Samsung aircon cuts off. lights green/yellow flashing
Unit is a Samsung AS09A1VE Air conditioner Split System
Unit turns on with remote, green light comes on with start bells. Another bell sounds yellow light comes on, unit switches off green and yellow lights start flashing, all in around 5 to 10 seconds, unit will turn off with remote, lights go out.
Filters are clean, remote has new batteries, remote operates unit in another room.
Cant find a decent manual that describes these problems, any hints out there?
cheers.
  • Anonymous May 24, 2009
    my samsung ac split as05xlx was blinking on LED lamp, then i called technician & he just set with a remote.now i have the same problem. would you like to give me the code for this problem?
  • Anonymous Mar 31, 2014
    Cant turn aircon unit on with remote, have put in new batteries in. No info appears on the screen when mode button pushed
Lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
My split system was working fine. Tuned it on and wont work. remote is working. do I need a tec to come and look at it.
Before calling a repairman, check your self by a volt meter.Confirm power is there in your indoor unit.If there green or red light in the unit displayed or not. If yes, try with your remote. If not check your PCB for fuse blown. Replace the fuse and check again.
Indoor unit display light and no work by your remote means communication error between your remote and unit. Try with other remote. If o.k. replace your remote. If not, problem with PCB receiving sensor. Repair it. Thanks and hope it's helpful?
Jan 08, 2011 | LG LSC121PMA Split System Air Conditioner
I could not make my aircon work. When i turned it on using the remote control, the operation and timer light will blink together. The fan would not spin. No matter how many times i've turned it off and on,...
The problem is on electronic control units in the indoor air conditioner, there are two temperature sensors, sensor pipe evaporator and room temperature sensor. one or both of these sensors is defective, so that electronic controller error and showed signs of a green and yellow light flashes. You must replace both sensors with a new and appropriate size (specification).
Aug 25, 2010 | Samsung Heating & Cooling
Lights are blingking
thermostat command to out door unit not there . Check your PCB
Jul 14, 2010 | Samsung AS18A6RB Air Conditioner
Mitsubishi split-type air conditioner model MSH-26SV. When the unit is switched on, the 2 green lights on the front panel light up normally but but the unit doesn't work at all and, after a few minutes,...
Hi I have Mitsubishi split unit which is 5 years old. when turn heat mode for 30 deg C on the remote condesing unit runs for about 6 minuts and stops. what would be the Technical problem ?Thanks an Apprentice.
May 23, 2010 | Mitsubishi MS09TW Air Conditioner
Samsung AS09XLN air conditioner lights blinking
Sounds like a common problem I have found with Samsung mini split unit. When powering on, does the internal blower attempt to start, then the unit stops and lights blink? If so, on the circuit card there is a 1.2uf or 1.5uf (CBB61) that probably has gone bad. I have replaced several of these. Good luck.
May 08, 2010 | Samsung AS18A6RB Air Conditioner
Samsung air conditioner light flashes and switches off by itself
It could be the temperature sensor. It is the short , usually black wire that runs across the front of the air handler. Unplug it, and check it with a meter set to ohms. If it reads a value it is good. If you get nothing it is shorted, and needs to be replaced. If it reads good, you may need to replace the main board on the handler.
GOOD LUCK WITH THE REPAIR
Mar 10, 2010 | Samsung Heating & Cooling
Indoor unit light blinking ( first n second light from top)
I have the same problem too. Aircon cannot switch on, two lights from the top is blinking. Everytime I turn on, the flip is open then close again with sound. The technician said the thermostat cable need to be replace. It cost about $15. The cable is 14" long. Hope this help.
Feb 16, 2010 | Samsung Heating & Cooling
I have split system aircon model no ese21hra wont
You should change the remote sensor receiver unit on the unit.
Nov 14, 2009 | Heating & Cooling
Heating & Cooling Logo
2,225 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
