Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
We had a ice storm and power was off for nearly two weeks, wont d
After our power was off for nearly two weeks it will make ice, but the dispenser will not dispense ice,
  • 10,865 Answers
When the power was off for that long period of time all of the ice in the dispenser melted. When the power came back on, any water remaining in the ice cube bin froze into a solid block.
If you raise the wire arm up and leave it up, no new water will come into the icemaker. Do that.
If there is a block of ice in the ice cube bin, use a blow dryer to melt it and discard it. Once the ice is gone, spray the auger with some PAM or other cooking spray to lubricate it a little bit.
Finally lower the wire arm down and wait up to 12 hours to get ice making normally again.
Posted on Feb 11, 2009
Samsung Rs2530B frig had power outage, now cubed ice is blinking and water and ice dispensers are not working.
CONTROL BOARD ON REAR PANEL IS MOST LIKELY THE PROBLEM .THIS IS COMMON WITH STORM DAMAGE..
Apr 26, 2017 | Samsung Washing Machines
Control panel for GE PFE29PSDSS
All models that have electronics are easily wiped out during storms due to the sensitive electronic controls on all of the control boards. Your model has the=> WR55X25146 Main Control Board the WR55X11138 Inverter Board and the dispenser control board. You will need to exchange parts until you get the right board. Most likely the motherboard,
Appliance 911 Sea Breeze
Aug 03, 2015 | GE Refrigerators
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Ice maker does not make ice
Is the freezer freezing the contents good?
Nov 27, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Codes flashing on door screen after power blip
You had a power surge due to the storm, unplug the unit for 5 min's and see if it resets the faults.
Jul 09, 2017 | Samsung 24.6 Cu. Ft. 4-Door Side-by-Side...
Ice & Water Dispenser Suddenly Dysfunctional; LED lights, too!
Cory, you sound like you have a bad water valve as well as a bad control board for your dispensor. If you've had any storms in your area in the past 4 - 6 weeks, it's very possible that the storm took both parts out.
We have parts for GE as well as mots other major brands, so please give us a call with your complete model number and we will get your parts out to you right away!
We hope this solves your problem and we look forward to being able to assist you with future issues.
Have a great evening.
Nov 05, 2009 | GE GSS22JF Side by Side Refrigerator
Icemaker stopped working
You will have to determine whether the problem is due to no water getting to the icemaker or a control problem in the icemaker unit.
There is a water valve near the bottom of the refrigerator where water from the outside source enters the refrigerator. This valve sends water to the icemaker (and probably the water dispenser) when the refrigerator controls call for water. These valves can malfunction, and the water lines can get blocked.
The other possibility is that something inside the icemaker controls has malfunctioned, and it is not calling for water.
Oct 18, 2009 | KitchenAid Superba Architect KSCS25INSS...
Ice continues to be made, about a week ago, the part that turns the ice to crush it or dispense it doesn't work, it also takes about 2 minutes when water is activated before it will finally dispense, all...
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again. It it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Aug 21, 2009 | Refrigerators
Condensation on the outside of the ice/water dispenser on freezer side.
Turn the water supply off to the back of refrigerator and take the line feeding the supply to the water control valves off and then put the line into a pan to purge any trash that may have collected before entering control valve. It is very possible that a piece of rust or a piece of plastic is holding the control valve open slightly. The continuous dripping of the chilled water is what I suspect is causing the condensate. On bottom of the refrigerator Sears uses a number like this example. You may find the number behind the cold food section door near floor. I will need that to help you better. Example 215.22897
Sears always gives their models a different number than the same models that GE, Whirlpool, Westinghouse and on and on. When you are able to see if the valve is stuck and need to clean or replace it we will need your model like in the example to find the correct part, Let me know, Thanks, Sea Breeze
May 15, 2009 | Kenmore Refrigerators
No water from water dispenser
wat temp are you runninr in the refrigerator side? it should be at 38 degrees because now days the are using an averaging sensor inside and also if tis any colder yoou will possibly freeze you produce
Dec 25, 2008 | Refrigerators
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
95 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
