Question about Bissell 1699 ProHeat Clear View Upright Steam Vacuum
Soap is not dispensing out of the soap dispenser on the bissell
My soap solution is not dispensing out of the dispenser on my bissell
    President:
  • 1,902 Answers
Pour some hot water in the machine and see if the hose is clogged. Is the pump making any noise when you hit the switch like it is trying to pump?
Posted on Feb 11, 2009
Bissell powersteamer won't dispense soap
Check to make sure the tank is installed completely. Turn off unit and unplug it. Then reinstall the tank, plug in the unit, wait one minute and turn it one. Check by using the sprayer. If that didn't work call the Consumer Care at 1-800-237-7691
Sep 24, 2014 | Bissell Powerclean Powerbrush Pet Carpet...
Soap won't dispense from tool sprayer
Here's a quick link to some helpful tips. http://www.bissell.com/FAQDetail.aspx?id=1064&cid=ccsocial
Here's a link to locating a BISSELL Authorized Service Center if you continue to have difficulty.
http://www.bissell.com/service-centers/?cid=ccsocial
Dec 01, 2012 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Bissell ProHeat Turbo. It has only been
i use white vinegar to clear my line.. and it doesn't hurt the carpet.
check the little filter on the top of the machine (mine is on the right side) if it is full of lint, etc and blocked it will not dispense or pick up.
Mar 28, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell Proheat wont spray soap with uniformity
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhkl
Sep 10, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
BISSELL HELP
Usually when you can't put out soap, there is a problem with the vale at the bottom of the dispenser, or the seal is not on it and gone or sitting in the hole, needs to be on the dispenser. Same is true for the wter tank valve and seal.
Mar 25, 2008 | Bissell 1698 PowerSteamer ProHeat Upright...
Will not dispense soap from handle
The soap dispenser, on the side, make sure the seal is on the bottom of it and not in the hole. You may have to replace the valve asm for the dispenser part # 2101795
Sep 30, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell pro heat cleaner
This could be due to dried out soap in the works below the dispenser. Try cleaning the hole, putting plain water in the soap dispenser to clean it out further. You could just put some soap in with the water. Be sure to run lots of rinse water through afterward to clean out the heating unit.
Aug 18, 2007 | Bissell 7901-1 ProHeat Scotchgard Upright...
Soap dispenser
Probably plugged with soap. Try to clean the hole under the shampoo dispenser. Put plain water in the dispenser and hope it gradually cleans it out.
Jun 14, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 1699 ProHeat Clear View Upright Steam Vacuum Logo
382 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
