Question about Peavey EQ215FX Home Equalizer
Eq on channel a doesn't work on 2 units
I have been having a loud hum on channel a of Peavey eq215's. when I hook into channel b it works fine. Why doesn't channel a and b work together on either unit. Peavey CS 800 and a Crown XLD802 into Peavey eq 215. one per amp going into a PV14 board.
  • Eric Grantham Feb 16, 2009
    Thanks, I'll get it checked, just didn't want it to be something really simple
    Genius:
  • 1,175 Answers
It could be an internal ground connection on the EQ that's broken ( maybe inside the connector) ..I repaired numerous peavey products and broken grounds are common.
Posted on Feb 16, 2009
When setting up xr8600 is it best to start mains and monitors master at 0DB?
1. Turn the main and monitor volumes all the way down (off). Plug a cd player into channel 9/10 and play a track of music of your liking. With the main/monitor volumes still off, adjust the gain on 9/10 until the clip light turns on, then back it down until the clip light just turns off. Put the channel volume at 12 o' clock.
2. With the music still playing, turn up the mains to the desired listening level first, and then adjust the graphic eq until the music sounds good in the room. Remember or mark the position of the volume control. Do not use the channel eq on 9/10 for music that has been mastered properly, leave the eq flat. Once this step is completed then you have now set the main eq.
3. Repeat the same for monitors. Turn off the main volume and then bring up the monitor main volume to the desired level first, then set eq. Now your monitor eq is set properly. Remember or mark the position of the monitor volume.
4. Set up microphone - plug a mic into channel 1 with volume all the way down. Speak or sing into the microphone and adjust the GAIN until you see the clip light, then back down a litttle on the gain. Put the monitor and main volumes back up to the mark from step 2. Now adjust the volume and monitor send on the mic channel to the desired loudness first before adjusting the mic channel eq. Use subtractive eq method to minimize distortion and feedback. ...i.e. if the mic is bassy then turn down the lows, do not ADD highs. If the mic needs bass, turn down the highs.
Jun 08, 2014 | Peavey Xr 8600 8 Channel Powered Mixer
Peavey Ecort is working fine but has a loud buzzing that slowly gets
This is often caused by the failure of the large capacitor(s) in the power supply. The noise being the 50/60hz mains hum getting in. They will be the biggest Capacitors in the system with a value around 4700UF or greater, so you can't fail to see them.
Jun 14, 2013 | Peavey Audio Players & Recorders
I have the Nitro BMWX 483 4 channel amp, BMWX 484 2channel amp , and I have the Nitro BMWX 424 4 band EQ !! Now what I'm trying to do is hook up both amps together to the EQ ! So far, I hav the BMWX...
From what I have read about this EQ it is just for subsonic frequencies. You really don't want to run your components through this EQ. Leave the components running off of the 4 channel amp and your sub box on the two channel with the EQ in series between your head unit and the sub amp.
Jun 30, 2011 | Nitro BMW-483 Car Amp
I have a peavey 1220 powered mixer and I'm trying to hook up to two sp15's top's and 2 18; peavey subs for my band and I can't get the bass seperated so it's out of my tops
Hi. The mixer puts out a full range mix, the solution is in your speaker setup.
Many subs have a built in crossover that splits the signal for the tops. Check your sub specs or manual. If your subs have this, run your output signal to them first and then link them to the tops from the special daisychain socket.
If they don't have one, you can install a passive crossover to your subs or buy an external crossover unit.
The last (and not very good) option is to fake a crossover with the desk's stereo EQ. Connect the subs to the left or right channel and the tops to the other and use the EQ to remove the bass from the tops and vice versa, pan everything dead center. Obviously this sacrifices your stereo sound and isn't brilliant.
Jun 29, 2011 | Peavey XR 1220 Powered Mixer Mixer Powered
Peavey 115 Low hum Low volume from input
The preamp section has a problem. It could be anything in the preamp but is OFTEN the input jack itself. They take a lot of abuse.
Also the insert jack contacts that forward the preamp to the power amp if no external FX are used can go bad.
Additional things are circuit board cracks caused by rough handling and also controls that have had the knobs mashed in which can destroy the potentiometers they are connected to.
Sep 19, 2009 | Peavey Music
Peavey sound board 2 channels not working
check for cold solder joints from the input jacks and the fader. If any look suspicious (dull or grainy) re-solder.
Apr 29, 2009 | Peavey Pv 2600 Power Amplifier
How can I hook up bose 901's to onkyo tx-sr876
Assuming you really want to have a working surround system you will need a separate stereo amplifier for the 901's to accomodate the need for the Active EQ. There is no way to separate your receiver's front L&R channel preamplifiers from their amplifiers.
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 110W for mine and it ahs plenty of steam for the 901's.
For connectiuon I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ';s Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
Not what you might want to hear but 901's have special requirements. I've had mine for 25 years and have no regrets.
Mar 09, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 hook up
I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds. You would probably just get a nice 2-channel amplier for the 901's. However, the TX-SR606 doesn't provide power for a Subwoofer, should you decide to get one, so you would need another amplifier channel for that, too. Therefore, you might look around for a powerful 3- or 4-channel amplifier so you could drive the Sub, too.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. I'm using only 100W for mine and it has plenty of steam for the 901's.
For connection I would run a pair of RCA cables from the Front L&R Audio Line OUT to the Active EQ's Line IN; then the EQ';s Line OUT to a separate amp's Line IN. Attach the 901's to the new amp, run through the receiver's setup procedures for volume, etc and you're done.
A seperate subwoofer channel on the amp could be used. Just run a single RCA channel from Sub OUT to one available channel IN on the amp and attach the subwoofer to it. Two would work, also. That's what I do. You could use a 1-2 RCA splitter to feed two avaailable channels on a 4-channel amp. The iterations are many. Have fun.
Feb 28, 2009 | Bose 901 VI Main / Stereo Speaker
How to hook the eq up??
take output from left and right from equalizer and go to line in any two channels inputs in peavey mixing console and adjust your level with faders and other control knobs.
Mar 02, 2008 | Phonic PEQ3400 2x15-band Graphic Equalizer...
Peavey Compressor/Limiter and Peavey 3/4/5w Crossover
The correct order is Mixer>EQ>Compressor>Crossover>Amps>Speaker. Here is the link that helped me out. Scott's PA System Tutorial
Feb 13, 2008 | Peavey CROSSOVER, STEREO 2-WAY/MONO 3-WAY,...
Peavey EQ215FX Home Equalizer Logo
309 people viewed this question
Top Peavey Audio Players & Recorders Experts
 Grubhead
Grubhead
Steve
shaqsatin
Level 1 Expert
Are you a Peavey Audio Player and Recorder Expert? Answer questions, earn points and help others
