Question about GE 25931 Trio Cordless Phone
WHEN THE PHONE RINGS ID DOES NOT APPEAR INCOMING CALL
CORDLESS 2 HANDSET PANASONIC MODEL KX-TG 6702B
  • jim beckwith May 11, 2010
    do you have the service with your phone company
5 Suggested Answers
SOURCE: idect x1 cordless phone
the cordless connected on ups rings periodically without being called
Posted on Mar 08, 2008
SOURCE: GE MODEL 28112 DECT 6.0 CORDLESS PHONE
I contacted GE today and they told me how to get the caller ID to work on the additional handsets. You must follow these steps in the exact order given.
#1 - unplug the base phone
#2 - unplug the telephone line from the base phone
#3 - remove the battery packs from the phones
#4 - wait 10 minutes.
reverse the order when assembling. Put battery packs in phones, put the telephone line back in the base phone and lastly plug all phones back in. It takes about another 10 minutes after that before all phones start recognizing caller ID but it now works fine.
Posted on May 30, 2008
SOURCE: caller id not working
US phones use Bellcore FSK caller id. India uses DTMF caller id. Buy a DTMF- FSK converter at a telecom shop.
Posted on Dec 22, 2008
SOURCE: Panasonic cordless handsets all say line in use
I had the same problem. Something makes the phone's memory get "stuck."  Take the battery out of the phone for a minute and then put it back. Then unplug the phone and plug in again. You need to do this with all extensions. The problem goes away.
Posted on Jan 12, 2009
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
ABOUT KX-TG6541
maybe if you ring the company name of the phone such as panasonic it maybe broken or read the instructions
Jun 05, 2014 | Panasonic KX-TG6541B Dect 6.0 Plus Digital...
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
Caller ID not functional in Model KX-TG-9331T and 9332T
Do you have the converter that converts your caller id to U.S. caller id?
Mar 15, 2010 | Panasonic KX-T7633 Corded Phone
Can I register a panasonic kx-tg55438 handset to a kx-tg5622 base
No, The kx-tg 5622 uses only the kx-tga560 (2 of them) for its cordless sets
Jan 07, 2010 | Panasonic KX-TG5622 Phone
No ringer sound panasonic KX - TG 7200 BX
not that I am aware of . usually just buy a new phone and be done with the non functioning one .
Jan 16, 2009 | Panasonic KX-TGA101S Cordless Handset
Panasonic kx tg7200fx and kx tg 1100 compatible for use in intercom
A few days ago I bought Panasonic KX TG1100 - but the base unit does not ring - only the handset!
Can I do anything about it?
Nov 08, 2008 | Panasonic KX-TG2357 Cordless Phone
KX-TG 1100SP CALLER INFORMATIONNOT DISPALYED
check page 18 from your user guide (or at "http://phone.manualsonline.com/mdownloads/2a9697eb-f1f9-a434-457a-98ab6de1d9cc.pdf" if you don't have the book), your security code may not be set. good luck!
Feb 26, 2008 | Panasonic KX-TG1100 Cordless Phone
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Feb 08, 2008 | Panasonic KX-TG6702B Twin Cordless Phone
GE 25931 Trio Cordless Phone Logo
27 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
