Question about Sony PlayStation Portable (PSP) Console
WHlie playing in turn off. Already fully charged and sometime
Just wont turn on.
Well, i don't know how to charge it but jiggle the cords in the back of t.v. and console and reboot
Posted on Feb 12, 2009
Tabeo tablet battery not charging will work if plugged in
Hi! Hope this may serve as a hint. When power problem dooms to any electronic device needing battery operation we sometimes least assume that the battery life is near to its end. I mean its charging life has come to end. However, you can sometimes recycle it's life cycle by discharging fully and recharging fully without using it. Battery utility softwares can help monitor its life but cannot revive at all. Charging also using fast charger and or slow charger can help reactivate the battery cells. I personally experience, a gadget of mine its charging life is almost come to end and when I accidentally plug it on my laptop with 3.0 USB offline charging capability it somehow raise its life but not as good as it is. If the above doesn't work at all, it's time to change the battery pack. Goodluck!
Mar 09, 2014 | Toys R Us Tabeo
The gyropter will not charge when I plug it in
Check the charger adaptor if it has any output power. If no power comes out replace the adaptor.
Check also the battery terminal, it might already corrode and needs clean up.
If all does not work, the battery in the helicopter is already malfunctioning.
hope that helps you out!
Aug 14, 2011 | JCPenney Gyropter RC Helicopter
Hi, I have samsung SGH - X700, my phone gets switched off automatically when i speak for 15-20 min over the phone. When i put for charging, it shows full charged in 30 min.. Could you please...
The problem is with the battery. The battery life is down.
My advice is that you purchase a new battery from a recognised store.
When you have done that, before you use the phone, charge the battery fully. Also, ensure that the supply of power is steady.
In addition, to sustain your battery life, once in a whlie, like every 2 months, fully discharge then fully recharge your battery.
This should make it last longer.
Hope this helps?
Success.
May 15, 2011 | Samsung SGH-X700 Cellular Phone
I have a sony cibershot camera for over a year now, it has always worked nicely, up until a month ago, it suddenly wont turn on anymore. I,ve already charged and re-charged the battery but nothing...
make sure the batt is charging and working fine.check also the batt contacts.make sure its clean.insert batt to your camera.instead of pressing the power button, press the play button instead to power camera on. if unit turns on,might actually be an issue w/the camera unable to power on in camera mode.if it turns on initialize cam (p.75 of the manual).see if it works.if still wont turn on try using a diff batt (or if you have an optional ac adapter model#acls5k use it, attempt to power on cam to isolate issue w/power source).if batt or ac adaptor not available try to check batt with another cam if possible to test batt. if still unit doesnt turn on using a fully charged, diff batt, or using an ac adaptor,unit would reuire service. hope this info helps.thanks:)
Apr 06, 2010 | Sony Cyber-shot DSC-H9 Digital Camera
I have had problems with truck starting
When it wont crank, tap on the starter with a hammer, wrench ect. if it starts then, most likely need the starter replaced. If it grunts, its getting power. Make sure the battery is good. to check, take a voltage reading should be 12.7 volts on a fully charged battery, take a reading when starting, should not go below 10volts.
Sep 18, 2009 | 1995 Nissan King Cab
When I turn on my N64 with everything plugged, the red light wont turn on!
What's the RED light For ? usually indicates charging ..if flashing if steady then it's fully charge to a GREEN light unless it's already Solid RED
Sep 18, 2009 | Video Game Consoles & Games
GPX DVD Player
Most items, first time your have to charge it for continious 8 to 11 hours. On that time it fully charge the battery and internal battery. I would say charge it for 11 hours.(It wont over chage on anything.)
But, if you already charged it for some time, discharge it fully. (Leave it playing till it wont even turn on when you puch the power button) Then charge it backfor11 hours.
Cheers!!
Mar 13, 2009 | GPX Audio Players & Recorders
WHlie playing its turn off
giggle with the cords in the back of the t.v. and back of console, also take disc out and restart
Feb 11, 2009 | Sony PlayStation Portable (PSP) Console
Won't hold a charge I guess is the problem
your battery is broken and wont hold charge you will have to buy another
Jan 13, 2009 | Insignia IS-PDO40922 Portable DVD Player
Sony PlayStation Portable (PSP) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
