Question about Apple iPhone Smartphone
I reboot and the opening screen is asking for my voicemail passwo
When I type in the number password, I can't get the ok or cancel buttons to work.
Try to reset it..
hold the home button and on/off for sec..
just try..
Posted on Feb 11, 2009
Our school has a Siemens 500 OptiPoint 500 advance phone that has a greeting one. Can't find out in any of the manuals as to how I can go about changing it. Can anyone out there help me?
We always programme the voicemail to 555. If you have something different change what is below, which is our 'one sheet' user guide from www.dschiltern.co.uk
All Types of Phones
1. Your mailbox number will be the same as your extension number.
2. Default password is 1 2 3 4
3. Voicemail group number is 555 (unless programmed differently)
Before callers can leave voicemail messages you must activate your mailbox and record your greeting message. We would suggest something along the lines of
"You are through to the voicemail of . . . . I am sorry I am unable to take your call at the moment but please leave a message after the tone and I shall get back to you "
To Record Your Greeting Message
1. Dial the voicemail group number (usually 555)
2. Enter your password (default is 1234)
3. Keep pressing 3 to scroll to greeting messages
4. Press 8 to toggle between your two greeting messages
5. Press 0 to change the message and follow the instructions.
To leave voicemail just press 'Release' or hang up.
Responding to Voicemail
On a display phone you will see "You have messages" on the top line and "Display messages?" on the bottom line. Press tick twice to go to voicemail and then enter your password.
On Siemens 'Entry' phone or display phones with a 'voicemail' button, just press this button and enter password when asked.
On ordinary analogue phones you will get broken dial tone. Dial the voicemail group number (usually 555) and enter password.
In all cases you will then be able to listen to your messages.
To delete a message press 0. It will ask you to confirm by pressing 0 again.
Sep 17, 2014 | Siemens optiPoint 500 Advance - Corded...
How to reset a password on vizio p42hdtv10a tv i forgot the passwored
Hello
To change password use the number pad and type '0000' or whatever password you have changed it to previously, then press OK.
Actual proceedings are:
[1] Press the MENU button to open the main
On Screen Display (OSD) menu.
[2] Press the [
three times until the Parental Control
menu opens.
[3] Press the [Down] button on the remote control
to highlight Parental Lock Enable. The
"Key-In Access Code" window opens.
[4] Use the number pad to type the default
password (0000) or whatever password
press OK.
[5] Press the [Down] button on the remote control
to highlight Access Code Edit.
[6] Press the [=>] button on the remote control
to enter the submenu. You will need to
use the number pad to type default (or
what you changed to previously) password
first
[7] Use the number pad to type the new
password.
[8] Confirm the new password by retyping it.
[9] Press EXIT button on the remote control immediately to exit the OSD menu
Jul 29, 2011 | Televison & Video
Voicemail not working How to record a message
Depending on what type of voicemail you have installed this should be the way to setup your voicemail. Typically if you dial your voicemail extension and press * when the main greeting starts it will ask you for your mailbox number. Usually your mailbox number is the same as your extension number and you password is defaulted to your extension number plus 997. If your password doesnt work you will have to go into the administrator mailbox which is 999. the password is usually 999997. Go to option 8 on menu then option 4. this will reset your password on your mailbox to default. Also included a website with Toshiba manuals. Hope this helps.
http://www.wedophones.com/ToshibaManualsLead.htm
Feb 24, 2010 | Toshiba DKT2010SD Phone
How do we reset a voicemail password for a Nortel M7324 phone?
press feature 983 the screen should say log:
enter 1020000 (default password) if you have a 3 digit intercom number, 120000 if you have a 2 digit intercom number
the display should say mbox, AA, and othr above the three soft keys
press the mbox soft key
the screen should say add, del, and chng above the soft keys
press the chng soft key
enter in the mailbox number you wish to reset the password on
press ok
the screen should say reset and next above the soft keys
press the reset soft key
press the Rls key
your password should be reset to 0000
Oct 20, 2009 | Lands Phones
I cant remove the deep freeze software standred 6
read this :
http://www.faronics.com/faq/default.asp#7
1-This software (protection) is effective, it is
impossible to ignore, unless you remember
password entered at the first reboot after
installation password that allows you to unfreeze
the position, necessary step prior to
uninstallation. To access the password window
Password combine the ALT + CTRL + SHIFT + F6, then
choose "boot Thawed" and restart.
