Pioneer AVH-P5000D Car DVD Player
Problem for Pioneer AVH-P5000D Car DVD Player
Parking brake bypass
By surfinrulz25 on Feb 11, 2009
how do i bypass the parking brake sensor for this head unit. pioneer avh 5000
Solution #1
posted on Feb 11, 2009
Somewhat Helpful)
Shadowmaru
Rank: Wiz
Rating: 86%, 18 votes
Tie the Parking break sensor to the ground wire, or ground it to a piece of the frame and your done ;)
Was this helpful?
Yes
No
Solution #2
posted on May 08, 2009
Not Rated)
abacadabra
Rank: Apprentice
Rating: 0%, 0 votes
The unit needs the parking brake to be set, released, then set again. So you need a 2 prong toggle switch connecting a) parking brake and b) ground. When you turn on the unit, flip the toggle up, down, then back up to trick the unit that the parking brake has been set, released, then set again.
Was this helpful?
Yes
No
Solution #3
Not Rated)
Shuttle83
Rank: Guru
Rating: 85%, 981 votes
Hello surfinrulz25,
There should be a cable which is marked to go to the parking brake. Take this cable and connect it to ground and that will bypass the parking sensor. Some manufactures have gotten hip to this and have installed circuitry that senses a hard ground so what you have to do is install a toggle switch between the sensor cable and ground. using the toggle switch you can then simulate the actuation of the parking break, by throwing the switch on or off.
I have to say this in order to protect myself: I do not recommend that you do the above procedure, because it creates an unsafe driving experience for you and those who share the road with you.
If you need further explanation post your question.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Was this helpful?
Yes
No
Popular Solutions for Pioneer AVH-P5000D Car DVD
Questions and Unsolved Problems for Pioneer AVH-P5000D Car DVD
Do you recommend Pioneer AVH-P5000D Car DVD Player?
Answer
Answer
hi i have a pioneer avh- p5100 and i wanted to update it so i can change the background i heard u... (More)
Answer
Can an avh-p5000dvd be unlocked for multi region
Answer
Whem I play music on my AVH- P5000DVD a beeping sound starts in the background. When I pause the... (More)
Answer
hi i have a pioneer avh i can listen mp3 but can not watch videos from usb flash disk in my car.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Pioneer AVH-P5000D Car DVD...:
Top Car Video Player Experts
Rank: Guru Guru
Solutions: 14801
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Car Video Player Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
