Question about Kenmore Dryers
Kenmore Dryer - no heat and timer doesn't stop
Although the dryer spins, there is no heat and the timer doesn't stop and end. It stops prior to the end.
  • pdarred Feb 11, 2009
    Hope this helps!
    Model Number 11066722694 Electric
    The timer on the dryer stops prior to the end of the cycle. Since it doesn't go to stop, it continues to spin continously unless I manually turn the dial to stop. I started the dryer prior to going to work and it was still spinning when I got back for lunch 4 hours later. The timer was about to stop but it didn't. The clothes (just a few pairs of jeans) were cold and a little damp. There was no heat; just cool air. Both problems happened simultaneously.
    The interior light works. There is no noise like a clanking or burn wire smell. The exhaust and filter are clean.
    Is it fixable or should I just put it out on the curve.
    Thanks.
  • Mark Egan May 11, 2010
    Please give the dryer model number, and more clearly describe the symptoms of the dryer failing to operate more clearly so we can help you more.
  • 979 Answers
First turn off both breakers then back on. Next, check the wiring from the receptacle to the plug to the back of the dryer. Next, the thermal switch under the top of the dryer next to or near the drum may be bad. Bypass it and see if you get heat. If so, then replace it for about $20. Your heating element may be bad also. You can visually check it and see if it is burned in 2. Now your timer is probably bad. They are easy to replace and fairly inexpensive.
I guess after looking at all this, you need to decide if it is all worth it to fix it. If it is more than 10-12 years old, you may be seeing the beginning of the end. If the thermal switch, the element, the timer are all bad, you may want to make room at the curve and take the door off for safety. Dryers aren't that expensive especially when you consider the hassle. Good luck and let me know how and what you do.
Posted on Feb 11, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore dryer model 110 does not stop during automatic cycle
Make sure the small orange wire is connected to the 250 limit at the base of the heater assy. That is what powers the motor on auto cycle.
Nov 27, 2013 | Kenmore Dryers
The dryer is not heating up and the dial stops at the cool down so the dryer will not shut off by it self. Its a kenmore 70 series dryer.
you need to send the model number,open the door and look around the opening where you put the clothes into the dryer and you'll see the tag with the model number.it will start with 110. or 417.because you have no heat that's why the timer won't advance,when the heat shuts down then the timer advances when the heat comes back on the timer stops moving or advancing,no heat the timer won't move.send the model number
Jan 16, 2011 | Kenmore Dryers
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
My kenmore dryer just stopped working. the timer
the timer has internal cog teeth with works with an ecentric cam to keep the timer operating. the cam is working if ticking although a tooth appears to be broken keeping the timer to advance on its own
Mar 13, 2010 | Kenmore 63942 Dryer
Kenmore 11066912690 dryer stops working
if you are using the sensor drying cyle this could cause the unit to stop. it will detect the most dry clothing first usually light clothes that dry faster.if not and you are useing timed dry the most likely cause is a faluty timer,or a thermostat sesnor is going bad and turnoing off the dryer before the clothes are dry
Sep 16, 2009 | Kenmore 62602 Electric Dryer
Started dryer at 6 am, got home at 5pm it was still running
if it was set on timed dry replace timer if it was on auto dry check element thumbs up
Aug 12, 2009 | Kenmore 62882 Electric Dryer
Replaced timer, new one stops turning and doesn't turn dryer off.
Some dryers have a "press guard" setting. This willkeep the dryer tumbling with no heat at the end of the cycle. Usually you can select it on or off and in some cases can set the time. see if you have this feature.
Apr 07, 2009 | Dryers
Dryer timer still runs after auto-cycle is complete.
can you just leave the door open when not in use???????
Mar 30, 2009 | Kenmore Dryers
With timer on dryer stops spinning when door is open but heat won't shut off
The element might be shorted and grounding itself to the element housing.
Could also be the centrifugal switch in the motor or the contacts in the timer.
Feb 18, 2009 | Kenmore 62802 Electric Dryer
Dryers Logo
363 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
