Question about Nokia N70 Cellular Phone
Battery is not holding charge
Nokia N70 mobile is not holding charge for 2-3 hours even after full charge.
I forgot my N70 mobile unlock code
Format Nokia n70(full reset)
Here's how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key
3) Power on the phone
Jan 06, 2011 | Nokia N70 Cellular Phone
My n70 gets easily discharge. i have change to a new battery but i still have the same trouble.
Make sure always bluetooth and camera shutter turned off.
set brightness(senser ) to minimum,
Try to charge battery after full empty of battery,
Only charge 2 and half hours maximum,
Buy a genuine battery(original).
Make sure all application closed (Minimisation of applications cause charge removal),(Press and hold menu key show if threre is any applications works on background),
Try to format phone by press *#7370# Install a good antivirus(netquin)
Jul 10, 2010 | Nokia N70 Cellular Phone
Charging problem
hi :) have your phone has been water damage ?? most after water damage,phone mother board's charging piont will be pro,tat only way u can do,pls send to mobile shop for repair it.
Jul 08, 2010 | Nokia N70 Cellular Phone
My mobile n70 not stand on charge above 3 to 4 hours
This problem is usually caused by battery but on rare conditions the charger as well. First of all, try with another battery (your friends' or..) and keep it charging for 1 hour and see the result, Second try with another charger. If the problem still persists then there might be problem with charging ic which you can't fix it if you are not a mobile technician. Give it a try and good luck..
May 05, 2010 | Nokia N70 Cellular Phone
My nokia n70 not turn on even bettary is fully charged
i have nokia n 70 music addition is can not turn on the display then what should i do n my battery is fulled charged ????
Jul 09, 2009 | Nokia N70 Cellular Phone
Softwire problem. my N70 music edition White Screen
my nokia n70 mobile phone screan saver not sopourt
May 17, 2009 | Nokia N70 Cellular Phone
Motorla Slvr L7 Won't hold charge
nokia mobile phones has maximum charge holding capability.motorola phones consumes more charge if we use mp3 player in it.are you a continuous user of mp3 player then try to decrease it
Jan 15, 2009 | Motorola Mobility SLVR L7 Cellular Phone
My Nokia N70 cell phone Screen is white blank
formating your phone may fix the problem
Here’s how to hard reset or format your Nokia N70 mobile phone:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Before formating make sure that your battery is fully charged. Copy all your important contacts, messages, calender, etc in your memory card and your phone should be fully charged window.google_render_ad();
Oct 21, 2008 | Nokia N70 Cellular Phone
Nokia n70, offline
well try changing sim or try different sims. if problem remains there try formating your phone
-green dial key
-the star key(*)
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is disply
make sure that you copy all your important contacts, notes, calender etc in your memory card. your battery should be fully charged and remove memory card before formatting.
Oct 17, 2008 | Nokia N70 Cellular Phone
Hi regarding nokia n70-1
1. You have to hold down the power button for a few seconds before it will turn on.
2. Did it suddenly stop working or has it never worked before?
3. You posted this in the GPS section. You'll have better luck getting an answer in the cellphone section.
Dec 05, 2007 | GPS
Nokia N70 Cellular Phone Logo
77 people viewed this question
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
