Question about Acer Computers & Internet
Monitor turn dark frequently
Recently, my new PC monitor turns dark (turns into black screen) frequently. Now, I simply can't use my desktop PC due to this problem. What's the problem & what can I do to fix it? Does it have to do with the power supply of the PC / terminal box? Please help ! ! !
  • 191 Answers
It sounds like your PC trouble, you may try (it is better to make sure the monitor connect other PC ok)
1) check PC ram, change ram sticks position if there are two ram stick, or change a new ram if only one ram inside. not fix go next
2) check VGA cable connection, reseat the cable. still not fix go next
3) if you use AGP VGA card change VGA cable to onboard VGA interface (setup bios VGA to onboard),
is this helpful to you olease feedback thanks.
Posted on Feb 11, 2009
  • Frank Zhang
    Frank Zhang Mar 07, 2009
    is this any help you fixed?
Gateway 5150 - the screen is black but switched on - need to twist and put in light to be able to see anything. Don't know what to do?
You know Sir instead of hassling with this just go and get another monitor you can find CRT's all over at garage sales. It would be your best bet and avoid the confusion just get another monitor. That one is more than likely no good anymore. John
Apr 09, 2012 | Compaq Presario 5150 (320850-003) PC...
Monitor has power. Will come on very briefly and the go to black screen. Can turn power off and back on and get the same above result.After a 2-3 hour period may come to life...may not.
It appears as if the monitor's back lighting is failing. To test the theory, take a bright flashlight and shine it on the lcd monitor screen when it goes black. If you can see the images that were on the screen before it went dark while shining the flashlight on the screen, then the back lighting is failing. Depending on the monitor, it could have florescent or L.E.D. back lighting, but it's usually more economical to simply replace the monitor with a new better performing monitor, than to attempt repairing the back lighting on the failing monitor.
Dec 01, 2010 | Samsung SM225BW 22 inch LCD Monitor
Second monitor is black
Simply hooked up to my onboardchipset and my graphics card. Should have tryed it sooner. Thankyou for all your help
Oct 13, 2009 | Dell Computers & Internet
Computer monitor screen stays black
please check the signal cable..... sometimes the signal cable gets faulty and it would be best if you replace it..
Jun 02, 2009 | LG Flatron L1710S 17" LCD Monitor
Backlight for display cuts out
Bad capacitors are a plague now, most likely cause of the black screen
simply remove the doomed and caps that have color leaking from the top. and replace with duplicate good caps from your local electronics store
Mar 22, 2009 | HP W2007 LCD Monitor
Screen seems to be not working properly
try using a different monitor, borrow one if you have to, if the monitor works on your computer, then it simply means you need a new monitor. As far as the computer shutting down, it may be recording the bad monitor as an error in the loading process and automatically shutting down.
Mar 15, 2009 | HP TouchSmart IQ770 PC Desktop
Safe Mode is also Black..
I found your other posts regarding this problem. I believe it may be that your monitor is failing. Do you have another monitor to try? Another clincher is to start the computer, do the login, and when the monitor goes dark, turn off it's power button, and turn it back on after waiting for 30 seconds or so. If the monitor lights and looks normal then goes back off, it's the monitor at fault.
Dec 12, 2008 | E-Machines eMachines Desktop PC
My computer monitor has somehow turned its brightness all the way down, possibly due to me choosing a new screensaver which was already installed on my computer. Sadly, my monitor, an Emprex LM-1704...
Find yourself a dark room or wait for the night to come. The darkest monitor adjustment could somehow reveal some light when there are no other light source available.
You may also hook a conventional CRT monitor and make your changes (such as bringing your computer back to its original settings). The darkest adjustment in CRT monitor could still render discernible displays.
Sep 09, 2008 | Computers & Internet
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Faulty monitor
This is most probably cause by one or more Faulty Electrolytic Capacitors, I find these are the MOST commonest form of "Fault" in these LCD's TFT's units. I ususally simply replace "On Spec" all High Value Electros, in fact ALL Electro's are suspect and often I just "Shotgun" and replace 'em all. Usually fixes all problems. Always use High Temperature Caps.
May 11, 2007 | Proview XL370B (Black) 17 in. Flat Panel...
Computers & Internet Logo
419 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
