Question about Microsoft Xbox 360 Console
2 left lights flashing.... still
The two left lights on the console started flashing red which i know means its overheating so i bought the cooler attachment and it is still flashing the 2 lights. please help.
  • cmbnoke Feb 12, 2009
    10 min into playing and the 2 red lights appear then the system shuts off
  • mastag Apr 12, 2009
    Same here! i try to play online and i shuts off...but this happened when i just turned it on
    Problem Solver:
  • 6 Answers
Buying cooler attachment is not going to help - it doesn't indicate that it's overheating but it indicates that the Xbox has a proble of 2nd level. To fix it, you have to send it back to Microsoft if you have a varranty, if not you have to buy a new chip replacement set which is aviable on the internet.
Posted on Feb 12, 2009
2 red lights start flashing
Two red lights flashing on the Xbox 360 means that the system is encountering overheating issues. What you can do is to let your console cooldown for about half an hour and you are ready to go. Also, if you are connected to a Hi-definition output and running on 1080p, you might want to downscale it to 720p as the console generates less heat in lower resolution. Hope this helps..
May 12, 2010 | Microsoft Xbox 360 Console
overheated. let it cool of, clean it and place it somewhere cooler.
Mar 20, 2010 | Microsoft Xbox 360 Console
Two red lights left side flashing on the xbox consol do you what what the solution is?
hello,
Two red lights lighting up means that your 360 is overheating... try to move your 360 to a cooler spot. you can also try to vent the heat by pointing a desk fan directly to the console.
I hope this helps.
- HotRatchet
Feb 11, 2010 | Microsoft Xbox 360 Console
XBOX 360 TWO RED LIGHTS FLASH
the two flashing lights is the code for your console overheating make sure nothing is on top of or behind the xbox and make sure it is not in an enclosed space
Sep 20, 2009 | Microsoft Xbox 360 Console
I switch my ps3 on and start to play a game and then sfter about 10 mins it switces itself off and a red light flashes, then the same happens again after i switch it on. could it be overheated?
sure, it can. try cleaning your coolers : turn the on off switch behind the console OFF, then hold the eject button and , HOLDING THE EJECT BUTTON,switch the on off key ON (behind the system). it will clean your coolers.
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
Three rings of death
Your system will need the 3 red light service. The 2 red lights flashing indicates overheating. We can fix this for you if interested email for estimate
xbox360fixer@verizon.net
Thanks
Jan 13, 2009 | Microsoft Xbox 360 Console
What does 2 flashing lights mean on an xbox 360?
The two red flashing lights on the left side of the circle indicate the thermal limit has been reached. (over-heating) Check to see if the fan on the back of the unit is blowing air. There are external fans that can be added to keep the GPU. (Graphics Processing Unit) and CPU (Central Processing Unit) temp down. Keeping the temp down can prevent the dreaded RRD. (Red Ring of Death) Here is link as an example of a cooling fan. http://www.gamerepairparts.com/xbox-360-cooling-.html
Shop around and find one that you like. Remember, when it comes to these computer chips, cooler is safer.
Dec 31, 2008 | Microsoft Xbox 360 Console
3 red lights on xbox360 and screen problems
Hi there!
The three flashing red lights may indicate that there is a hardware problem with your Xbox 360 console. The main thing that causes the 3 red lights to start flashing is because of overheating and as the motherboard within the console takes more heat it actually warps and bends until the solders become loose.
Once this happens you will receive the 3 red lights. Even before you get the 3 red lights you may have noticed your games freezing and this is caused in the same way, by overheating. As the chips take more heat they shut off to prevent lasting damage, although they can only do this a number of times until you get the Xbox 360 3 Red Lights.
To fix the problem you need to stop the level of heat the motherboard takes and you can do this in a number of ways, but it will involve opening up your Xbox and working on it. In addition, you could always send your Xbox back to Microsoft as they are offering free repair for this error, you will just need to wait 3-4 weeks that’s all.
Cheers!
Dec 21, 2008 | Microsoft Xbox 360 Console
X box 360
i put a intercooler and it worked great... i don't know whats wrong with yours? if all the lights are flashing then it overheated
Oct 22, 2008 | Microsoft Xbox 360 Console
3 flashing lights
3 Red Lights Flashing - is a general hardware failure
  • Unplug everything and let it sit for 20 min. Re-connect and try re-starting
  • If these steps do not resolve the behavior, turn the console off, remove the hard drive, and then turn on the console. If the 3x Red LED error light is no longer displayed, turn the console off, re-attach the hard drive, and then turn on the console.
  • Check the lights on the power supply. When you turn on the console, the power supply light should illuminate green even if the three lights on the console flash red.
For more things to try check here
Nov 23, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
117 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
