Question about Canon PowerShot A400 Digital Camera
E18 Error Let my husband use my camera he said he did not drop it I can see the pictures taken but when I try to take more I get E18 on the screen Power shot a400 but get error message then shuts down. Ive had this camera a few yrs I love it.
  • conniewegman Apr 13, 2009
    Camera will not turn on. gives E18 and shut down by itself
  • nobalc May 07, 2009
    My PS-A400 has the same problem and batteries goes down too fast.
  • Canon Master
  • 4,738 Answers
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try. If there's any consolation, the A400 lens barrel is very resilient in its design, so there is some hope here:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 13, 2009
I have a PowerShot S2 IS Icannot take a picture screen show E18.
E18 is the standard Canon lens error. The lens gets stuck when extending. If you did not drop it and there are no signs of damage you can check with Canon and try to get the camera repaired under warranty.
If it is not covered here are a few methods to try on your own, at your own risk.
http://www.e18error.com/repair.html
Good Luck,
-WN
Dec 28, 2009 | Canon Cameras
Canon camara was dropped and now it reads e18. Camara still shows pictures on the display screen
Hi
The Canon E18 error happens when the lens gets stuck while trying to extend. When your camera was dropped the lens mechanism was damaged resulting in this error for a jammed mechanism.
If the camera is still under warranty you should see if Canon are willing to repair it. If not you can view this link which is a very good walkthrough with pictures on how the error was resolved with a Canon SD300.
As you can see from this the process is intricate enough and involves opening the camera so should only be attempted if you feel confident about taking it on.
http://members.shaw.ca/gregs_space/Canon_E18_repair_guide_for_SD300.pdf
Hope this helps. Please remember to rate my answer. Many Thanks.
Jul 28, 2009 | Canon Cameras
Error message E18
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
Jan 12, 2009 | Canon PowerShot S1 IS Digital Camera
Canon powershot sd300 e18 error
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
E18 Error
Sorry to hear that. I have an A80 also, and I really like that camera (swear it takes better pictures than even my A620).
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
May 11, 2008 | Canon PowerShot A80 Digital Camera
Canon pwershot s1 IS E18 error code
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're worth a try:
Feb 14, 2008 | Canon PowerShot S1 IS Digital Camera
E 18 problem
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but they're still worth a try. Good luck! :
Feb 13, 2008 | Canon PowerShot S500 IXUS 500 Digital...
E 18 problem
This error is caused by a faulty lens motor, contaminated transmission, or mechanical damage from dropping. Unfortunately, there is no easy fix for this and it requires service from Canon or other repair facility.
Dec 30, 2007 | Canon PowerShot S2 IS Digital Camera
Trouble with lens and blank screen
http://www.e18error.com/repair.htmls shows pictures of how to take apart a similar camera.
need an online translator from Bulgarian.
Canon Repair is out of the question.
Dec 09, 2007 | Canon PowerShot S30 Digital Camera
Canon PowerShot A400 Digital Camera Logo
154 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
