Question about Tomtom One XL GPS Receiver
How to get directions using side streets
Directions on side streets
I can not get my tomtom to find city and street adress
Which device are you using the tomtom on? a phone or a gps handheld? which ever you are using you must download the maps of your desired region and install on sd card for it to find your streets. your model AND REGION WILL HELP ME HELP YOU BETTER.
Nov 16, 2011 | Cell Phones
I have a Magellan 4350. From day one, my home
if you havent installed the latest v8.3.2.64084 update go HERE and download it and follow the directions carefully.
bill
Jan 01, 2010 | Magellan Maestro 4350 GPS Receiver
BOUGHT NEW GRIPS FOR 2010 FAT BOB IS THAT SOMETHING I can do myself or is the throttle side gonna be a problem?
Throttle side switch housing may need taken apart. Just take your time and read the directions.
Nov 16, 2009 | 2006 Harley Davidson FXDBI Street Bob
How to update street names in some small towns
type in town and main street and it then should show all side streets and more as you go along.
Jul 30, 2009 | GPS
Direction directions do not name streets
go to change preferences select change voice select computer voice
Feb 18, 2009 | Tomtom ONE GPS Receiver
I can't get it to announce street names
go to the language section of your unit and pick a language with (tts) following it.this is text to speach option.
Jan 13, 2009 | Car Audio & Video
Text to speech incorrect info
Yes, this is basically normal. This is not a shortcoming of the GPS per se, but of the maps that it's using and where on the map it has recorded that certain addresses are located.
The maps that the GPS systems don't (typically, to my knowledge) have every building on them, instead they just have numbers recorded every so often on the street and then the machine interpolates where a particular address ought to be based on known intersections. E.g., 150 Foo Street ought to somewhere around the middle of the 100 block of Foo St. on the "even" side of the street. So this is probably why it thinks your apartment is slightly further up the street than it is; when people build things, we often don't allocate exactly the same amount of frontage to each street number, hence the offsets.
I'm still pretty impressed with my Garmin and doubt I could find my way home without it. Good luck!
Nov 30, 2008 | Garmin nuvi 255W GPS Receiver
Street addresses
give me more imfo or try using postcodes
May 28, 2008 | Garmin StreetPilot C330 GPS Receiver
Speaking the names of major streets
It will only tell you the names of the streets if you use the COMPUTER voice. The other voices will not announce street names. So go to your voice selection and pick the computer voice...either male or female.
Mar 30, 2008 | Tomtom One XL GPS Receiver
Street name that is a number.
When you need to enter an address that is numerical such as the 52nd street, enter as normal until you reach the street name. At the bottom of the screen, you will see a button that says, "123." Press this button, then enter the number (52, in your case). Press done, and it should say something like, "52nd (Street, Ave, Etc.)" Press this button, and your address should show up. Please let me know if there is anything else I can do for you.
Mar 03, 2008 | Garmin StreetPilot C330 GPS Receiver
Tomtom One XL GPS Receiver Logo
770 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
