Question about Lexicon Lambda Usb Desktop Recording Interface Sound Card
I only get audio sound out of one speaker using my lambda
Only one side of the pek gose up when i talk in the microphone
  • tr3sb Feb 14, 2009
    yeah i have the same problem but i found out is if you plug the mic into the top number on slot the left ear records if you plug it into the bottom slot the right ear records i think it has sopmething to do with the speaker slots inbetween can anybody help us on this do we need the large speakers in order to record?
  • Stallion608 Mar 24, 2009
    I HAVE THE EXACT SAME PROBLEM AND IVE RE DOWNLOADED AND DID EVERYTHING AND I DONT THINK MY MIC IS BAD IS THERE ANY OTHER REASON FOR IT
You need to ensure that youre recording in Mono. When adding a track in cubase a prompt appears that asks you about the configuration [stereo or mono] make sure its set to mono. Also make sure that you press the monitor button on the front panel so that its pushed in (mono setting). And finally beware of your monitor mix settings... If youre listening via the headphone jack on the front panel, the monitor mix needs to be turned all the way to the left (ie Direct).
Posted on Apr 04, 2009
    Problem Solver:
  • 5 Answers
The mic. cord that is in it you might need to twist and push in harder
Posted on Feb 11, 2009
Noise when talking on skype
When using services like Skype or VoipBuster the audio is compressed. Depending on the quality of the internet connection the audio quality will be different. If you or the person on the other side of the line has a bad internet or bad WiFi connection, the compression of the audio will be much stronger, resulting in a worse audio quality.
Another problem that occurs many times is an audio feedback. If you, or the person you're talking to uses a microphone and computer speakers, the audio coming out of the computer speakers can be captured by the microphone and be amplified again. It forms a feedback loop and creates an echo. The best thing to do is that you both use a good quality headset instead of putting the audio over computer or iPad speakers.
For your iPad, you can buy the Apple EarPods. They are affordable and contain a microphone to make Skype calls with your iPad.
You own a iPad, which is a device of high quality. If the person you're talking to has a crappy phone or bad hardware, the quality will be bad. The advice then is that that person buys a device that has a higher quality than he or she is using now.
I hope my advise will solve your problem.
Feb 12, 2014 | Apple Ipad I-pad
Skype not working
Sir,
Click this link for more information........
http://support.skype.com/index.php?_a=knowledgebase&_j=questiondetails&_i=35
Also Check........
On a PC with external speakers and also a headset with microphone. Windows XP is configured so that standard audio are external speakers and standard microphone is the headset. Skype is configured to use the headset for audio in and out.
This way one can listen to sound from the PC and from MP3 players through external speakers and if there is a call to make or take, this is going through the headset.
But now there is the problem that the noise level for the headset is too low. Increasing volume has no effect on the headset, it only affects the external speaker's volume.
Now the solution: Going to the control panel and opening the sound setting, go to the audio tab. The external speakers are selected as default. Just temporarily select the headset and then click on volume just below. You can now set the volume for the headset, click OK and click cancel (!!!) on the sound control dialog box. This way the external speakers remain as default output.
Skype-->Tools -> Options -->Sound Devices-->audio device/USB/etc Audio Device (do NOT use windows default device)
You can also tick the ring pc speaker check box as this is a good backup to alert you even
if the main speakers are off or turned down.
Windows:
Start-->Control panel-->Sound and Audio devices
On the audio tab set the default playback device to your main soundcard(AC97/Audio-chip/add-on-adapter), etc.
Your installed audio device must be present there.
If not, reinstall audio device
thanks
good luck
Oct 29, 2008 | Altec Lansing Stereo Headset with...
I need to knowwhat phono leads I need to connect pc to tv -sound to come out of tv-Ive a medion pc? WHERE do I connect the leads on the pc?
Normally 3 standard sockets for audio, line in, line out and mic in, that are coloured blue green and pink respectively, for audio out connect to green socket (3.5mm jack plug)
May 11, 2010 | Medion MD-1704 PC Desktop
I Installed the Lexicon Lambda and followed all of the instructions to the letter. I can hear sound out with no problem, but when I record, it records from my laptops internal mic. Thus, everything in the...
You will need to go into your sound properties, you can do this by clicking on the speaker Icon thats down by the clock (lower rights hand side of your screen) that should bring up sliders for everything.
Their is also other options and advanced options you may need to enable that could be specific to your devices. but the main thing here would be for you to disable the one mic and enable the one you want and also possibly lower its sensitivity levels.
Apr 17, 2009 | Lexicon Lambda Usb Desktop Recording...
Gravely distorted sound on recording
You have to download updated audio codec for your system. Go to this link:
http://www.free-codecs.com/XP_Codec_Pack_download.htm
Download it. When a box appears, Click Run button.
Best regards
Jan 02, 2009 | Lexicon Lambda Usb Desktop Recording...
Lexicon Lambda on Mac
Hi, I just bought one today and am using a condenser mic through the lamdba. I booted up apple logic - plugged in the device and it found it as a usb audio device. You need to use the headphone jack on the lamdba. good luck
Dec 26, 2008 | Lexicon Lambda Usb Desktop Recording...
