Screen my screen workd fine on my pavilion ze4600 lastnight but today it is dull black i can barly see i tryed the brightness but i dont think it worked any thing i can do i have shutdown and restarted several times
  • 6,784 Answers
Unplug the screen itself so it can reset. plug back in after 5 min.
Posted on Feb 11, 2009
Lastnight PC booster took control of my PC and with my permission. I have had problems all day trying to connect to the internet. I am really frightened that I may have made a mistake. The reviews I r
Hi Beverly,
In order to fix your internet connectivity of computer please follow the below steps :
1. Restart the computer with Safe mode. ( Restart the computer and before any screen comes up, Keep taping F8. This will lead to an black screen, using up and down key select Safe Mode. And hit enter. You will be able to see many codes are coming up. Please dont panic as this is normal. Screen size will not be normal.)
2. Use Any antivirus to scan your computer.
Thank you for using FixYa
Regards
Subhankar Ghosh
Dec 27, 2014 | Cars & Trucks
Low beams are dull, barely on
I have a 2010 mazda6 and I had hid in it now my low beam are dull could barly see when its just low beams on and I changed my bulbs to stock
Mar 12, 2013 | 2004 Mazda 6
Dark Screen
Hi
Not cleaning per sey but a tune up. CRT monitors have alot of things going on inside (high voltage and high heat). This causes parts to change value. You can send this to my company for a tuneup or take it to a local serviceman. The average price price should be +- $100.00.
Thanks
Jul 23, 2009 | HP Pavilion MX70 17" CRT Monitor
Dull picture on laptop but cursor is still bright
The screen brightness is automatically adjusted by your laptop's Power Management configuration in the Control Panel. Depending on your laptop's brand you might not only have the Windows power management, but also a proprietary power management application within the control panel or in your Start Menu programs usually listed under your computer's brand name. For example a program folder called "Toshiba" under Programs for a Toshiba laptop. Anyway, I would start there. Usually you can set up the screen brightness according to whether or your computer is plugged in or working on battery. Good luck! :)
May 22, 2009 | Toshiba Satellite A105-S4004 Notebook
I've acer travelmate 4500 laptop. Till yesterday it was working fine, but today i donno what happend to it.. the screen display is completely dull. that I couldn't see the display and if I closely observe...
The possible reasons is that you have turned down your brightness and contrast without realizing it, to fix this simply look for a brightness key on your keyboard and turn it up. If it is missing or did not fully work, see if you can notice any image and try to get into your Display properties, click the setting tab and go into advanced and turn up your brightness and contrast from there. If this does not work, im afraid to say you have damaged your LCD screen and this would result in your dull screen appearance. Get a computer technician to take a good look at it to see what has happened if this is the case
Hope This Helps
Nov 18, 2008 | Acer Computers & Internet
My screen went dark !
hello sir
To state the obvious, make sure the brightness is turned up. This is usually a function key on the keyboard. If this doesn't accomplish anything, then the backlight on the lcd may be damaged, and the lcd will have to be replaced.
thank you
Jun 17, 2008 | HP Pavilion dv6000z Notebook
Screen is black
Press any button to see if the screen will light up. If it does not, then hold the power button in for 15 seconds. If that still fails: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 29, 2008 | SanDisk Sansa Clip MP3 Player
Screen`s brightness less
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness
If tese dont work either your LCD lamp or board may be going bad.
Nov 18, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Lights on bottom screen don't light
i dont think it is a problem i think it just does it to save energy
Oct 03, 2007 | Nintendo DS Lite Console
Computers & Internet Logo
151 people viewed this question
David Payne
David Payne
