Question about Canon FAXPHONE B640 Plain Paper Bubblejet
Scanner feed hangup
Canon Faxphone B640: In feeding the original for faxing and copying, the first page comes through with a slight tear slightly to left of center. sometimes I have to hand feed it. With subsequent pages, they start to feed and then often hang up, requiring a "force feed" which sometimes fails. I think that one of the black tabs that covers the white plastic in the assembly that engages the feed roller is broken. There is a long one to the right, but the one to the left is evidently broken.
Can I fix this, or must I send it to Canon?
  • hsvonbriesen Apr 04, 2009
    I ended up taping a small piece of stiff paper to the separation pad to replace the broken portion. Seems to work OK, though it seems a bit funky.
    Problem Solver:
  • 6 Answers
NEEDS A SEPARATION PAD AND A BUSHING.IT IS NOT A EASY FIX
Posted on Feb 12, 2009
When i send a fax my client gets a black copy
Your SCANNER UNIT has failed, very expensive to fix.
Apr 02, 2010 | Canon FAXPHONE B640 Plain Paper Bubblejet
Can't fax or copy on brother mfc3240c machine
Sounds like you may have a small obstruction in the scanner feed. This would inhibit making copies and sending faxes. Lift this section up slightly to inspect for small pieces of paper or dust. Blowing it out with compressed air would also be a good idea.
Aug 20, 2009 | Office Equipment & Supplies
your fax cartridge is BJC Bx/BC03/03
Jun 28, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
I need the drivers to install my printer
Hi, You might want to read the bulletin below before using that machine.
Hope that helps.
Lbcoaster
An electrical component used in certain FAX PHONE B640 units manufactured between September 30, 1999, and January 26, 2000, may present a risk of fire.
This potential risk, and Canon's commitment to customer satisfaction and safety, have led us to implement a special Instant Exchange Program to replace, at no cost to customers, all FAX PHONE B640s bearing the following serial numbers:
  • UKK52923 to UKK55442
  • UKK60513 to UKK99999
  • YKK02001 to YKK20000
The serial number on your FAX PHONE B640 is printed on a silver sticker located on the back of your product, as shown below:
b640_serial.gif If your FAXPHONE B640 contains one of the above-listed serial numbers, simply call our special Instant Exchange Program toll-free number, (888) 280-7858, between 8:00 a.m. - midnight, Eastern Time, Monday through Friday, or between noon - 8:00 p.m., Eastern Time, on Saturday.* We will arrange to ship you a new FAXPHONE B640 or comparable model, complete with a one-year warranty, at no charge. We also will provide you with a toll-free telephone number to call to arrange pickup of your used FAXPHONE B640. There will be no charge to you for this pickup. Please DO NOT return your FAXPHONE B640 to the retailer from whom you purchased it.
If you have any questions concerning your FAXPHONE B640 or the special Instant Exchange Program, please call Canon at 888-280-7858 or email Canon at B640@va.cits.canon.com.
*If you cannot use the toll-free number because you live outside the United States, you may call (757) 413-2848, and receive additional directions for the replacement of your FAXPHONE B640.
Jun 02, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon B640 printing problem
The scanner lamp is not working. When making a copy, the lamp lights the source document, so if there is no light, the source document 'looks' black. Your machine will need to be serviced.
Jan 26, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon b640 problem
By cleaning the feed rollers you the fax will feed beter.Remove the dockfeeder and the paper tray.you will find the feed rollers in the bottom of the paper tray.Take a cloth and a stong soap selution and clean the 2 feed rubbers.
Jan 06, 2009 | Canon FAXPHONE B640 Plain Paper Bubblejet
Black marks only when faxing
check the Scan glass where you put the original to fax, there should be a door to open and see a small strip of glass, clean it.
Nov 17, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
Faxes being sent but stuck in memory, How do I Print them out?
Printing Documents in Memory: From B640 Manual
Except when you run out of paper, the faxphone will automatically print out the contents in memory when you remedy the cause of the problem.
If running out of memory caused memory reception, adding recording paper and press {STOP} to begin printing the stored page(s).
After printing the page(s) in memory the faxphone erases the documents from memory.
Jan 19, 2008 | Canon FAXPHONE B640 Plain Paper Bubblejet
Drum? glass? on faxphone?
try this take out drum( toner) clean machine see if there is a thin strip of glass on bottom inside the machine. make sure it is clean, this will give you black lines if dirty.
here is the manualit can guide you better, look for the troubleshooting and maintenance section
http://www.retrevo.com/s/canon+b640++manual?rt=tr&p=http%3A%2F%2Fwww.usa.canon.com%2Fcpr%2Fpdf%2FManuals%2Fb640_ug.pdf
good luck
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Sent faxes and copies come out all black
The lamp in your scanner unit has gone out. Given the age of your unit it is not economically feasible to repair Sorry Ed
May 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Canon FAXPHONE B640 Plain Paper Bubblejet Logo
108 people viewed this question
old marine
old marine
