Question about Memorex Televison & Video
Images not goin to my tv
I got an s-cable and connected my computer to my tv, but still not getting the image.
  • Randy Hough
    Randy Hough May 11, 2010
    Please provide computer make,model,and Operating system.
  • 537 Answers
Make sure your tv has the video input set to AUX. Also, make sure your computer is really outputting the signal. Does your computer require a switch or setting to be made before video out through the s-video connector is active?
Posted on Feb 11, 2009
Why can't I find the connect to projector option?
Connect your Projector to PC Computer
Connect to projector
How to Connect Laptop to Projector
How to display computer image on TV or projector
How to display a computer image on a TV or projector All modern televisions and projectors have one or more ports which allow them to receive and display an image generated by a computer. Both desktop and laptop computers are capable of connecting to a TV or projector, provided that they have the appropriate cables. The following sections contain instructions for using your TV or projector as a computer monitor. For best results, we recommend reading them in order.
Identifying available connections
Connecting computer and projector or TV
Display using Desktop
Display using Laptop
I don't see an image on my TV screen
Identifying available connections The first step in connecting your computer to a TV or projector is finding an identical port on both machines. Once the matching port has been identified (one that is the same on both your input device and output device), you need the appropriate cable to connect them. This section contains a picture of the back of an Epson projector and its available connection ports; as well as descriptions of each.
HDMI
The HDMI connection is very popular among display electronics. In fact, nearly all modern televisions and projectors feature HDMI ports. Most laptop computers support HDMI and it is becoming more prevalent on both desktop as well; even without a high-end video card. HDMI is quickly becoming the standard for all electronic equipment for its high quality signal and ability to carry both audio and video signals. The image to the right is that of an HDMI cable.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-1.jpg VGA
The VGA connection is the most common among both desktop and laptop computers, is found on most projectors, and some TVs. The VGA cable has a 15-pin connector on each end that plugs into a VGA port on each device. Due to the fact that most televisions do not support VGA, we recommend using HDMI for their wider range of compatibility.
find-connect-projector-option-vga-hdmi-zonwsocbr3qazne24mugrpvs-1-2.jpg Tip:VGA cabling is universal for devices that support it. For example, the if your desktop monitor that uses a VGA cable it, that same cable can be used by a laptop to connect it to a projector.
Note: If you are using an Apple desktop or laptop you need a VGA adapter to connect a VGA cable to the computer.
DVI
The DVI connection is newer than VGA and it offers a sharper image. Although the DVI port is not shown on the Epson model above, it is still somewhat common for projectors, not so much for televisions. It is mostly found among desktop computers for monitors, but some laptops have DVI connections as well (Apple laptops are more commonly known to support DVI than any other brand of laptop). Since finding DVI on a TV or projector is more difficult, we again recommend using HDMI cables.
Tip: There are special cables that convert from DVI to VGA or DVI to HDMI and vice versa.
Composite Video
The composite video connection is quite common on a TV or projector, but it is nearly nonexistent on modern computers. This connection is the yellow female cable on what is normally a three bundle of red, white, and yellow. The only time you should see this setup is on older video cards for desktop computers.
S-Video
The S-Video connection is also commonly found on TVs and projectors, but solemnly on a desktop or laptop computer. This connection is a small step up from composite video, but is nearing obsolescence.
Connecting computer and projector or TV After you've identified what connections are available on both your computer and TV or projector, you're ready to connect the cables. If the same connections are not available for both the computer and TV or projector, you'll need to purchase a video converter cable that converts one signal into a compatible signal.
Desktop Computers For a desktop, you simply need to plug the cable into the computer and output device. If you don't see an image, you may need to change the display using the following steps.
  1. Press the Windows Key.
  2. Type Adjust screen resolution and press Enter.
  3. Find Display and click the down arrow on the right-hand side of the box.
  4. Select the appropriate output device.
  5. Click Apply then OK.
Laptop Computers If you're connecting a laptop computer to a TV or a projector you'll often need to "send" the video signal to the display device. The key sequence to do this varies depending on the laptop; but usually it's either: Fn + F3, F4, F5, F8, or F9. For example, pressing and holding Fn + F3 at the same time on my laptop sends the video signal to my connected TV instead of the laptop's screen. The corresponding key used with Fn may be labeled as CRT/LCD or have a picture of a monitor on or close to the key. Additional help and information with switching the laptop display can also be found on the link below.
Switching TV inputs Finally, if you're connecting a computer to a TV make sure it has been switched to the correct input. For example, if you connected an HDMI cable to your computer and the "HDMI 2" port on your TV, you'll need to switch to the "HDMI 2" input. This action can be accomplished by pressing the input button on your TV remote until the correct image is displayed.