2-for Windows 2000 or XP
Go to Start-> Control Panel-> Tools
Administration-> Services
click on right click then Properties DFServEx
in the general tab in Startup type: select
Option deactivated
then reboot and all will be resolved
3-http: / / www.faronics.com/
4-for disabled deepfreez is simple
pressed the button shift + double click on deepfreeze
nearby clock. enter the code if you enter the / if you did
not click OK.ENSUITE CLICK ON BUTTON LE3EME
ENSUISTE OK and restart THE PC
after the boot up you found approximately one thinks red
deepfreeze ok
releancer installing deepfreeze and its SETUP
you found approximately UNANSTALL OK UNTIL THE END
AFTER rebooting TT WILL BE AS BEFORE
5-download the recent version of deep freeze and
installation and during installation it asks you
uninstall the previous version and continues to validate
jusqau he asks you to install the new version
cancel
Sep 09, 2009 | Computers & Internet
I have a problem with voice mail with a meridian hooked to NT5806DA-93. The system on voice mail every second pulse off so that only half of each message is played at a half second interval
Voicemail Features Norstar Common To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
Norstar Voicemail Administrative Programming Programming must be done from any M7310, T7316, or M7324 model phone set.
To Log Into System Administration:
1. Enter Feature 983
2. The display will show "LOG", enter your login password
a. If your company extensions are 2 digits long enter "120000"
b. If your company extensions are 3 digits long enter "1020000"
c. If your company extensions are 4 digits long enter "10020000"
3. Press the softkey under "OK"
To Create a New Mailbox:
1. Log into system administration
2. Select the softkey under "MBOX"
3. Select the softkey under "ADD"
4. Enter the mailbox number (extension. you want to add
5. Mailbox type: Subscriber and then select "OK"
6. Extension: Usually the same as the mailbox number
7. Service Class: Enter 1
8. Name: Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma, and then enter the first name. When spelling the name, press # to move to the next character
9. Directory: Y (Yes.
10. Message Waiting: Y (Yes.
11. Out dial: Pool, enter 1 and then OK
12. Accept: 1, select OK
To Delete a Mailbox:
1. Log into the system administration
3. Select the softkey under "DEL"
4. Enter the mailbox number (extension. you want to delete
5. Select the softkey under "Delete"
To Reset a Mailbox Password:
3. Select the softkey under "Chng"
4. Enter the mailbox number you want to reset the password for
5. The display shows "Reset Password"
6. Select the softkey under "RESET"
7. Press the release key
*The new password will be "0000", the system will ask the user to change this the first time they log into their mailbox using this password.
To Change the Name on a Mailbox:
4. Enter the mailbox number (extension. you want to change the name on
6. Select the softkey under "Next", keep hitting "Next" until the display shows the name
7. Select the softkey under "Chng" to enter a new name
8. Enter the name using the dial pad. Enter last name first, press "# #" to enter a comma and then enter the first name. When spelling the name, press "#" to move to the next character
9. Select the softkey under "Next" to save the change
10. Hit the release button
Apr 15, 2009 | NorStar Lands Phones
Cant get voicemail
call your own phone number, and once it asks for the password type in the last 4 digits of your phone number.
Nov 25, 2008 | Vtech CS5111-2 Twin Phone
Voicemail does not work
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Jul 14, 2008 | Apple iPhone 3G
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
4. Leave message
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Apple iPhone Smartphone Logo
50 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
