Question about Brother HL-2070N Laser Printer
Ink runs on both sides of paper
My husband replaced the ink cartridge of our Brother HL2070N printer
Now it has the ink runs on both sides of the paper.
I cleaned the carrier portion of the ink cartridge but 20 papers or so, no significant change.
Is there a way to fix this or have we just ruined it?
    Sergeant:
    Champion:
  • 357 Answers
Try running the utility to solve this issue.
Good Luck.
Posted on Mar 16, 2009
Ink spots left side page brother laser printer
If you are using a generic toner, replace it with cartridge from Brother. Many of these are caused by using a refilled cartridge or a generic cartridge. Use a cleaning sheet and run it though a couple of times, if this does not clear it up you need a new cartridge.
Mar 28, 2014 | Brother HL-5240 Laser Printer
Ink has dried up and won't print
Remove the ink cartridges from the printer. Find the gold colored bars where the ink is dispensed on the cartridge. Run this part of the cartridge very gently under your faucet using a small trickle of warm water. Wipe clean with a paper towel until no ink remains on cartridge. Reinstall cartridges. Run cleaning cycle and then try reprinting. ( several cleaning cycles may need to be run to get a good printing ) If this does not clear the cartridges, they may need replaced.
Feb 22, 2014 | Brother International Brother MFC-J435W...
I have a Brother MFC-465CN and it says the Black Ink cartridge is empty. However, the cartridge is full. I cannot print until this is resolved - ow can I fix this?
Hello I am an expert on printers are pretty good Brother.Brother But the ink is running out fast .. I got home Brother MFC-210C.
So I took ink and slid ho.
. I hate Brother printers!. So I broke down and I saw that there is a color sensor and instead I chose colors I had crouched low and showed that the paper is full of the good? Try it at home if you can.
Jul 30, 2012 | Brother MFC 240C All-In-One InkJet Printer
Brother MFC-290c printer does not print black anymore. Test print page color ok but not black printing. What is the problem?
The problem is either:
* out of BLACK ink -- replace the ink-cartridge
* clogged ink-jets -- the ink is not spraying onto the paper, so run a few print-head-cleaning cycles
* dead electronics -- not triggering the jets to spray ink, so replace the printer
Feb 20, 2011 | Brother MFC-290C Multifunction Color...
I just changed all the printer cartridges out and now get black and blue now black and orange lines down both sides of the paper
1. Ink cartridges might be faulty, dripping more ink than they should. Remember to always use genuine ink cartridges.
2. Print head needs a clean (even if it was a faulty ink cartridge) and if this doesn't fix it will need replacement.
Nov 14, 2010 | Brother MFC 210C All-In-One InkJet Printer
How to change ink?
Press print button. Choose replace ink. Ignore this two steps if the display on your printer is Colour Ink is Empty.
Open cover. Press the round side of the ink cartridge holder arm and the holder will pop up. Take out the ink cartridge. Put in the new cartridge and pop the holder arm back by pressing it down.
Remember to remove the seal below the new ink cartridge before replacing it.
Jun 10, 2010 | Brother MFC-3220C Plain Paper Inkjet Fax
Brother hl2070n
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Brother HL-2070N Laser Printer
Can't print pic on glossy photo paper with brother 3in1 printer
First off thanks for using fixya.com
Secondly, it is very difficult to tell exactly which is the problem. I would however put most of my concern in the refill ink. Since it is from a third party and not recommended by the manufacturer this ink may be designed for regular paper only. Ink that is used for photos has a quicker dry time to keep it from running. Since your ink is running it may be that the ink is not designed for photos paper.
You may also be able to drop down your print quality, this will use less ink and may dry faster. This can be access by going into your print settings before printing a photo. With what I have seen in the past, switching over to a manufacturer recommended ink cartridge will probably fix your problem.
I hope this helps you out, but feel free to ask further if needed.
Jei
Dec 15, 2008 | Lexmark X620 MFP All-In-One Laser Printer
Using far too much ink
This came from brothers website:
The Yellow ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Magenta ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Cyan ink cartridge yield is up to 300 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
The Black ink cartridge yield is up to 350 pages @ 600 x 150 dpi when printing at 5% coverage on A4 sized paper.
so it appears that what you are experiencing is not normal and you may have a leaking printer.
There is one thing you can check though, everytime you print, make sure that you are not printing at the highest quality option selectable as this almost certainly will fire out more ink than regular printing... choose a middle quality option or even draft option if you will be printing regular text.
Jul 02, 2008 | Brother Office Equipment & Supplies
Changing my ink cartidge
Hate to have to tell you, had same problem, cannot be fixed, bought new printer BUT NOT a Brother, never again.
Brother wants you to return it to a repair depot for big $ to fix.
May 28, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother HL-2070N Laser Printer Logo
106 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
