Question about Cortelco (050044VBA20M) Corded Phone
Blank center dial label
How do I insert the blank center dial label. I received the rotary dial phone and it was not in place. Thanks...
    President:
  • 2,559 Answers
Just line the snaps up with the slots and push it in until it snaps into place.
Please rate this a fixya.
Posted on Feb 11, 2009
How do i get code for bluetooth
First make sure that Bluetooth is on on the CDE-143BT. Press and hold Audio/Setup (below and to the right side of the rotary encoder dial until you enter the Setup mode. Use the rotary dial to get to Bluetooth. Press the Search/Enter button (the center of the rotary dial). Then use the rotary encoder to go through the Bluetooth Settings menu. Press Search/Enter to toggle the current value. After Bluetooth is on, go to Visi M setting and make sure that it is on. Now, you need to go to the Bluetooth settings area of your cell phone when it is within range of the receiver. Tell it to pair with the receiver. Then when it asks for the code enter "0000". This code is hard encoded into the unit. See page 23 of the manual for the CDE-143BT for the code. The manual is available here: http://vault.alpine-usa.com/products/documents/OM_UTE-42BT_CDE-SXM145BT_CDE-143BT_EN.pdf . Surrounding pages show setting the other Bluetooth settings.
Note: the receiver will be acting like a Bluetooth headset. That's why you need to enter the receiver's PIN on the phone.
I hope this helps.
Oct 10, 2014 | Alpine CDE-143BT Advanced Bluetooth CD...
Why won't replica rotary dial phone works well but won't ring on incoming calls
Whats a rotary phone? J/k we're not that old yet.
Because phone systems are no longer analong. The way a rotary rings is by an increase in line voltage.
Aug 08, 2014 | Toscano Design Pay Phone Pop Rotary Dial...
When I dial out on my 1983 darth vader speakerphone all I get is a busy signal. Anyone have any idea how to fix this?
This phone was made when most phone companies were still using non touchstone systems. When you dial you can hear it simulate an older rotary dial phone. This was how the earliest touch button phones worked. I am not sure the phone company''s systems are still compatible with the rotary systems. Mine does the same thing when dialing out, but receives a call perfectly.
Sep 30, 2013 | Vintage 1983 Darth Vader Speakerphone...
I want to divert calls to my mobile from my Samsung KPDCS-12B LCD
  1. Push either 72# or *72. Dial 1172 on a rotary phone.
  2. Listen for dial tone.
  3. Dial the number to receive your forwarded calls
  4. These steps allow you to forward your calls..
Mar 04, 2011 | Lands Phones
Model UNIDEN UCIS-225 - Phone suddenly dials like a rotary phone. Does anyone know how to make it return to the non-rotary dialing?
two places<br /> 1. Manual switch on back of phone Tone or Pulse<br /> 2. Menu-Set Dial Mode - DTMF (tone) or Pulse
Aug 05, 2010 | Uniden Lands Phones
I have an old ITT series 500 rotary desk phone and need to get the faceplate off to put a new phone # under it. How do I take the faceplace off?
Oh stop it! Just buy a new phone LOL
This is really testing my memory, but grab a paper clip and straighten it out (you don't want to have to buy a dial tool for one phone, do you?).
Here's the trick. Rotate the dial to the 0 position and look under the finger stop in the center ring! Ooh, see that hole? Push your paperclip into the hole and keep rotating the dial clockwise.
Now, to put it back, slide the dial back in so that hole for the 1 is between the 1 and the finger stop and turn it counterclockwise until it snaps into place!
Yeah, I'll sell you my dial tool for $5 bucks :-)
Carl
Nov 22, 2009 | ITT Lands Phones
LG 3300 Screen gone blank
You will need to take the phone to a mobile service center and have them check your lcd and flexcable
Mar 12, 2009 | Cell Phones
I need to retrieve my home phone messages from cell phone
Activating Call Forwarding
You can activate Call Forwarding whenever you want your calls to be sent to another phone, including a mobile phone. Once activated, all your calls will be sent to the forwarding number you request. Each time a call is forwarded, you will hear one short reminder tone on your home phone, but you will not be able to answer the call from your home number.
1. Lift your telephone's receiver and listen for a dial tone.
2. Press *7 2.
In some areas you must use 72#
Dial 1172 on rotary or pulse-dialing phones.
3. At the tone, dial the telephone number where you want your calls transferred.
You will hear the number you entered ring. When the number is answered, Call Forwarding is activated.
4. If the call is not answered or the line is busy, hang up and call the number again within two minutes.
You will hear two short tones telling you that Call Forwarding is activated.
5. Hang up the receiver.
Deactivating Call Forwarding
Turn Call Forwarding off when you want to receive calls on your home phone.
2. Press * 73.
In some areas you must use 73#
Dial 1173 on rotary or pulse-dialing phones.
3. Listen for two short tones.
Call Forwarding is now off and you will receive your calls at your home number.
Dec 01, 2008 | Uniden Cordless Phone
Inside and outside screens are blank..
My V3 doesn't work either, the screen randomly turns on occasionally but try taking out the batery and the sim card and they inserting it back in. If this doesn't work i suggest taking the phone back to the place where you brought it. Hope this helps!
Dec 11, 2007 | Motorola Mobility RAZR V3
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Cortelco (050044VBA20M) Corded Phone Logo
174 people viewed this question
Top Cortelco Lands Phones Experts
Are you a Cortelco Lands Phone Expert? Answer questions, earn points and help others
