Question about Akai PT46DL10 46" HDTV-Ready Television
Can't reach AKAI about replacing lamp cartridge.
My AKAI Rear Projection front panel indicator indicates that I need to replace the lamp cartridge. The picture appears fine but it says the lamp operation exceeds its rated lifetime.
The manual says it should only be replaced by a qualified technical service and to contact AKAI. The phone number in the book is not a working number but I found another number and I cannot get a response by either phone or e-mail. They answer this new phone number but I am cut off each time before I can reach an operator. Is there someone else besides AKAI that can replace this cartridge for me?
My TV is a Rear Projection Model AKAI PT 46DL10.
Any information you can give me will be greatly appreciated.
Thank you,
P. Leonard
    Problem Solver:
  • 15 Answers
The bulb is not the original bulb. you need to purchase a 9 pin RS-232 connector cable and reset the lamp life counter on the bios of the tv if the picture is still fine on the TV. (make sure the cable has a male end and a female end and attach it to your computer and the data port on the back of your tv beside the pc input, there should be a male end on your computer that looks like a monitor input but backwards)
Then I downloaded the service manual from www.nodevice.com (under service manual, click on akai and then scroll to the bottom of the page where the model number of the TV appears; there in the manual they have all the codes to reset your tv, adjust all settings, do a diagnostic of your tv to find problems etc.
The cable only costs 5-10 dollars at most computer stores in your city
Hope this helps
Posted on Jul 01, 2009
  • dreamteamfou Jul 01, 2009
    for this model I recommend www.nextdaydlp.com make sure your serial number on the back ends in J or Z (it makes a difference when getting a new lamp, and a couple bucks difference aswell) the serial number is on the back of the tv in the middle.
    Problem Solver:
  • 10 Answers
Its very simple small cover on back of tv remove this to replace lamp as its inside new lamp is available a www.replacementlightbulbs.com just be sure to order right one check last digits on seriel number should be a J or Z that will tell you the one to order to reset lamp light push menu then enter
90918988
Posted on May 08, 2009
Okay, so my Panasonic PT-43LC14 went black in mid show last night. The bulb is approximately 18 months old. The LED indicators upon Power On are; Power LED blinks green for approximately 70 seconds; Then...
Check the bulb again and look at the root of where the main stem comes out inside and be sure you don't see any bubble like appearence around the stem at the bottom there. If you do see this then the bulb is bad. Otherwise try this: Hold volume down on front of unit and pip on remote for about 5 seconds. Message will come on screen that timer has been reset to zero. This sets the lamp timer to 0
May 17, 2011 | Panasonic PT-43LC14 43" Rear Projection...
Hi My name is Dieter and I have a Pioneer Elite Pro-610-hd which keeps loosing the picture and sound.
The tv "LAMP" LED light indication front of the screen panel flashes?When was the last time u replaced the tv projection lamp on this tv?If the last time u replaced the projection lamp was like 1/12 or 2 years ago?The tv been on and used like 4 or 5 hours a day?The tv projection lamp life are over.Require a new projection lamp.
Sep 19, 2010 | Pioneer PRO-610 58" Rear Projection...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Nov 02, 2009 | Akai PT50DL24 Television
Sony rear projection tv picture going on and off
change the lamp is is too weak to operate properly.
Sep 20, 2009 | Sony KDS-60A2000 60" HDTV
Replaced lamp and still no pic lamp light comes on then lamp light goes out PT50DL14
This Akai TV is actually built by Samsung. You need to count the blinking lights on the front panel.This indicates an error code.With the code I can tell you what circuit has failed in the TV.
Jul 30, 2009 | Televison & Video
I need to change the bulb in my WD65731 dlp tv. I have taken the cartridge out. How do I get to the bulb. I repleced my lamp and still have no picture. Am still getting a "blinking" lamp light on front...
The blinking lamp light refers to the lamp door not being closed. There is a little lever behind the main panel and if that's not shut, the lever won't be pressed in and therefore the light blinks. If it's a failed lamp, the lamp indicator light will be a solid, not blinking.
May 31, 2009 | Mitsubishi WD-65731 65" HDTV
Replaced lamp in WD-52825 but still no picture. Lamp indicator on.
the DM board has gone bad. it is not the 4 100uf caps on the board. it is surface mount parts. it this board has failed then the FMT board is not far behind. the chassis needs to be rebuilt. www.tv-techs.com
Aug 29, 2008 | Mitsubishi WD-52825 52" Rear Projection...
Akai 46 rear projection tv 1.5 years old
HERE WE ARE AGAIN WITH NO MODEL #................
Nov 10, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Akai PT46DL10 46" HDTV-Ready Television Logo
241 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
