Question about Mach Speed Zodiac MP3 Player
Zodiac mp4 player
HELP!!!!!
Dose anyone know if there is a firmware out that can go on this mp4 player? i called and they haven't seemed to have a need they said! any icon u hit gos to the same screen so dumb! anyway is there a hack or program that can upgrade the mach speed Zodiac 2gb mp4 player? thanks for ur time and help fast!
  • 1 more comment
  • paul_guil94 Apr 09, 2009
    It's exactly the same! I try to go in "explorer", but I only see red icons. And if I choose one of these, it stay on the same screen!
  • alexiscausor May 07, 2009
    it takes too long to load
  • user5555555 May 11, 2010
    Which screen does it go to? If you hold down the main button it always goes back to the main screen. Also, since the "buttons" are actually just light sensors, they are calibrated when it first turns on and can act like they are stuck if the light level around you changes.
How do I update the firmware for this player
Todd, first you give us enough information then we try to help!
what is it, make model #, etc and your complete question.
links below may help RE POST IF NOT HELPFUL
press the helpful button
How to Upgrade the Firmware on MP3 Player
Flash Drive Repair how to upgrade mp3 mp4 player firmware
http://www.moviecodec.com/mp3-players/installing-firmware-to-mp4-player-11573
How to Update the firmware for your MP3 MP4 player
Feb 07, 2016 | Audio Players & Recorders
Having erased all my music from my Disney Pixar MP4 player and am now left with 'Empty Disc!', is it possible to down load something called 'special firmware' from the internet on to the MP4 player?
It is very possible for you to download the firmware update from the internet on your mp4 player.
Follow the link below to download and see the instruction on how to install the firmware after downloading.
http://mympxplayer.org/image-vp129.html
Take care.
Jun 10, 2010 | Audio Players & Recorders
My (.XCESS.) MP4 screen does not display any thing
sounds to me like the firmware file has been corrupted, the included software for your player (MP3 utilities) should have a program called mp3 upgrade tool, which is used to load the firmware file to the player.
here is a site that should help you with firmware update
http://mympxplayer.org/how-to-recover-a-dead-mp3-mp4-player-vt10126.html
Mar 19, 2009 | Network Computing Devices (NSH800S/A)...
Wrong firmware added in mp4 player.....
You'll need to open up your player to find the plate and board ID numbers to be able to find a compatible firmware for your player. Take a look at this post here: http://mympx.org/forum/knowledge-base-faq/41330-how-recover-dead-mp3-mp4-player.html. This will tell you how to recover your dead player using your firmware.
Hope that helps.
Nov 10, 2008 | iLO (2 GB) MP3 Player
Sa3345/85
Try pushing the reset button on the bottom, next to the USB socket, then try switching on again.
If this doesn't work, then you may have corrupt firmware. Try a factory restore, as follows:
Open Philips Device Manager.
Whilst pressing and holding the [VOL+] button on the player, connect to the PC.
Continue to hold [VOL+] until told to release, then follow the on-screen prompts.
This will format the player and re-load the firmware.
NOTE: ALL FILES WILL BE DELETED FROM THE PLAYER.
May 12, 2008 | Philips GOGEAR SA6045 MP3 Player
Mp4 player ikasu
My son has just got ikasu mp4 4gb and also had problems.
but after much trial & error it works fine first i formated the
players memory then on video convertor tool i changed
screen rez to the bottom one in the drop box i think it 320*240
and the videos work fine and music you just open as an E drive
the drag and drop mp3s simple!
Feb 10, 2008 | Audio Players & Recorders
Mp4 nano 4gb keeps turning off
What I would recommend you to do is fo format your device and then update the firmware on the device..This problem will happen if you have some digital rights management problems on your device...Formatting the device and update the firmware is the only solution to your problem...
Thank You
Computerrep
**Please rate accordingly...
Jan 30, 2008 | Apple iPod nano
Mp4 player
The solution is, u gotta use the converter that comes with it. Its in the cd. Set to the correct resolution, which is 220x176 for ur model.
Nov 05, 2007 | Audio Players & Recorders
Mach Speed Zodiac MP3 Player Logo
253 people viewed this question
Top Mach Speed Audio Players & Recorders Experts
Gyula Lacz
Iron
Iron
Are you a Mach Speed Audio Player and Recorder Expert? Answer questions, earn points and help others
