Question about Toshiba Tecra M3 Notebook
What's considered "normal mode" for batteries?
I am trying to reset my Tecra M3 to "normal mode" for the battery as I have a new battery and need to test the life of the battery.
Any suggestions?
Thanks!
  • amy_schofiel Feb 11, 2009
    Perfect...thanks!
    Master:
  • 413 Answers
Try this..
Start menu>control panel> User accounts
Create a new user and go back into the control panel and see what the power options are. When you create a new user it has no memory of the power options you set. Look at the settings then set your account the same.
Does this answer your question?
Posted on Feb 11, 2009
My toshiba tecra m3 password i forgot what can ido for reset the bios password
You'll find all you need with this down load.
http://www.hiren.info/pages/bootcd
If this information was helpful, Please rate it high. Thanks
Apr 24, 2011 | Toshiba Tecra M3 Notebook
How do I calibrate a battery for a Toshiba Tecra M3? It won't hold a charge. Thanks!
If it won't hold a charge it has either developed memory, which requires a battery conditioner to correct, or it has a dead cell, which requires a new battery. Toshiba has battery conditioning software incorporated into their software and you can usually locate it under Accessories -> Maintenance directory.
Nov 28, 2010 | Toshiba Tecra M3 Notebook
No sound toshiba tecra m3
The Toshiba M3 laptop has an Intel Pentium M 2. 13 GHz processer and 512 MB (DDR2 SDRAM) of memory (although it can support up to 2048 MB). The 36cm XGA TFT LCD screen supports a maximum resolution of 1024 x 768. The internal hard drive can store 80 GB of data. The weight of the laptop is around 2300g and the Lithium ion battery lasts for around 3. 2 hours from a full charge. This laptop has a NVIDIA GeForce Go 6200 PCI Express graphics and has Headphones, Sound card and Speaker(s) audio outputs.
Dec 03, 2009 | Toshiba Tecra M3 Notebook
My Tecra Toshiba will not turn on or off, even plugged in.
Yes it is. And, it is highly recommended that you remove the battery if you're going to use your laptop for more than 1 hour. If you keep your battery in and have the laptop connected to the adapter, the poor battery is going to be charging/discharging so much that its life is greatly shortened. Also, this is what causes dead cells in batteries.
You might possibly have an internal power supply problem.
But, go ahead - remove the battery. See if it helps.
You also might try letting the battery charge for 3 hours with the laptop off.
Oct 12, 2009 | Toshiba Tecra A1 Notebook
Drivers windos 7
You can get download drivers of Toshiba tecra M3 Notebook from this Link.....
http://driverscollection.com/?H=Tecra%20M3&By=Toshiba
Thanks
Aug 17, 2009 | Toshiba Tecra M3 Notebook
Can you please inform me how to perform the ''reset the CMOS'' in a
This will require you some disassymbling the bottom of your laptop and look for a cmos battery, disconnecting it then replug.
Why not consider to clean/reseat it RAM, most of it does not make a unit to turn on when not detected.
Apr 04, 2009 | Toshiba Tecra 9000 Notebook
Reset bios password
Hey dude,
I hope this will work.
just take out the cmos battery from ur CPU located inside it and change it .
Ur password is resetted !!!
sajwhat_2003@yahoo.com
sajwhat@hotmail.com
Jun 13, 2008 | Toshiba Tecra M3 Notebook
Garmin ique 3600 won't turn on after battery goes dead
I had the identical problem; I called Garmin and a new battery = $50, installed only @ the factory. I tried buying one off eBay, but those batteries spec out ok but don't have the pigtail leads required for my M3 (probably would work just fine for M5). I soldered on the pigtail from the old battery from my M3, then put it all back together. Works! However, the new battery ultimately drains down over several hours so when I'm not using it I have to trickle-charge the thing constantly. Bottom line: I suggest sending your M3 back to the factory for a new battery rather than trying to replace it on your own.
Jan 25, 2008 | Garmin iQue M3 Pocket PC GPS Receiver
Toshiba Tecra M3 Notebook Logo
48 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
