Question about Canon PIXMA iP4000 InkJet Photo Printer
I need to flip my text to print on a transfer for a t-shirt
I do not have my manuel for the printer and cannot find out how to flip the text.
  • 46 Answers
You want to flip the text? Do you mean you want the text to display 90 degrees from normal portrait mode into landscape?
If so, when you select a document to print a window should pop up with options to select number of copies, etc. Take note of a pull down menu with portrait, and landscape options.
Use landscape to print your job with the text in this mode.
If you want this set as the default option you can set this in your print settings in the computer.
Open your printer settings in control panel, (assuming you use windows) select the printer with right click, and choose properties. There should be an item labelled document preferences. In this you can select a between Portrait and landscape. Hope this helps.
Posted on Feb 11, 2009
How do I do mirror (or reverse) printing for a t-shirt transfer? Thanks.
If you are printing text only, you can create it using wordart in word and then use rotate or flip command to reverse the text.
If you are printing a JPG with text, the easiest way will be to use photoshop to edit the image and add text if desired, then use the mirror utility, The picture and text get reversed and the transfer is printed in reverse to become "positive" when you iron it on the Tshirt.
hope this helps.
Mar 07, 2011 | Canon PIXMA MX870 Wireless Office...
Ihave a canon pixma iP6000D want to mirror image
Download some free software, the "GIMP" (Graphic Image Manipulation Program) from http://www.GIMP.org and use it to "flip" your image.
May 30, 2010 | Canon Pixma iP6000D InkJet Photo Printer
Printing t shirt transfers
I believe that printer does not support this option since it is using toner and toner printer has different technology where it creates electromagnetic reaction to paper itself and toner when printing . What you need is an inkjet printer. You can check Epson products and consumables and Kodak too.
Hope this helps
Apr 28, 2010 | Konica Minolta magicolor 2300DL Laser...
Printing letters from the computer to a iron on
You don't. Once you have completed your design including the text as it should read when the T Shirt is finished you go to print the design. When the printer dialogue appears then you Click Preferences, Properties, Options, or Setup (depending on the program or operating system) then choose the paper type as the T-Shirt Transfer option if you have one setup so that the print image will automatically be reversed when printed, or you choose an option to flip the image horizontally, or print reverse.
Oct 21, 2009 | Dell 924 All-in-One InkJet Printer
How to print mirror image with Cannon Pixma ip2000
  1. Click the Printer and Paper tab.
  2. Under Paper, in the Size box, select Letter.
  3. Click OK.
  4. Do one of the following:
    • If your design is a picture, clip art, or WordArt, flip it horizontally.
    default.aspx?assetid=za790050011033How?
    1. On the Arrange menu, point to Rotate or Flip.
    2. Click Flip Horizontal.
    • If your design includes text in a text box or table, turn it into a picture first, and then flip it horizontally.
    1. Select the text in the text box or table in your design.
    2. On the Edit menu, click Cut.
    3. On the Objects toolbar (toolbar: A bar with buttons and options that you use to carry out commands. To display a toolbar, click Customize on the Tools menu, and then click the Toolbars tab.), click Insert WordArt default.aspx?assetid=za060452451033.
    4. Under Select a WordArt style, click a style, and then click OK.
    5. Press CTRL+V to paste your text into the WordArt Text box.
    6. Format the text, and then click OK.
    7. If necessary, resize the WordArt, or use the WordArt toolbar to format it, and place it in the design.
    8. Select all the objects in the design, including the WordArt.
    9. Click Group Objects default.aspx?assetid=za060447801033.
    10. On the Arrange menu, point to Rotate or Flip, and then click Flip Horizontal.
  5. Print your design on plain paper first to make sure it looks the way you want it to.
  6. Make any adjustments to your design after seeing the test printout.
  7. Make sure thermal t-shirt transfer paper is in the printer.
  8. On the File menu, click Print.
  9. Select the options you want.
  10. Click OK.
Source
Cheers
Jun 20, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Printing dark tshirt transfers - can't override the flipped image
Hello I think I can help you. I Would not use T shirt transfer when you make up your print I would select poster print or any other form that does not automatically reverse the image. The reason your software is designed to do this is on the regular transfer paper your laying the image down on the shirt, so for it to come out right it has to be reversed. With the dark T shirt transfer paper your peeling off the backing and putting the image face up on the T Shirt.
Dec 23, 2008 | Canon i80 InkJet Printer
How do i do a t shirt transfer I cannot seem to "flip" the picture I have a canon 3300
invert and reverse will probably do the same thing.
can be in the printer driver or use a program.
Jul 18, 2008 | Canon Office Equipment & Supplies
Is there a way to print "mirror images" for t-shirt transfers on an MP460 Scanner-Printer-Copier? Jim Woodward 918-286-6947 jimwoodward1943@cox.net
Yes, use your application, such as Photoshop to flip (vertical) the image.
Convert to PDF and flip (vertical) the image.
Jun 09, 2008 | Office Equipment & Supplies
Printing a mirror image
I called a Canon rep and the printer does not have that option on it.
Feb 27, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
T-shirt transfer woes
You need to use a software program to reverse image like photoshop.
Dec 29, 2007 | Office Equipment & Supplies
Canon PIXMA iP4000 InkJet Photo Printer Logo
135 people viewed this question
old marine
old marine
