Question about Lexmark X1240 All-In-One InkJet Printer
Lexmark stoped working
My printer won't communicate to print. It stopped about a week ago out of nowhere
  • Lexmark Master
  • 19,396 Answers
Try first doing a system restore to a date before you starting with this problem.
To do system restore go to
Start button>>Programs>>Accessories>>System tools>>System restore.
If thet does not work test the USB cable first.
If you find no problem reinstall printer drivers from the disk that came with the printer.
If you do not have the disk you must download the software from Internet, follow instructions below,
Click here:Official Lexmark Drivers and Software
A web page will open, follow instructions, select model, select operative system etc., and click on download .
Chose to download the file in my documents when asked.
After downloading, find the file,double click on the file ,then if you get in troubles, follow the instructions below to reset and reinstall drivers:
  • Unplug printer USB.
  • Go to control panel >> installed printers in Windows and remove (delete ) any installed printer from printer list.
  • Download driver from website, or use the disk and run the install file.
  • Follow driver installation wizard.
  • Plug back printer when prompted from installation wizard.
Posted on Feb 14, 2009
My 9500 series Lexmark won't print, computer says its not communication
1. Check your printer to be sure your printer is listed as installed
2. If the print queue is full it can become confused and just hang up so turn off the printer to empty the queue
3. Power up the printer and send one document to print as a test
4. If the printer works, you should be back in business
Jan 20, 2013 | Office Equipment & Supplies
Put brand new lexmark 28 cartridge just 4 days ago. Maybe used 10 times. Computer says ink is low and won't print anymore. However, can still make copies.
It could be just a slight communication failure between your cartridges and the printer. Try to re-seat the cartridges by removing and re-inserting them into the cartridge carrier.
I hope this helps.
Mar 02, 2012 | Lexmark X2500 All-In-One Printer
"Communication Not Available" message is displayed
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Unplug and re-plug the printer into the power source to reset it.
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list again, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at . Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 16, 2011 | Lexmark X2670 All-In-One Printer
Keeps pausing job won't print. also won't scan... "can't load application" scans only to flashdrive.
Your firewall could be blocking some printer communications. Make sure to allow full access to all Lexmark and printer communications in the program rules/permissions for your firewall. For more information on how to configure the settings for your firewall, visit the Lexmark website at http://bit.ly/iNwkNs.
May 14, 2011 | Lexmark X4650 InkJet Printer
Lexmark X1150 printer copier scanner stop working with new comp.
that a usual problem among printer that cannot print of a vista OS..I suggest that you will use a windows XP .
May 14, 2009 | Lexmark X1150 All-In-One InkJet Printer
Printer stoped printinting
Hello there,
I think the correct printer is not selected on your computer. All you need to do is to go to Start > ControlPanel > Printers & Faxes > and check if you see multiple printers over there. If you do see multiple entries then right click on your lexmark printer and then select "Set as default printer" Once this is done, you can try printing a document to see if that works! In case if it still fails to print, you can try selecting the other printers listed in the printer & faxes folder as the default one and try printing. If you are still not able to print, I would suggest you to try uninstalling the program > restart your computer and then install the software once again.
Merry Christmas
Dec 24, 2008 | Lexmark Office Equipment & Supplies
Lexmark C1150 printer doesn't print
First I try to uninstall the printer, it didn't work, so I reinstall the the printer anyway, it worked for one print only.
As second attempt I disconnected the printer completely, turned the PC off, and after few minutes on again. Uninstalled printer.
Reconnected the cables again, install the printer - it works well!
Dec 05, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark x75
I DONT HAVE CD PROGRAM THE MY LEXMARK X75 PRINTER
Jul 11, 2008 | Lexmark X75 All-In-One InkJet Printer
Lekmark x9350
Try first doing a thorough clean of all printheads, cartridges too, then unplug all usb and power cords after turnig off. replug all and try again. I f no better, uninstall and reinstall printer.
Aug 12, 2007 | Lexmark X9350 All-In-One InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
