Question about Samsung TXE2045 20" TV
Can't tune low channels on Mitsubishi CK-2688R, 1985
TV must warm up before tuning channels 2-6. Only snow + loud static on channels 7-22. Do I need to replace the tuner?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, not yet but could be after test/diagnosis. Initially, you must first determine for the presence/absence of the variable 33VDC tuning voltage. This voltage varies depending on what channel is tuned into thereby setting the VCO (voltage controlled oscillator). In some instances, it could be a faulty/leaked capacitor in the 33V supply or even a zener diode. Faulty capacitors are easily identified by bulging top (normally flat), blistered/split casing, brownish paper within the immediate surrounding, rubber bottom partially out and/or powdery residue on one of the pins. The diode is tested like any semiconductor, forward and reverse bias.
Good luck and thank you for using FixYa.
Posted on Feb 11, 2009
RELENTLESS SNOW
You shouldn't have to have the tv to channel 3 or any other for that matter if you are in component. You need to make sure the tv is on the component input from your display menu that can be accessed from your remote.
Nov 12, 2013 | Mitsubishi VS-60805 60" Rear Projection...
When using cable input video is good but sound has fuzzy static
Your TVs tuner tuned a little off frequency. It could be as simple as having cable box on where you have good picture but fuzzy sound, use the TVs remote to change the channel and then change it back to proper channel. If that doesn't fix you may have wrong tuning type selected in channel set up menu.
Oct 11, 2009 | Toshiba 27A30 27" TV
Mitsubishi TV Channel Tuning/Remote Problems
To restore full functionality to your set you must replace the remote that came with set. Universals only control the most basic of functions.
Apr 27, 2017 | Televison & Video
I am trying to record on my sanyo dvw6000 and all i am getting is snow
"snow" shows that the channel you are recording isn't tuned in, or the av socket is in correct on the tv. Use AV-2 on the tv as this sends a signal out.
May 29, 2009 | Sanyo DVW-6000 DVD Player/VCR
I have a mitsubishi tv that when it was unplugged will not
The set may have reset itself to "air" tuning model when it was plugged back in. Set it for cable tuning (may say "CATV") in the setup menu, rescan your channels and you should be good to go.
Apr 27, 2009 | Televison & Video
Loud static
The set isn't fully tuned into the channel the satellite receiver is outputting on (should be channel 3 or 4). If this set is old enough it may have a fine tuning adjustment that needs to be tweaked a little to clear up the problem. Some Zenith TV's also had a switch to select different tuning systems. If set incorrectly this might happen. If yours has such a switch, make sure it's set to "normal" or "air". It may also be that just due to age the turner isn't working properly.
It might be time to consider replacing that set. A new one would give you all the picture and sound quality your satellite can give you. Right now you're paying for quality you can't appreciate.
Apr 22, 2009 | Televison & Video
Mitsubishi diva cant tune in
well .... no online user manuals for thoseTVs
you will need to use a digital seck top box and use that units remote to tune the TV
if there are any (needs a user manaual)
use the buttons on the TV lower casing
to tune up
none of the all in ones remote buttons work for all TVs functions
you are lucky if it turns on and off
and changes channel
Apr 29, 2017 | Mitsubishi VS-45609 TV
TV Snow and Static Sound
Sound like its all cabled wrong So its from the source, (wall satalight Whatever ) to VCR in then VCR out to TV, Now when the VCR fires up it tunes the RF output to Chanel 4 and has a strong signal, that over rides just about every thing. Simply way to stop this is one of two ways, press the TV/VCR button on the VCR, or simply turn off the VCR to let the signal pass through.
Mar 06, 2008 | Televison & Video
Tv seems ok by static and now, no sound (or very faint)
The problem you're describing sounds like a tuner problem. BUT you say that you have the same problem with A-V input too. That's weird!!! Possibly the electronic TV-AV switching circuit is messed up and stuck in the TV (tuner) position. If this is the case you DO have a tuner problem and a switching problem too.
Jan 14, 2007 | Hitachi C29-F200 29" TV
Televison & Video Logo
102 people viewed this question
Henry  Thomas
Henry Thomas
