Question about Hardware & Accessories
Storm Door Attachment
I have a storm door and the connection at the top will not stay tight enough and the window continues to blow it open. the actual mechanism does not stay tight enough to keep the door tight enough to close all the way. I keep trying to tighten screws but am wondering if I need to adjust the hinges or something else.
  • aaronwalton Feb 11, 2009
    yes, on the door I have the option of one tight screw hole or a oval shaped opening to put the screw into. Neither one makes things line up right.
  • Dwayne Bowers May 11, 2010
    Is it the top hinge that will not stay tightened? This could cause alignment problems that would cause the door to not operate properly.
  • 547 Answers
You need to shim in the frame of the storm door
Posted on Feb 11, 2009
Door sticks terribly...
First check to make sure that the hinges are securely fastened to the door jamb. Gently try to tighten all screws but be careful not to over-tighten or strip the screw heads. It's possible loose screws could be causing the door to hang slightly making it fit improperly into the door jamb.
It's also possible that the door frame isn't 100% "true" and it could be causing the storm door to get caught along the top or bottom edge. You can check with a level to make sure that both sides of the door are plumb (perfect 90 degree angle). You can also use a carpenter's square to check that all of the interior angles in the door jamb are 90 degrees respective to each other.
If everything is square then it could be that the hinges on the storm door are not aligned properly. With the storm door slightly ajar use a level on the vertical edge both at the top and the bottom. It should, ideally, be the same as the door jamb. If it's slightly off you could try shimming either the top or bottom hinge as necessary to even the storm door until it is aligned with the door jamb.
If you find that your door jamb is not "true" then you may need to consult with a carpenter or storm door installation expert to find a way to trim your storm door or refit it for easy opening and closing. Many older homes settle over time and sometimes door jambs slip out of alignment. The door itself may still open and close as usual but it may have sufficient gaps on all sides to prevent it from getting stuck. The newer storm door may be too tight a fit and catching on a door jamb that has settled out of true.
Feb 27, 2015 | EMCO Door. Forever 36 in. White Composite...
Sping in Emco storm door latch broke
I found a video that may help you listed below.
Best Regards my friend!
Mar 04, 2014 | EMCO Door. 300 Series 32 in. Bronze...
Can not adjust closing pressure to latch storm door when main door is closed.
Good and Bad
Good, you have a great seal.
Bad, creates pressure not allowing air the escape.
Adjust with main door open and most times screen will close after a long time.
Nov 04, 2013 | Wright Products Tap-N-Go White Screen and...
I bought a Stanley Screen & storm knob door latch recently (74-8258). The "spindle" connecting the inside and outside handles seems to "float", i.e., not be anchored in place. It seems that with repeated...
If the spindle is installed correctly, "floating" does not hamper proper operation. Review your installation and make sure the floating spindle is properly sated in the handle and alignment is maintained during the tightening process
Sep 03, 2013 | Stanley Hardware 748257 Black Screen &...
BMW X5 2001 -DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR.
DRIVER OUTSIDE DOOR HANDLE WILL NOT OPEN DOOR. FROZE UP IN ICE STORM AND APPEARED TO BREAK WHEN TRIED TO OPEN DOOR. INSIDE HANDLE STILL WORKS. IS DIY REPAIR FEASIBLE?
Jun 23, 2009 | 2001 BMW 5 Series
Craftsman garrage door opener not operating after thunder storm
If you had an lightning storm you most likely have a bad logic board. That is not a reset button you are pressing.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Hardware & Accessories Logo
344 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
