Question about Apple iMac G5 Desktop
Can't click and drag
Reconnected my keyboard and mouse on my G5 iMac that I just got back from the shop. I can double click on an icon and open it, but can't drag a file (e.g. like to the trash)
  • Luke Kim
    Luke Kim May 11, 2010
    I need more information on the issue you are having. The only thing i can get from your explanation is that you connected an external keyboard and mouse to your G5 iMac (17" or 20"??) and you can't click and drag an icon to and fro anywhere on the desktop??
    "I can double click on an icon and open it..."
    - First question is if you move your mouse from left to right or up and down rapidly or slowly, does the pointer move look as if it is attempting to move or is it just there unmoved? Because with your next part of your sentence "...but can't drag a file...(e.g. like to the trash)" says to me that you are not able to move the mouse to where you would like so you can relocate a file. Is this correct?
    = If above is YES, then next question i have is the reason you had it returned to you by the "SHOP" the same reason or similar to the issue at hand? And also linked to the question is did the mouse and keyboard work fine before sending your iMac in for servicing or no? If it had worked fine then you should return your iMac G5 to that SHOP and explain to them that you had no issues with the mouse and how it functioned prior to having your system serviced, and explain to them what isn't working as it should be. Since they had touched the internals or not last then they should fix this issue for you as a freebie.
    But i would first try another optical mouse and or keyboard or connect the mouse not through the keyboards hub but direct and see if that clears the issue. If it doesn't, then i would say replace the mouse. But if nothing changes even with a different Mac compatible mouse then do as suggested above.
  • Apple Expert
  • 481 Answers
I suspect you have a wireless mouse. When the batteries get low in an Apple wireless mouse, one of the prime symptoms is that click works but drag doesn't, or vice versa. Replace your batteries.
Posted on Sep 19, 2009
Copy and paste for dummies
You're following instructions for an IBM-style machine and mouse. You need to be reading instructions for Apple. Often their version of a 'right-click' is to double-click, but it depends on the program. Read your manual about using your mouse, and always look for Apple-specific instructions for any program or application you are using.
Aug 14, 2014 | Apple Imac 17" Desktop G5 2ghz 512 Mb Ram...
How to wake up an imac
clicking the mouse
tapping any key on keyboard
by pressing the power button lightly
Jun 25, 2014 | Apple iMac G5 Desktop
How to force spit CD from drive
A few ways of doing this
1) restart mac and press down the mouse button after you hear the startup noise
2) if that does not work try opening up disk utility and click on the icon of your disk under the left hand column then go up to eject button and click eject
3) or open up terminal found in the utilities folder within your applications folder and then type in
drutil tray eject and then press return
4) Finally what to do is try pick up your imac tilt the
imac to the one side and press the eject key and hopefully the effect of gravity will allow the CD to fall out.
However, I would say that DVD drives in all macs are a bit suspect and if
your macbook is still under warranty or under AppleCare take it back to the Apple Store and tell them that the DVD drive is faulty and they will replace it free off charge.
If it is out of warranty there is one other way to do it which I have used recently but IT CAN BREAK THE DVD DRIVE (Use it at your own risk), so only use it as a last resort. Get a thin piece of plastic (or credit card) and put a piece of double sided tape on it then with the macbook switched off insert the piece of plastic with the tape facing down in relation to the keyboard. Put it in about half an inch and you may be able to drag the DVD out.
Hope this helps.
Dec 10, 2012 | Apple 2.16GHz iMac Intel Core 2 Duo...
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Sep 11, 2010 | Apple iMac G5 Desktop
The desktop files on my mac G5 won't open when I double click. My son was recently using it and I don't know if he reset or changed settings that would cause this.
One of 2 things...
One, the app used to open the files is missing or not found.
Two, the extension was removed from the file.
Try holding the Option Key while dragging the file on top the application's icon. This will force it to open.
Aug 28, 2010 | Apple Power Mac G5 Desktop
The icons on the desktop are not responding to the cursor
Do you have a wireless mouse? A common symptom of a weak battery is that move works but click doesn't, or vice versa. The solution is to change the batteries in your mouse.
If this is not your problem, please provide more detail.
Jun 24, 2010 | Apple iMac G5 Desktop
I bought an imac g 3350 . never had a mac before
Download your program. Make sure it is for YOUR OS. A .dmg should appear on your desktop when it is finished. Double click that. It should open a file with an application icon and a drive icon on the desktop. Open your applications folder from your hard drive, then drag the application icon to that. Eject the drive icon from the desktop by dragging it to the trash.
Jan 05, 2010 | Apple iMac G3, G4 USB Keyboard 9224078
My Logitech LX5 wireless optical mouse has never worked properly
hi im josh in cebu phils.may i help you? Friend try my gathered solutions. This problem has a simple solution—replace your batteries! Low batteries in a wireless device will cause all sorts of problems. In a mouse, this typically means that the cursor slows down, jerks around, or seems to hit an invisible wall. Fresh batteries should fix things right up.
If new batteries don't fix the problem, you have some sort of wireless interference. Try moving the wireless receiver to a new position—preferably away from other wireless devices (wireless network adapters/base stations, cordless phones, baby monitors, and the like). If interference continues, see if you can change transmitting/receiving channels on one of the devices, or consider turning off the interfering device while you're computing. Good luck friend hope i helped you.
Mar 04, 2009 | Logitech LX5 Cordless Optical Mouse
Double click problem
in most cases the best thing to do is to change ur mouse, but i would also suggest u try to use a mouse pad, some paints have a problem when using optical mouse
Feb 18, 2008 | Logitech LX7 Cordless Optical Mouse
Apple iMac G5 Desktop Logo
1,094 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