Skype
Audio Setup for Windows XP and Vista
1. Audio settings, in Windows and Skype
XP: Windows Control Panel / Sounds, Speech and Audio Devices / Sounds & Audio Devices
or Right-click speaker icon in system tray and select "Adjust Audio Properties"
Volume / Device Volume: Make sure “Mute” is NOT checked in this window.
Volume / Device Volume / Advanced: If there is no “Microphone” section in this window, go to Options / Properties and check “Microphone” in the “Playback” list. Then make sure “Mute” IS checked in this window
Audio / Sound Playback: Your on board sound/Sound Card
Audio / Sound Recording: Your on board sound/Sound Card
Audio / Sound Recording / Volume: Make sure "Microphone" is selected and the volume slider is at the center or higher
Audio / Sound Recording / Volume / Advanced: If “Microphone Boost” or “20db Boost” is present, select it
Vista: Windows Control Panel / Hardware and Sound / Sound / Manage Audio Devices
or Right-click speaker icon in system tray and select "Playback devices"
Playback: Your speakers or on board sound/Sound Card must appear in this list, and must show “Working”
Playback: Select your speakers or on board sound/Sound Card, then click “Set Default”
Playback / Properties / General: Device Usage: “Use this device (enable)”
Playback / Properties / Levels: “Mute” is not on, volume slider in the middle
Recording: Your Microphone or on board sound/Sound card must appear in this list, and must show “Working”
Recording: Select your Microphone or on board sound/Sound Card, then click “Set Default”
Recording / Properties / General: Device Usage: “Use this device (enable)”
Recording / Properties / Custom: If “Microphone Boost” is present, select it.
Recording / Properties / Levels: Microphone volume should be centre or higher
Recording / Properties / Levels: If there is a “Mute” button, it must not be on
Skype / Tools / Options / Audio Settings:
Microphone: Your headset/mic or USB device or Web cam mic, as you prefer
Speakers: Your headset, USB device or speakers, as you prefer
Ringing: VoIPVoice USB Phone or on board sound/Sound Card; also tick Ring PC speaker
Note: The audio devices you want to use MUST be present in these Skype device lists. If they are not, check the device connections and driver installations again.
2. Microphone and Speaker connections
Check if your mic (pink) and speaker (lime) jacks are in the proper sockets (it is easy to reverse them) and fully inserted (they sometimes stick only partially inserted)
If your microphone or headset has a “Mute” switch, make sure it is not on
If your speakers or headset has a volume control, make sure it is turned up
For test only you can use an earphone instead of microphone (really)! Just unplug the microphone, plug the earphone into the microphone jack, and talk into your earphones. (I know it sounds silly, but it might tell you if your microphone is defective)
A standard microphone plugged into Line In will NOT work.
3. Check audio in Windows.
XP: Start / All Programs / Accessories / Entertainment / Sound Recorder
Vista: Start [Orb] / All Programs / Accessories / Sound Recorder
Make a short recording with the microphone; you should see the level meters moving as you speak. On Windows XP, you can then play back what you recorded.
4. Once done, test with Skype Test Call (echo123).
Oct 19, 2008 | Computers & Internet
Lambda lexicon sound problems: is vista the cause?
I have had the same problems with the lambda driver ...they just posted a new installer on the lexicon website which fixed me up...try it.
Jul 16, 2008 | Lexicon Lambda Usb Desktop Recording...
Audio feedis crossing with my speaker feed with and without the microphone plugged in.
Your mic still picks up sound when it's unplugged ?
As far as the other prob goes that sounds like howl round ( feedback ), mute the mic when not talking through it or get a mic with a cardioid polar response pattern ( just ask for a cardioid mic, can get a hypercardioid or supercardioid too but a cardioid would be best for your application, point the mic right at your speaking position with the back of the mic pointing at the speakers wich ideally should be behind the mic, this will help cancel out their sound, puting a limiter on the mic and setting it where it only starts picking up sound when you talk directly into it will help too, but the sure fire way to solve the prob is to mute the mic when not speaking into it. What you definitely don't want is an omnidirectional mic, for what you are using a mic for.
Jun 10, 2008 | Logitech Labtech Verse 524 Microphone
Microphone and speaker problems
Do a virus scan first FREE ANTI VIRUS Try here its free http://www.kaspersky.com/kos/eng/partner... If you can not access or open IE right click in and select Properties then set the homepage to Blank! SOUND RECORDING\MIC ON USB CAMERA In Windows XP Select the proper Audio Input Device (Sound Recording) under the Audio Tab in Sounds and Audio Devices in Control panel. Usually it is name after the USB Camera. CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. CLEANING Using a dump clothe. Wipe the plugs with a twisting motion. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester.
Sep 20, 2007 | Audio Players & Recorders
Lexicon Lambda Usb Desktop Recording Interface Sound Card Logo
393 people viewed this question
Top Lexicon Computers & Internet Experts
Tony
aftab Nawaz
aftab Nawaz
Alun Cox
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
