Question about Technics SL-1200 Turntable
Mono i have a 1200 inwhich i want to use with serato but someone open it and connect it in mono i want to know how to change it please email me as soon as possible
  • 104 Answers
Http://www.radioshack.com/product/index.jsp?productId=2102978
http://www.radioshack.com/product/index.jsp?productId=2102977
What you need is one of each of the RCA Y-adaptors like at the above links. Radio shack probably has non-gold cheaper ones in the store. on the one that is radio shack model #42-2608 hook the two 'female' connectors to your turntable's red n white RCA outputs. then take the radio shack model 42-2609 and hook the two 'male' connectors to your serato. finally connect the two Y-adaptors together in the middle! This merges both channel but keeps them both equally going into your serato so that no actual musical info is lost.
Posted on Feb 11, 2009
Why can't I insert ink cartage in slot?
please open the door of printer and push the cartridge slowly and then the cartridge push down, the cartridge come out.repeat this same process to insert new ink cartridge.
Oct 01, 2015 | HP Deskjet 2540 Inkjet Multifunction...
How do I insert new cartridge into HP desktop 1510
Easy answer , though this here isn't your answer but try googling it or you tube. I've always found answers there.
Good luck !
Jan 02, 2015 | HP Deskjet 1510 Inkjet Multifunction...
Im playing my SL-1200MK2 threw serato and it when i press play to make the record spin serato pick up that the record is slowly spinning backwards? and no noise is coming from the record
do you have your timecodes set properly and configured with serato? that could be the issue try adjusting the timecodes w serato and basically re sync them. if this doesnt help please let me know
May 11, 2011 | Technics SL-1200MK2 Turntable
Music cuts out for a split second randomely
u r facing the problem of buffer down of pcb
ju must change ur processor and ram too than u see that ur system working properly
Jul 26, 2009 | Rane Serato Scratch Live Computer DJ...
Taken off internet because someone is using another devise
Hello
That means that someone else knows you Yahoo Mail password.
Please change it as soon as possible.
Best regards,
Zizzler
Apr 22, 2009 | Yahoo Mail
Distorted sound, Low signal, unable to use deck with serato.
I just want to clarify the way you have your gear set up.,
Normally this is enough to annoy anyone.
Having set all the equipment up,this is what I would do.....
Try without Serato
Firstly I would set the records & platters and then the counterweights,
Then I would do an audible check.Headphones,Monitors and then front of house system
If this passes I will then set the room levels for comfort and then the eq band gets a tune up for the room,
If this set up procedure works then connect Serato,
If problems persists then Uninstall Serato and Reinstall.
Try Again if all else fails ......
www.serato.com they have a contact us,report the problem.
Hope this helps ,If you need more help please let me know,Misterdj
Jan 18, 2009 | Technics SL-1210 Turntable
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Serato won't recognize my music files
your using itunes and trying to export your library that is the problem it has metatag encoding which at this time is not supported by serato and says it all over there sites forum. There are ways to do it but none of which i know that are legal or condone. Your best bet is to not use itunes as many djs acknowlodge that since you cant use itunes to dj with, even in your bedroom as stated in there terms of service that it is not worth using itunes. I use other types of music collections on like such as mp3.com and rhapsody or dancerecords.com to download all my music to dj with.
Sep 08, 2008 | Technics SL-1200 Turntable
Connection help
Nope. There are no input connections on the DZ1200. However, you can use programs like Serato, CUE, TRAKTOR, or PCDJ, and you can keep your music on your computer/hard drive, and control with the DZ1200 via specially coded CDs.
- OPTiC
DJ Pro Lab
1200s.com
Aug 16, 2008 | Technics SL-DZ1200 CD Player
Problem
Make sure your ground wire is connected. I know Serato does not work properly if your ground wire is connected.
Also, make sure your running the connection from the Line Out of the Serato box into the LINE IN on your mixer. You can use the Phono Input also, but I generally tell people to use the line input to avoid any issues. Regardless of which input you use, make sure that your Serato software is either set to LINE or PHONO, otherwise it wont run properly.
- DJPROLAB
Feb 14, 2008 | Technics SL-1210 Turntable
Technics SL-1200 Turntable Logo
231 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