Jul 14, 2015 | Computers & Internet
No image from computer to tv with vga connection
Ensure your TV is turned to computer/VGA input. On your computer use the Windows key + P continuous until it appears on the TV.
Mar 08, 2014 | Pioneer Elite PRO-1140HD 50 in. Plasma...
Theres no image when connecting my tablet to lg tv
make sure your cable is not damaged or compatible.
Jun 19, 2012 | Samsung Galaxy Tab 101 Tablet...
What key will project my laptop image to a tv screen. I have the proper cable connection between my computer and tv.
Thank you for choosing fixya.
There is a short cut key which you can press to connect the image from your laptop to the tv screen. You can either duplicate or extend the image to the tv. Just press windows key+P.
The window key is beside the FN and the ALT key.
I hope this helps.
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Feb 03, 2011 | Dell Inspiron E1505 Notebook
What do i need to use t3500 to watch tv
  • 1
    Determine what kind of video line-in connection the TV has. These connections are typically on the back or side of the TV. You also will need to determine what kind of video line-out connection the computer has.
    Types of video connections include S-Video, VGA, DVI and HDMI. The Resources section of this article offers links to sites that will help you identify the connection type of your TV and computer.
  • 2
    Purchase a video connection cable that is for the type of connection that the computer and TV share. For example, if the TV and computer both have S-Video ports, you should purchase an S-Video cable. S-Video connections are the most common and least expensive option.
  • 3
    Connect the end of the S-Video cable that matches the connection on the computer to the computer video line-out port. Connect the other end to the video line-in port of the same kind on the TV.
  • 4
    Convert video from VGA video to S-Video or even component video. Do this if the two connection ports on the computer and TV are not compatible. You will need to purchase a scan converter box, a VGA video cable, and either an S-Video or component video cable. Connect the cable that will connect to the computer jack to the computer and the converter box, and connect the S-Video or component video cable to the TV and the converter box.
  • 5
    Turn on the TV and use the remote control to select "Input." Some TVs will have multiple selections. Turn on the computer and play a movie or display an image on the screen. As you are scrolling through the "Input" options on the television, you will see a matching image of what you opened on your computer on the TV screen when the correct input is selected.
  • 6
    Adjust the screen resolution on the computer if the image on the TV is distorted, too small or too large. Do this by going into Control Panel and Display Settings on the computer. Select a different screen resolution until the image on the TV fits the TV screen
  • Oct 28, 2010 | Dell Precision T3500 Computer Workstation...
    Connect satellite L655-03F to tv samsung LN-S4095D
    Assuming your T.V. is set up right, That is, the cable input matches the select input on the remote control check this, try clicking around the input choices while you feed the computer output to the to the T.V. Otherwise you may need to check for a other coveter boxes, It stands to reason, one way or another, you should be able to see the computer image on that T.V. model.
    Jul 26, 2010 | Toshiba Computers & Internet
    Images are not clear and it looks like a tv channel not tuned.SHH
    W/power off
    Try moving cables to another location and ckn connections
    Apr 28, 2010 | Philips Brilliance 150P Monitor
    Laptop to TV connection but no audio
    what kinda connection did you made?? what kinda cord did you use....anyway...it usually works that way..you can get image on TV ..by setting the image card driver ...but the sound bust be connected separately ...if your TV has a input plug for sound...just take a proper cable ...and get signal from the green out of the computer and plug it into the input of the tv ...this way you will have sound comming from the TV speakers and access on the volume with its remote control ...but no matter what kinda plug u used for the connection with the tv ...you will not get eny thing more than image..
    so...if your TV doesnt support sound plug in just attach some speachers ...
    Jun 14, 2009 | Acer Computers & Internet
    The image expands off the screen of my HD tv
    Look in the menu for an image adjustment option. This is used to center or adjust the given image. Try a different type of connectiong from the cable box to your TV. ie; if you are connected by component connection, try AV or HDMI to test. If that doesn't work, look at the cable box settings (call your cable company for instructions) or have the box replaced if defective.
    This is common for PC connections but not for cable.
    Dec 21, 2008 | Televison & Video
    Acer aspire 3610 can i use my laptop to connect to lcd tv i have vga output
    So if there is not a vga input connection on your lcd tv which most do. You can get a vga to dvi cable adapter in conjunction with a dvi to hdmi conversion cable. Note that you may have to change your resolution settings in order to veiw computer images on your lcd t.v. If your laptop has an svideo output you can also connect this way but the image quality will be greatly reduced.
    Dec 10, 2008 | Acer Computers & Internet
    Televison & Video Logo
    41 people viewed this question
    Top Memorex Televison & Video Experts
     Grubhead
    Grubhead
    Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
