Question about Electrical Supplies
Switch on saw
If you would install a swiched receptical on your saws so that you can energize a shop vac when you pull the trigger you would sell a lot more saws . Make it a switched and none swithced receptical so you can plug in another tool too.
  • 21 Answers
It works the other way mate. You plug your saw into your vac unit and when you turn on the saw, the vacuum turns on as well. You need a proper vacuum with a power outlet. Your way would mean extra wires coming out of the saw. Not a good idea. Not everyone would want a saw with extra wires coming out of it.
Posted on Feb 11, 2009
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
Dewalt Model D304-04 reciprocating saw wont run. I plug it in, pull the trigger and it wont start. What am I doing wrong or what could the cause be?
Hi Fred:
Hmmmmm.
- Confirm there is power in the plug.
- use continuity meter to check that there is a complete circuit through the saw.
- broken connection in plug?
- broken wire between plug and switch?
- switch not functioning?
- switch set between forward and reverse?
- Speed control potentiometer contacts dirty?
- Bad brushes?
Aug 25, 2015 | Dewalt Saws
My hitachi miter saw started to buzz when plugged in. It's seems to work normal when trigger is pulled but starts to smoke when I release the trigger. Bushing poor good. I have no idea what is wrong?
have it investigated by an appliance repair shop
the system is this
plug in --no noise
pull trigger -- blade spins and makes running noise
release trigger and blade stops -- no noise
anything else indicates a serious problem with the unit especially if it is smoking.
May 20, 2015 | Saws
Have a Craftsman sabre saw, model #315.17280 with a defective switch. Switch part is #63896. Where can I locate a new or used switch??
THE ORIGINAL PART IS NOT AVAILABLE ANYMORE, THERE ARE SOME SWITCHES THAT SHOPS ARE LISTING AS REPLACEMENTS. BE VERY CAREFUL WITH REPLACEMENTS, ELECTRICALLY THEY WILL WORK, BUT THERE MAT BE A FIT PROBLEM. GOT LUCK. I HAD TO USE A COMPLETELY DIFFERENT SWITCH MOUNTED IN A RECEPTICAL BOX ON THE TABLE LEG.
Aug 01, 2013 | Craftsman 120 Amp Reciprocating Saw Sabre...
Choke trigger on the handle will not lock to start the chainsaw
more information please..
To lock the choke on:-
1. depress dead mans trigget on top of back handle
2. squeeze throttle trigger fully in.
3. slide on switch fully down to 'full choke' position. 'it should stay there'.
4. Pull saw over until it fires once.
5. click 'on' switch up one position to 'half choke'
6. pull saw over again, saw should start running and be revving high.
7. 'blip' throttle, saw should stop revving and run on tick over.
Dec 31, 2012 | Stihl MS181 14" Chainsaw
Saw stopped working during a job How to troublwshoot a trigger switch on circular saw
when you pull the trigger switch it should "click" when engaged.. if you don't hear a "click" then you have to replace the trigger.... If it does click then it could be brushes, or a short in the cord.
Jun 18, 2010 | Craftsman Saws
Can not unlock saw
there is a safety button[usually by thumb area when u grab handle ] on most saws that has to be pressed as well as the switch when using circular saws
Jan 18, 2010 | Saws
My recip saw just quite working I was cutting and
The switch has gone bad and the contacts are gone...
you will need to replace the switch...
heatman101
Dec 04, 2009 | Dewalt Saws
Wen electric chain saw -is it doa?
Are you pressing the trigger lock with your thumb before you pull the trigger? That's a safety feature to prevent accidental sawing.
There's not a sensor for the oil, but you don't want to run the saw dry. It takes a special bar/chain oil which is thicker than motor oil.
FYI... if you look for a manual on the web, search for "Wagner chainsaw" because Wagner bought the chainsaw business from Wen.
Mar 10, 2009 | Electric Chainsaw Sharpener
Electrical Supplies Logo
125 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
