it starts. When it buzzes, it will only buzz for a few seconds and then nothing.
it is either the door switch or start switch, this website will show you how to test both, Good Luck Tim:
Apr 16, 2011 | Whirlpool LER4634J Electric Dryer
My dryer will not start. when i press the start button i hear a faint buzzing sound and nothing happens, the inside of my dryer warms up a little. other then the buzzing sound i hear no noise.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The
Dryer is not Turning
Dryer Repair - The
Jan 31, 2011 | Dryers
220volt dryer; "Performa". Schematic refers to 53-3540 "REL". When push-to-start pressed loud buzz/arc sounds from about 14 inches below switch. Someimes long buzz/arc and unit starts, sometimes a buzz and...
Correct diagnosis is the key. You need to remove the top and the front of the machine. You should be able to see where the arcing has occurred. If you can't see it, you bridge the door switch, remove the belt, and run the machine for 5 seconds, being mindful the elements are going to heat up unless you have a cold run setting.
Because you get a 'buzz' and not movement to the drum, my feeling is that the motor is defective. It has two sets of windings, a start winding and a main winding. The start windings are to get it moving so that the main windings aren't stressed when power is applied, and there is no movement for a second.
The cost of the motor probably means it is beyond economical repair, so time for a new one and its 2 year warranty.
Nov 24, 2017 | Maytag Dryers
Loud buzz when starting, then shutting down after 10 min.
Yes, this sounds like the motor cutting out on thermal lockout.
Apr 10, 2009 | Kenmore 62602 Electric Dryer
Dryer makes a buzzing noise when I push the start switch.
Sounds like a bad motor, The buzzing noise is probably the motor humming then nothing because the thermal over load switch inside the motor opened. Timer will still be energized. Good Luck
The Squirrel
Mar 26, 2009 | Dryers
Whirlpool Dryer (LER7646E) not working
check your power cord and the receptcal if you see any discloring on pronges of your power cord you'll need to replace cord and the receptical it could be shorting out
Dec 13, 2008 | Whirlpool LER7646E Dryer
you have not said anuthing about ohming out the start knob,and have you checked both legs on the power cord are getting 120 volts each?let me know what you find-mike
Sep 09, 2008 | Whirlpool LER4634J Electric Dryer
Amana Dryer won't start
Depending on your interpretation of the 'buzzing' sound compared to mine, I'd say it may be a relay chattering or the motor trying to start up but the windings are beginning to fail. You may want to clean the motor housing from dust etc and make sure that you do that with the power disconnected. Also: with no clothes in teh dryer..try rotating it around and feel for any spots in that rotation that may be binding.. if the drum has excessive restriction while rotating.. the motor may not have enough torque to overcome that and just buzz,,, Hope that helps...
Aug 14, 2008 | Dryers
Dryers Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
