Question about Samsung Heating & Cooling
Samsung aircon turns in 5 sec. lights green/yellow flashing
It is a samsung split system model AS09A1VE.
When I turn it on with the remote the (im running) Green light comes on with bells, then a yellow light comes on and the aircon switches off (bells agian) all in around 5 to 10 seconds, then the green and yellow lights start flashing constantly. Lights turn off when I press power button again on remote (bells again).
Filters have been cleaned, remote has new batteries, remote works on other unit in the flat
  • Anonymous Mar 29, 2014
    batteries died and now remote is not working after replacing them. no reset button
  • 121 Answers
Check capacitor on outside unit,or gas is leaking.
try to reset(small black button in inside unit under the cover)
Posted on Feb 16, 2009
My Kelvinator ESG21HRIA split system blew a fuse in the fuse box and now will not turn on!
to blow a fuse it must have a dead short ( probably vermin across live points)
when thee is a fault in a board (internal and external) it will run then shut down
I recommend that you have a kelvinator service technician come and check ti all out because if the system has been properly installed in the first place ( obviously not from troubles from installation), the units have an operation life span of more than 15 years
Oct 05, 2015 | Heating & Cooling
I have a 1978 battery operated Garfield clock made by Sunbeam. The wires have come off, am trying to rewire but need a diagram
I have a Model 883-100
As far as I can tell
Battery 1 + Yellow from clock / Green from clock -Neg (Clock)
Battery 2 + Red to bell / White Neg to clock (Alarm Bell)
blue to alarm volume switch
red from alarm switch to bell
The Green is Neg on the inside of the movement
The Yellow is Positive to the clock movement
The Blue and White go to the trigger for the alarm-
(switch to power alarm)
one battery is for the clock and the other is for the bell
the battery on the clock moment is not needed
but should can be used to run the clock if wiring is messed up.
Apr 25, 2011 | RTO Garfield Alarm Clock Question Answer...
When I turn on my ps3 model cechg01, it blinks the green light a couple times then shuts itself off. No other color lights just the green one, then beeps three times and shuts off.. Can anybody help narrow...
When you plug in your system with the power cable and turn the toggle switch (in the back) do you see the red stand by light?
The red and yellow light comes from 1 bulb and the green and blu light comes from another..
If you have the YLOD and your yellow/red light is out, you will only see the green light.
I am really interested in your problem.
Do this to check your status: If you can do this function below but not any other, chances are, you do have the YLOD. It can be fixed.
Power off the unit using the toggle switch on the back. Hold down the 'eject' button and turn the toggle switch back from off to on. This will run a fan test and should eject your disc. Remember, this will only work on the 20, 40g models. Not the backwards compatible units with the 4 usb port holes and the memory card slots.
Jan 25, 2011 | Sony Playstation 3 (PS3) Console
Split system turns off after 35 minutes. Vanes close but operation green light blinks four times. By pressing on/off switch on remote - green light stops blinking. Press on/off switch again, system starts...
Out door compressor getting over heated. Check freon pressure. May be short of gas. If fan motor less rpm, replace capacitor. If condenser dust blocked,m clean it.
Jan 19, 2011 | Heating & Cooling
My split system was working fine. Tuned it on and wont work. remote is working. do I need a tec to come and look at it.
Before calling a repairman, check your self by a volt meter.Confirm power is there in your indoor unit.If there green or red light in the unit displayed or not. If yes, try with your remote. If not check your PCB for fuse blown. Replace the fuse and check again.
Indoor unit display light and no work by your remote means communication error between your remote and unit. Try with other remote. If o.k. replace your remote. If not, problem with PCB receiving sensor. Repair it. Thanks and hope it's helpful?
Jan 08, 2011 | LG LSC121PMA Split System Air Conditioner
Samsung air conditioner light flashes and switches off by itself
It could be the temperature sensor. It is the short , usually black wire that runs across the front of the air handler. Unplug it, and check it with a meter set to ohms. If it reads a value it is good. If you get nothing it is shorted, and needs to be replaced. If it reads good, you may need to replace the main board on the handler.
Mar 10, 2010 | Samsung Heating & Cooling
Right out of the box, my ML-2510 has a solid red error light
You should install the software prior to connecting the printer, to make sure the provided drivers are ibstalled and not the generic ones that come with Windows.
Jul 22, 2009 | Samsung ML-2510 Laser Printer
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
Heating & Cooling Logo
1,338 people viewed this question
Top Samsung Heating & Cooling Experts
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
