Question about Canon FAX-L350 Plain Paper Laser
I have cable modem for my internet. I dont have any phone service
Just only cell. Can you have fax machine connect thru cable modem as a phone line?
    Genius:
  • 2,120 Answers
No. fax machines are ANALOG devices. Cable Modems, DSL, Vonage etc are DIGITAL.
Posted on Feb 15, 2009
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
I am using a cable modem and a router on a laptop. I do not have a phone line. Am I able to fax using Windows 7? The computer states that I do not have a built in fax modem. I have an HP printer with...
For regular faxing a modem connected to a standard phone line is required, normally.
There are many websites devoted to allowing you to send faxes online that would suit your current needs perfectly. please see the following two links, these are services that can assist you in doing exactly what you need to.
Site #1
Site #2
NOTE: There are MANY more but these are two of the most prominent.
May 04, 2011 | Computers & Internet
How can i connect a phone with and answering machine and a computer?
Magic Jack does that all in one. Some cell phones will connect to a computer but only to transfer files or in some cases can be used as a internet access modem. Cell phone service providers will offer a answering service or a voice message service. Now regular wired phones can pass thru a computer if it uses a standard modem with a pass thru port. That type of modem will allow you an answering machine service if you want to pay for the software which goes for $29.oo To about $99.oo dollars.
Mar 20, 2011 | Cell Phones
Would like to connect a fax but only port 1 or (tel 1) port 2 does not work, should i send back to comcast or reset modem
There is nothing wrong with your modem. Comcast charges extra for a second line. Depending on your model of fax machine, there should be both an input ond an output on the back of the fax machine. Plug the fax machine into line 1 on the modem. Then, plug your phone into the input on the back of the fax machine. If you fax does not have both in and out, then you can purchase a "Y" phone line adapter from your local electronics store.
ps. VoIP is a digital line... Facsimiles are analog signals... Sending analog signals over digital lines is not recomended. If you are wondering "why?" (and understand tech jargon) VoIP is sent via UDP, which is a connectionless protocol (does not retransmit dropped packets) Fax machines use TCP, which does resend dropped packets. This variance in Qualiy of Service sometimes cases strange activity such as both lines (sending and receiving) dropping connections, faxes taking a long time to transmit (due to constant resending loops), etc. It does work... kind of. I would just not assume that faxes made it to their destination until it gets confirmed.
Dec 31, 2010 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Ng poor line condition/ out of memory
Generally this is an indication that the telephone line you are trying to fax over has either alot of noise on it or possibly on the receivers end.If you are on a telephone line which has DSL service on it make sure you have a line filtre connected on the fax to eliminate line noise for your DSL modem, as well if you are using a digital phone service such as Vonage or your Cable providers phone service this is a digital service, contact brother technical support to have your modem speed lowered to 9600bps through the firmware switches on your machine.
Mar 26, 2010 | Brother IntelliFAX 4100 Laser Fax
How can i send a fax thru my internet connection
Fax systems are ANALOG your cable is DIGITAL, you will have to use scan to email if your printer has that option.
Jun 27, 2009 | HP OfficeJet 6110 All-In-One InkJet...
I am trying to use the fax facility on my epson600fw.my isp is aol .Problem no dial tone. What connections are necessary............via printer,modem & computer ?
Typically, a fax machine is connected directly to a telephone wall jack with a known working connection. Try plugging the fax machine directly into a wall jack first and pick up the handset on the fax machine if it has one. You should get a dial tone. Then try to fax something to someone you know.
The machine can also usually be routed through the modem in a computer by connecting the "line" cord on the modem to the wall jack and plugging the fax machine into the the "phone" jack on the modem. You may need to install the software that came with the fax machine to get this to work.
If you have no dial tone, check the wall jack with a known to be working single line phone. If there is a dial tone, it's something to do with fax machine, the computer modem or the connections.
Some fax machines can take advantage of internet faxing through a cable modem or DSL connection. Check your manual for the options available.
Apr 18, 2009 | Lexmark X5470 All-In-One InkJet Printer
Yes i want to find out if a cable modem will work with your dsl phone internet service?
No.
A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
Jan 27, 2009 | AT&T High Speed DSL Modem
WILL NOT RECEIVE FAX
Fax machines are ANALOG devices and are designed to have their own dedicated phone line. They will not work reliably on DIGITAL phone lines.
Dec 02, 2008 | Office Equipment & Supplies
We have an internet modem(connected w/an ethernet cable) that also includes a phone line which also connects to a fax machine. We only have one phone number and we were told if we put our fax on auto...
Most fax machines do not operate well on digital lines.
Contact your provider and see what fixes they have for your specific fax machine.
Most fax machines still require an analogue line.
May 02, 2008 | Office Equipment & Supplies
Canon FAX-L350 Plain Paper Laser Logo
80 people viewed this question
old marine
old marine
