Question about Sony Handycam DCR-VX2100 Mini DV Digital Camcorder
Lines through the tape when recording or playing back
I have a panasonic 2.3 mega pixel camcorder that uses dv tapes. It was working just fine until an error message came on that the heads needed to be cleaned. We followed the instructions, and cleaned the heads. When we tried recording or playing back our tapes, there are lines that run through the LCD screen and the tape will not play correctly. I am using Maxell mini DV's and Sony mini DV's and they both are doing that. I recently got a brand new JVC player, put one of these tapes in it, and it also is showing lines through the LCD screen and the tape is not playing correctly. Any suggestions?
  • Sony Master
  • 2,794 Answers
It could need a head adjustment. Any camera store can do that for you.
Posted on Feb 11, 2009
  • Tim Babcock
    Tim Babcock Mar 23, 2014
    Make sure that the firmware has been updated as well. The support section on the Panasonic website should have details on it (if it is provided).
No DV output from Canon GL2. Using a firewire cable from DV port on camera to firewire port on Mac Pro tower. Attempting to import the camera live to Final Cut Pro. Previously worked just fine.
Was the tape your trying to import recorded on the camera you are trying to import from? I've noticed that sometimes the tape I recorded on my old Panasonic won't show up on my GL2. It's like it's a blank tape, but I know it's not, as I have it labeled. Stick it back into the panasonic and it plays fine.
Nov 12, 2009 | Canon GL2 Mini DV Digital Camcorder
Panasonic NV-GS60 with horizontal lines appear on screen
Clean the heads(use the specified cleaning tape sparingly).
Change tape. Using Panasonic video tape? It sounds like no. You might get by with Sony... Try Panasonic.
The tapes are different thickness, durability and therefore suitability for cameras. Try to get ME -type tape( metal evaporated) instead of MP( metal particle) as the particles tend to flake off more readily. The blue often means no signal(video) was recorded in that space(on the tape). Let me know it it helps.
vac8
Dec 26, 2008 | Panasonic PV-GS39 Mini DV Digital...
Panasonic HVX200 will not play back tape
Your playback heads might be clogged. I am not sure if this camera with give you a RF warning if your record heads get clogged. Also most professional machines drums are rated at 1000 - 1500 hours before they need to be replaced. If you are at 500 and never cleaned the heads it is time to. Run a cleaning tape a few times.
Dec 16, 2008 | Panasonic AG-HVX200A Mini DV Camcorder
Pixels instea of clear picture
The problem is with the tape...Never rewind tape in the play mode for some reason it will screw it up.
And only use good tape such as...
Panasonic - MiniDV Digital Video Cassettes Model: AY-DVM80XJ
Dec 01, 2008 | Canon XL1S Mini DV Digital Camcorder
Lines across screen on playback.
A Q-tip should never be used to clean a video head.  Unfortunately they can pull the tiny head out of alignment.  I believe this is your problem and the repaid may be more costly than a new purchase.
Nov 25, 2008 | Panasonic Palmcorder PV-DV351 Mini DV...
Cannot play tape.
Sometimes that happens to me too. What I do is just push play, then fast forward, and normally if you watch it, the picture starts to come back. Just keep fast forwarding until you can see all of the picture, and you should be fine.
Mar 24, 2008 | Panasonic PV-GS19 Mini DV Digital...
Playback is Jittery at certain parts, but not on my Panasonic camcorder
TRY A DRY TAPE CLEANER. A GOOD ONE DONT BE SKIMPY. OR YOU MIGHT NEED TO GET THIS CLEANED BY A PRO. SOUNDS LIKE YOUR HEAD IS DIRTY.
Jan 09, 2008 | Samsung SC-D23 Mini DV Digital Camcorder
How do I remove lines
I had the problem of the horizontal grey lines with some pixels of pink. I ran the dry head cleaner a few times and the lines became solid grey with the sound now skipping worse than before. I cried, cleaned again, then played the tape. I did this about 4 times and still had no luck.
I then decided to try to record with a new tape around the room to see what would happen. After recording I played the tape back and it worked perfectly. I then went back the old tape that would not play properly and it worked fine! Seems like when I used the record button after cleaning it a few times everything worked fine, wierd.
Hope this might help someone.
Oct 22, 2007 | Canon ZR80 Mini DV Digital Camcorder
Canon zr100 digital video camcorder won't record or show picture on screen
PLEASE USE MINI DV HEAD CLEANING CASSETTE & TRY , MAY SOLVE YOUR PROBLEM
Oct 20, 2007 | Canon ZR100 Mini DV Digital Camcorder
My tape player in my video camera isn't working anymore...
repairs will cost close to replacement and - it will be older ( needs new heads , probably ); buy a new one , and get a repair quote on the old one - or ebay it , for parts ;
Nov 10, 2006 | Panasonic PV-GS19 Mini DV Digital...
Sony Handycam DCR-VX2100 Mini DV Digital Camcorder Logo
255 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
